Forum Index : Microcontroller and PC projects : The Great Colour Maximite 2 Octahedron Prize Challenge
Page 11 of 11 | |||||
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8582 |
The 3D team I've attached the latest hack version for you to try and help me diagnose the problem with my hidden surface algorithm CMM2V1.5.zip Here is the test program option explicit option default float dim integer viewplane = 700 dim q(4) dim roll=rad(0.5) dim integer nv=9, nf=9 ' cube has 9 vertices and 9 faces 'array to hold vertices dim v(2,nv-1)=(-1,1,-1, 1,1,-1, 1,-1,-1, -1,-1,-1, -1,1,1, 1,1,1, 1,-1,1, -1,-1,1, 0,0,.1) math scale v(),200,v() ' array to hold number of vertices for each face dim integer fc(nf-1) =(4,4,4,4,4,3,3,3,3) dim integer bcol(nf-1)=(rgb(red),rgb(blue),rgb(green),rgb(magenta),rgb(yellow),rgb(cyan),rgb(white),rgb(brown),rgb(gray)) dim integer fcol(nf-1)=(0,0,0,0,0,0,0,0,0) 'array to hold vertices for each face dim integer fv(math(sum fc())-1)=(1,5,6,2, 1,0,4,5, 0,3,7,4, 5,4,7,6, 2,6,7,3, 0,1,8, 1,2,8, 2,3,8 , 3,0,8) draw3d create 1, nv, nf, v(), fc(), fv(),fcol(),bcol() dim integer c page write 1 draw3d camera 1,viewplane, mm.hres\2, mm.vres\2, 0 for c=0 to 720 math q_create roll,1,2,3,q() draw3d show 1,mm.hres\2,mm.vres\2,1000 draw3d rotate 1,q() inc roll,rad(0.5) page copy 1 to 0,b do while inkey$="":loop next draw3d close all If you run the code you will see a diagnostic at the top of the screen. This prints the normalised vector from the vertex to the camera x, y, and z and then the calculated surface normal of the triangle and finally the dot product of the two. This output is for the brown triangle. If you step the program forward by pressing any key you will see the dot product slowly increasing and then when it gets positive the brown segment disappears when it clearly is still facing the camera. This is my bug I can't find. The C source is below if it helps for(f=0;f<struct3d[n]->nf;f++){ // calculate the surface normals for each face vp=struct3d[n]->facestart[f]; p1.x=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].x; p1.y=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].y; p1.z=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].z; p2.x=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+2]].x; p2.y=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+2]].y; p2.z=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+2]].z; p3.x=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp]].x; p3.y=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp]].y; p3.z=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp]].z; U.x=p2.x-p1.x; U.y=p2.y-p1.y; U.z=p2.z-p1.z; V.x=p3.x-p1.x; V.y=p3.y-p1.y; V.z=p3.z-p1.z; normals.x=U.y*V.z-U.z*V.y; normals.y=U.z*V.x-U.x*V.z; normals.z=U.x*V.y-U.y*V.x; normalise(&normals); ray.x=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].x*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].m+x-struct3d[n]->camera.x; ray.y=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].y*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].m+y-struct3d[n]->camera.y; ray.z=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].z*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+1]].m+z-struct3d[n]->camera.z; normalise(&ray); if(f==7){ PInt(f);PFlt(ray.x);PFltComma(ray.y);PFltComma(ray.z);PFltComma(normals.x);PFltComma(normals.y);PFltComma(normals.z); } struct3d[n]->dots[f] = ray.x * normals.x + ray.y * normals.y + ray.z * normals.z; depth[f]=struct3d[n]->nearest[f]; depthindex[f]=f; if(f==7){ PFltComma(struct3d[n]->dots[f]);PRet(); } } // sort the distances from the camera depthsort(depth, struct3d[n]->nf, depthindex); // display the forward facing faces in the order of the furthest away first for(f=0;f<struct3d[n]->nf;f++){ // sortindex=f; sortindex=depthindex[f]; vp=struct3d[n]->facestart[sortindex]; if(struct3d[n]->dots[sortindex]<0){ for(v=0;v<struct3d[n]->facecount[sortindex];v++){ xp=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].x*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].m+x; yp=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].y*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].m+y; zp=struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].z*struct3d[n]->r_vertices[struct3d[n]->face_x_vert[vp+v]].m+z; // We now have the coordinates in real space so project them