Subject Topic: stmF7Mite repport Post ReplyPost New Topic
<< Prev Page of 10 Next >>
darthmite
Posted: 26 September 2015 at 9:26pm | IP Logged Quote darthmite
Hi ,
I just finished the base for 3D Object and it work well for 100% software 3D
We can load up to 25 object , each can have 600 points and 600 faces.
But try to keep this value lower as possible to be fast.
In same time Uwe resolved the COM1 and 2 issue and made the SPI Library work !!
Some more next time ...
Cheers.
Edited by darthmite on 26 September 2015 at 9:26pm
Back to Top View darthmite's Profile Search for other posts by darthmite
phantomnet
Posted: 26 September 2015 at 9:31pm | IP Logged Quote phantomnet
if i’ll write :
10 color red,black
20 cls 0
30 color blue,white
40 print “anything”
it should to be printed on lcd as fore color: blue and background color: white
but is not?! :(
lines 10 and 20 doing their job but line 30 isnt
Back to Top View phantomnet's Profile Search for other posts by phantomnet
darthmite
Posted: 26 September 2015 at 9:51pm | IP Logged Quote darthmite
I don't know what version you using , but here it's ok on version a34
phantomnet
Posted: 26 September 2015 at 10:22pm | IP Logged Quote phantomnet
I'm using latest version A35
I've check on A34 and is not ok !!
it just print fore:white, Bacground:blue (system colors) and
you cannot have to change Print command colors, only system colors!!
If you type separate commands like
> color blue,white
> print "232323"
232323
it's working
BUT
> 10 color blue,white
> 20 print "asdasda"
> run
asdasda
its not working !!!
darthmite
Posted: 26 September 2015 at 10:29pm | IP Logged Quote darthmite
Strange
Something for Uwe to try out.
First time I tried in console , it's why it worked.
phantomnet
Posted: 26 September 2015 at 11:04pm | IP Logged Quote phantomnet
This is my test setup:
STM32F746 Discovery
Arduino proto shield
CC1101 board
Rear view
Front view
Connectors
Prototype Shield
Work in progress:
CC1101 432Mhz scanner (thanks for SPI1/SPI2 implementation )
Zonker
Posted: 27 September 2015 at 2:19am | IP Logged Quote Zonker
Humm... Awesome setup...! But what type of display unit are you using..? I see ST on it... Not sure how it interfaces... I have a discovery board, but no touch display for it... Looks like the firmware package is shaping up nicely..! I was wondering if support for the A/D and D/A hardware would be included...
Anyway.. Nice work Gent's..!
Back to Top View Zonker's Profile Search for other posts by Zonker
Posted: 27 September 2015 at 6:57am | IP Logged Quote matherp
Great work
Edited by matherp on 27 September 2015 at 7:19am
phantomnet
Posted: 27 September 2015 at 7:51am | IP Logged Quote phantomnet
Zonker:
Board is STM32F746G-DISCO from ST
link
Firmware is MMBasic 4.5 like in this topic.
derexponent
Posted: 27 September 2015 at 11:04am | IP Logged Quote derexponent
i just uploaded a new version (a36)
> 10 color blue,white
> 20 print "asdasda"
> run
asdasda
its not working !!!
should work now
and here a video with 3D-Objects-Functions from Fabrice
3dObjects-video
here a second video to demonstrate the multitouch
multitouch
leave a comment if spi should have more settings
(like LSB/MSB, more speed options)
Uwe
Edited by derexponent on 27 September 2015 at 11:08am
Back to Top View derexponent's Profile Search for other posts by derexponent
derexponent
Posted: 27 September 2015 at 11:40am | IP Logged Quote derexponent
ADC is comming next --> EDIT : ADC is working with new update A.37
but the two DAC-Ports are not routed to the Arduino connector
(and used for other functions)
but the board has a two channel sound DAC on a headphone jack
so maybe we can handle analog output at this way
or PWM at a normal GPIO with an external RC filter.
Uwe
Edited by derexponent on 27 September 2015 at 5:03pm
phantomnet
Posted: 27 September 2015 at 9:23pm | IP Logged Quote phantomnet
Uwe:
SPI working good. If You can add more options it will be more flexible.
I have found another issue:
Some times (every 20-30sec) during do/loop in test sub lcd loosing horizontal synchro for 1-2 frames.
It is simple scanner using RF1100SE board with CC1101 chip.
