JAQForum Ver 20.06
Local Time 07:08 13 May 2024 Privacy Policy
Forum Index : Guest Book : local variables
crez
Posted: 11:40am 04 Jun 2021
running the following
Option explicit
Dim a As integer
s1
End
Sub s1
Local b As integer
s2
End Sub
Sub s2
Local c As integer
a=1
b=1
c=1
End Sub
gives the error 'b is not declared' at line 14.
because sub s2 is called from within s1, I was expecting b would be declared, in the same way that a is available in s1. Apparently not. If I declare b in sub s1 using the DIM command, it becomes available in sub s2 but also the main program, which is not what I desired.
© JAQ Software 2024
