JAQForum Ver 20.06
Local Time 14:30 13 May 2024 Privacy Policy
Forum Index : Guest Book : Simple solar regulator
Godoh
Posted: 06:44am 12 May 2022
I have seen some articles here about home made MPPT controllers, they look very complex to me.
I need to replace my damaged controllers and want to control the following.
24 volt battery bank
90 volts DC panel voltage
60 amps or above current from the controllers to the battery.
Many years ago I saw some stuff that was being done by Oztules on home made regulators. Just wondering if anyone here knows of a simple circuit to use for this purpose and where I can get circuit boards made in Australia.
I have a board design for a project that Oz did but it is only a .png or pdf file.
Do any manufacturers work from pdf files?
Hope someone knows
Pete
Solar Mike
Posted: 02:28am 13 May 2022
May I suggest you post your question under an appropriate forum topic like "Solar" in order to get any replies.
Mike
Godoh
Posted: 04:56am 13 May 2022
Thanks mike, yep I forgot to choose the right forum.
Pete
© JAQ Software 2024