zdist=sqrt((xp-struct3d[n]->camera.x) * (xp-struct3d[n]->camera.x) + (yp-struct3d[n]->camera.y) * (yp-struct3d[n]->camera.y) + (zp-struct3d[n]->camera.z) * (zp-struct3d[n]->camera.z)); zratio=1.0-struct3d[n]->viewplane/zdist; // We now know how far the point is away from the camera xadjust=(x-xp)*zratio; yadjust=(y-yp)*zratio; // PFlt(zratio);PFltComma(xp);PFltComma(xadjust);PFltComma(yp);PFltComma(yadjust);PRet(); struct3d[n]->coordinates[vp+v].x=xp+xadjust; struct3d[n]->coordinates[vp+v].y=yp+yadjust; if(struct3d[n]->coordinates[vp+v].x>struct3d[n]->xmax)struct3d[n]->xmax=struct3d[n]->coordinates[vp+v].x; if(struct3d[n]->coordinates[vp+v].x<struct3d[n]->xmin)struct3d[n]->xmin=struct3d[n]->coordinates[vp+v].x; if(struct3d[n]->coordinates[vp+v].y>struct3d[n]->ymax)struct3d[n]->ymax=struct3d[n]->coordinates[vp+v].y; if(struct3d[n]->coordinates[vp+v].y<struct3d[n]->ymin)struct3d[n]->ymin=struct3d[n]->coordinates[vp+v].y; } DrawPolygon(n, sortindex); } } Edited 2020-11-29 01:26 by matherp |
Bingo! You just put it in words in a way that made it go click in my mind. Yes, it is very much the case that projection hides faces. Faces are not visible because the face normal is (even slightly) towards the camera in 3 dimensions. Faces are visible because the angle between the face normal and the line of sight to the face is less than 90 degrees. You can solve this in two ways: 1) do the full 3D calculation - the cross product of two sides gives the face normal (make sure it's outward), then the sign of the dot product of this normal and a vector from the camera to the face (which can be the vector from the camera to any vertex of the face, or the centroid, if you choose) determines visibility. Since the dot product is given by the product of the magnitudes of the 2 vectors multiplied by the cosine of the angle between them, if the sign of the result is positive, then angle must be less than 90 degrees. 2) project the points onto the viewing plane first, then look if the projected points are clockwise or counter-clockwise. This can be done with a 2D cross product. Oh, now you've dialed it up! You either have to calculate clipping regions, because a nearer face can _partially_ cover a farther face, or rely on painters to do the partial obscuring for you. I'd suggest solving the face visibility first, then this may be fixed for free. That can't be. Something is wrong in the normal calculation. The normal can only be 0 if one of the vectors is 0. Visit Vegipete's *Mite Library for cool programs. |
I've gone through the C calcs manually and can't see any problems. Is that normalise function a standard library, or is there possibly a bug in it? normalise(&normals); |
Actually, the more I look at this, I don't think that the vector called "normals" has been normalised. normals.x=U.y*V.z-U.z*V.y; normals.y=U.z*V.x-U.x*V.z; normals.z=U.x*V.y-U.y*V.x; normalise(&normals); . . . if(f==7){ PInt(f);PFlt(ray.x);PFltComma(ray.y);PFltComma(ray.z);PFltComma(normals.x);PFltComma(normals.y);PFltComma(normals.z); } If those last three numbers are the normalised vector of vector "normals", there values squared and added together should approximate 1. At the point where the z goes positive we have the following values x: 0.6276 y:0.1203 z:0.0014 0.6276^2 + 0.1203^2 + 0.0014^2 = 0.39388176 + 0.01447209 + 0.00000196 = ~0.4 Edited 2020-11-29 04:33 by PeteCotton |
Got it |
Fantastic! |
Pete Do you have the coordinates for the Elite Spacestation that you fly into? Edited 2020-11-29 05:40 by matherp |
Sure. The Coriolis station. #VRML V2.0 utf8 Shape { geometry IndexedFaceSet { coordIndex [ 0, 1, 2, 3, -1, 0, 1, 5, -1, 0, 3, 4, -1, 0, 4, 8, 5, -1, 1, 2, 6, -1, 1, 6, 9, 5, -1, 2, 3, 7, -1, 2, 6, 10, 7, -1, 3, 4, 11, 7, -1, 4, 8, 11, -1, 5, 8, 9, -1, 6, 9, 10, -1, 7, 10, 11, -1, 8, 9, 10, 11, -1 ] coord Coordinate { point [ 160 0 160, 0 160 160, -160 0 160, 0 -160 160, 160 -160 0, 160 160 0, -160 160 0, -160 -160 0, 160 0 -160, 0 160 -160, -160 0 -160, 0 -160 -160, 10 -30 160, 10 30 160, -10 30 160, -10 -30 160 ] } solid FALSE } appearance Appearance { material Material { shininess 0.2 specularColor 1 1 1 diffuseColor 0.8 0.8 0.9 } } } All of the files are available in this .zip EliteShips.zip This file foramt is .wrl. It looks pretty easy to understand. I might write a wee conversion program tomorrow to read them and convert them in to CMM2 3D objects (I am running around today). |
