JAQForum Ver 20.06
Local Time 21:46 13 May 2024 Privacy Policy
Forum Index : Guest Book : MMBasic
RicM
Posted: 02:06am 06 Feb 2022
How do you keep part of the number after the decimal point I was thinking of using the FUNCTION Command.
Any ideas
Kind Regards
RicM
disco4now
Posted: 04:36am 06 Feb 2022
Hi RicM
You should probably post MMbasic questions in the  Microcontroller and PC projects section. Also say which MMBasic system you use (e.g. CMM2 ,Picomite )as their maybe some differences.
see the STR$ function in the manual.  STR$( number, m, n )  where n is number of decimal places
If it is a picomite the FORMAT$ function has some options as well
Gerry
Edited 2022-02-06 14:36 by disco4now
Latest F4 Latest H7
© JAQ Software 2024