Sub test()
  graph_init()                                    'draw layout
  spi_setup()                                     'spi setup
  cc1101_setup()                                  'set CC1101 registers
   For cc= 0 To 63                                '64 channels
    Line((cc*4)+204,210)-((cc*4)+206,20),Black,BF 'clear prev draw
    spiWriteReg(&h0A,cc)                          ' set new channel
    rr=RSSI(spireadreg(&hf4))                     ' read RSSI level
    Pixel((cc*4)+204,100-rr)=Red                  ' draw level dots
    Pixel((cc*4)+205,100-rr)=Red
    Pixel((cc*4)+206,100-rr)=Red
    If tocz(5,22,85,72)=1 GoTo go_out             'check touch
   Next cc
go_out:
  SPI close 1                                      'close spi
End Sub
Sub graph_init()
  Color White,Black
  Cls 0
  Line(0,0)-(479,18),50712,BF   'top status bar
  Line(5,22)-(85,72),50712,BF   'draw button
  Color Black,50712             'color for button label
  Print @(19,41) "Stop scan"    'botton label
  Line(203,24)-(459,24),Blue
  Line(203,222)-(459,222),Blue
'drawing dots net
  For i=0 To 23 Step 4
   Line(203,24+(i*8))-(459,24+(i*8)),Blue
  Next i
  For i=0 To 32 Step 4
    For j=0 To 24
      Line((i*8)+203,219-(j*8))-((i*8)+203,217-(j*8)),Blue
    Next j
  Next i
End Sub
Function tocz(x1,y1,x2,y2)
 Local n
 n=MTouched(#s)
 If (n=1) Then
  x=MTouched(#x,1)
  y=MTouched(#y,1)
  If (x>=x1)And(x<x2)And(y>y1)And(y<y2) Then
    tocz=1
  Else
    tocz=0
  EndIf
 Else
  tocz=0
 EndIf
End Function
' CC1101 SPI functions
Function RSSI(val)
If val>=128 Then RSSI=((val-256)/2)-74
If val<128 Then RSSI=(val/2)-74
End Function
Sub SPI_setup()
' SPI port setup
  SetPin 9,din        ' GDO0 = D08
  SetPin 10,din       ' GDO2 = D09
  SetPin 11,dout      ' CS   = D10
  SetPin 12,spi1_mosi ' SI   = D11
  SetPin 13,spi1_miso ' SO   = D12
  SetPin 14,spi1_sck  ' SCLK = D13
  SetPin 15,dout      ' led  = D14
  SetPin 23,din
  SPI OPEN 1,h,0
End Sub
Sub spiWriteReg(addr,val)
  Local sp
  Pin(11)=0
  sp=SPI(1,addr)
  sp=SPI(1,val)
  Pin(11)=1
End Sub
Function spiReadReg(addr)
  Local sp
  Pin(11)=0
  sp=SPI(1,addr)
  spiReadReg=SPI(1,0)
  Pin(11)=1
End Function
Sub cc1101_setup()
spiWriteReg(&h30,&h00) 'command SRX
spiWriteReg(&h0b,&h0b) 'FSCTRL1(0x0B)=0x0B
spiWriteReg(&h0C,&h00) 'FSCTRL0(0x0C)=0x00
spiWriteReg(&h0D,&h10) 'FREQ2(0x0D)=0x10
spiWriteReg(&h0E,&h10) 'FREQ1(0x0E)=0xA7
spiWriteReg(&h0F,&h62) 'FREQ2(0x0F)=0x62
spiWriteReg(&h10,&h2D) 'MDMCFG4(0x10)=0x2D
spiWriteReg(&h11,&h3B) 'MDMCFG3(0x11)=0x3B
spiWriteReg(&h12,&h73) 'MDMCFG2(0x12)=0x73
spiWriteReg(&h13,&h22) 'MDMCFG1(0x13)=0x22
spiWriteReg(&h14,&hF8) 'MDMCFG0(0x14)=0xF8
spiWriteReg(&h0A,&h00) 'CHANNR(0x0A)=0x00
spiWriteReg(&h15,&h00) 'DEVIANT(0x15)=0x00
spiWriteReg(&h21,&hB6) 'FREND1(0x21)=0xB6
spiWriteReg(&h22,&h10) 'FREND0(0x22)=0x10
spiWriteReg(&h18,&h18) 'MCSM0(0x18)=0x18
spiWriteReg(&h19,&h1D) 'FOCCFG(0x19)=0x1D
spiWriteReg(&h1A,&h1C) 'BSCFG(0x1A)=0x1C
spiWriteReg(&h1B,&hC7) 'AGCCTRL2(0x1B)=0xC7
spiWriteReg(&h1C,&h00) 'AGCCTRL1(0x1C)=0x00
spiWriteReg(&h1D,&hB2) 'AGCCTRL0(0x1D)=0xB2
spiWriteReg(&h23,&hEA) 'FSCAL3(0x23)=0xEA
spiWriteReg(&h24,&h0A) 'FSCAL2(0x24)=0x0A
spiWriteReg(&h25,&h00) 'FSCAL1(0x25)=0x00
spiWriteReg(&h26,&h11) 'FSCAL0(0x26)=0x11
spiWriteReg(&h29,&h59) 'FTEST(0x29)=0x59
spiWriteReg(&h2C,&h88) 'TEST2(0x2C)=0x88
spiWriteReg(&h2D,&h31) 'TEST1(0x2D)=0x31
spiWriteReg(&h2E,&h0B) 'TEST0(0x2E)=0x0B
spiWriteReg(&h00,&h0B) 'IOCFG2(0x00)=0x0B
spiWriteReg(&h02,&h06) 'IOCFG0(0x00)=0x06
spiWriteReg(&h07,&h04) 'PKTCTRL1(0x07)=0x04
spiWriteReg(&h08,&h05) 'PKTCTRL0(0x08)=0x05
spiWriteReg(&h09,&h00) 'ADDR(0x09)=0x00
spiWriteReg(&h06,&hFF) 'PKTCTRL1(0x06)=0xFF
spiWriteReg(&h31,&h00) 'command SFCTXON
spiWriteReg(&h34,&h00) 'command SRX
End Sub
Any suggestions ?
Edited by phantomnet on 27 September 2015 at 9:24pm
