Forum Index : Microcontroller and PC projects : stmF7Mite repport
Page 6 of 6 | |||||
boss Senior Member Joined: 19/08/2011 Location: CanadaPosts: 268 |
@derexponent yes, version 1.06 working properly Thanks |
plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
Hi, I testet several keyboards on the disco but with no luck. Even the board with installed mmbasic on will starts only if it connectet to an usb port on an computer but will not start if the source a normal phone charger with usb ( 1500 ma) in this case. Btw: what do you think about a nestet funktion call entry . So we dont need kill other functions for. |
darthmite Senior Member Joined: 20/11/2011 Location: FrancePosts: 240 |
I get the same problem. Now i just use wireless kb and it's ok. Actually i use a Logitech K260. Cheers. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8566 |
Works nicely for me with a Lenovo SK-8825. Disco powered from the USB ST-Link port direct from the computer so 500ma max You are using the USB-FS port? |
Hi, After some resets it works. I use a dirty cheap usb keyboard and an usb otg Adapter. What do you think of mod file sound support? |
I made a stm32f429 version of mod32 player. It's a 90% like the one use in mmsasic. What is to modify is to use the sound data with the external audio dma. If someone want to port it i can provide the source Cheers. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
StevePL Newbie Joined: 18/03/2016 Location: PolandPosts: 2 |
I've been playing with V1.07 for a few days and it's great. Is the source code available for 1.07? I downloaded V1.0 from Geoff's site but was wondering about the latest version. Is anybody working on adding file handling to this as not having it really limits what you can do? I've written a small basic program to create a pop up 4x4 numeric entry window which works really well. Is there anywhere to post programs like this? Just in case it may be useful to someone else. I haven't played with micro controllers since the mid 80's mostly Zilog z 8's programmed in assembly but I cut my PC teeth on GW basic, Quick basic and Quick C so this is a huge nostalgia trip for me!! Thanks to everyone involved for all the hard work!! |
Playing around with the source I managed to enable the file I/O and for now it appears to be working. I'll test it over the next few days. Geoff, I'm really impressed. MM Basic is the muts nuts!! Uwe , Fabrice I'm so happy you ported it over to this platform. It's really great. Steve |
I think matherp is now doing 3 or 4 new version per day it will be hard for Geoff to know what to post on his source page ... he he he .. But anyway it will be good if the version from the source can be written that we can know what the actual state is Cheers. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
Uwe has the latest source. I haven't touched it since 1.07 was released by him. He is clearly the "owner". It would definitely be good is someone had the time/skills to complete the File I/O routines |
mysli Newbie Joined: 27/07/2016 Location: GermanyPosts: 11 |
Hi All, I recently found the MaxiMite port for the SMT32M746 Disco and was very much amaced by having this Basic interpreter system available there. I have flashed the version V1.07, but discovering a lot of issues. I have played around with the touch buttons to get familiar with it, but V1.07 seems to have severe issues here. I downgraded back to V1.00, then things are looking better, although still some of the examples do make trouble. V1.07 is out since quite some months already, are there any activities on the STM32 porting, does it make sense to report bugs? Is there maybe a newer release available? |
Micro-80 Newbie Joined: 03/03/2017 Location: Russian FederationPosts: 26 |
A year has passed. Any news about this project? |
WalterHynson Newbie Joined: 12/09/2019 Location: United StatesPosts: 1 |
Hello,I hope this project is not dead,I got it loaded and running fine and I need to know have you tried to use a RS3232 to TTL for a RS232 port to connect to a serial printer?also I am having trouble with the syntex for circle.please give an example of the correct syntex as evertime I get an error:invalid argument.If you have time please help blindwarrior1952@gmail.com. THANKS |
lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3008 |
Note that the last evidence of this project being worked on was from over three years ago. You would be much better off with the newish and currently-maintained ArmMite F4 port--see here and here The part and LCD are available on aliexpress here for about $25USD. (Note--you may want to edit your post to obfuscate your email address so that malevolent scrapers don't get it and bombard you. Also, followup, if you get the F4, should be on one of the above threads or a new one.) Edited 2019-09-16 23:11 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Page 6 of 6 |