Nasty. Some of the data is comma delimited, some is space delimited. That's just evil. Visit Vegipete's *Mite Library for cool programs. |
On the bright side, 3D Builder, which is built in to windows 10, can open these VRML files with a double-click. FreeCAD, available for windows, mac and linux, can also natively open them. Both of these programs make it easy to view this file type. I suppose it makes sense that the VRML format be the default 3d file format. "draw3D load #n, filename$" perhaps? Visit Vegipete's *Mite Library for cool programs. |
I have hacked together a very rudimentary .WRL loader. And when I say hacked - I do mean hacked. The code is a mess. I will re-write it with some nice string handling functions - this was really just cut#1 to get it working. The data seems to be loaded in to the 3D object okay, but some of the faces are missing. I suspect that maybe they aren't all in right hand notation after all? Or is this possibly the face removal bug matherp found earlier? Either way, it's 12.45am and I need my beauty sleep. I will look at it again tomorrow. Like I say, don't judge me on the horrible state of this code - it will be much cleaner once I am happy it is working. option explicit option default float dim integer camera_y = mm.vres-20 dim integer viewplane = 700 dim integer camera_z = 0 dim integer camera_x dim integer c,t,s timer=0 dim q(4) dim yaw=rad(1),pitch=rad(2),roll=rad(0.5) DiskRead(1,"..\EliteShips\coriolis.wrl") draw3d camera 1,viewplane,camera_x,camera_y,camera_z 'gui cursor on 1,40,camera_y page write 1 for c=0 to 7200 camera_x=c+40 draw3d show 1,mm.hres\4,mm.vres\2,1000' math q_euler yaw,pitch,roll,q() draw3d rotate 1,q() ' rotate this object # inc yaw,rad(0.1) ' inc pitch,rad(2) ' inc roll,rad(0.5) page copy 1 to 0,b next page write 0 print 720000/timer draw3d close all end sub DiskRead(objNum as integer, filename as string) local string dataLine$, a$, vert$, face$ local integer readingVertices=0 local integer readingFaces=0 local integer t,j local integer temp, faceCount,VertCount, index1, index2, index3 'Pass 1 get the data out of the file and in to vert$ and face$ open filename for input as #1 do while not eof(1) line input #1,a$ a$=Trim$(a$) ' Get rid of any leading or trailing spaces ' strip all formatting out of input line dataLine$="" for t=1 to len(a$) if asc(mid$(a$,t,1))>=32 then dataLine$=dataLine$ + mid$(a$,t,1) next t if left$(dataLine$,10)="coordIndex" then readingVertices=0:readingFaces=1 if left$(dataLine$,16) = "coord Coordinate" then readingVertices=1:readingFaces=0 if left$(dataLine$,1)="]" then readingVertices=0:readingFaces=0 if left$(dataLine$,1)="-" or (asc(left$(dataLine$,1))>47 and asc(left$(dataLine$,1))<58) then ' This line starts with a number if readingVertices=1 then vert$=vert$+dataLine$ if readingFaces=1 then face$=face$+dataLine$ endif loop close #1 'vert$ is 3 points seperated by spaces. Each 3 points are then seperated by a comma ' count the nuber of verts for t=1 to len(vert$) if mid$(vert$,t,1)="," then vertCount=vertCount+1 next t vertCount=vertCount+1' The last item does not have a comma - so compensate for that ' face$ uses 4 or 5 numbers seperated by commas. -1 is used as the terminator ' Count the number of -1's to give us the face count for t=1 to len(face$) if val(mid$(face$,t,2))=-1 then temp=temp+1 next t faceCount=temp 'load the face$ and vert$ data in to our 3D object local float v(2,vertCount-1) index1=0 index2=0 a$="" for t=1 to len(vert$) if mid$(vert$,t,1)="," then v(index2,index1)=val(a$):index1=index1+1:index2=0:a$="" ' New vertice next else if mid$(vert$,t,1)=" " then v(index2,index1)=val(a$):index2=index2+1:a$="" else a$=a$+mid$(vert$,t,1) end if next t v(index2,index1)=val(a$) ' be sure to catch the last value as it's not ended with a comma local string faceData(faceCount-1) local integer fc(faceCount-1) index1=0 ' position in array faceData() and fc() index2=0 ' face count a$="" for t=1 to len(face$) if mid$(face$,t,1)="-" then 'end of this group t=t+1 'this is really naughty- but I'll fix it in a later rev faceData(index1)=a$ fc(index1)=index2 index1=index1+1 index2=0 a$="" else if mid$(face$,t,1)="," then if a$<>"" then index2=index2+1:a$=a$+"," else a$=a$+mid$(face$,t,1) endif next t local integer bcol(faceCount-1) for t=0 to faceCount-1 bcol(t)=rgb(100+rnd*155,100+rnd*155, 100+rnd*155) next t local integer fv(math(sum fc())-1) index1=0 ' position in array fv() a$="" for t=0 to faceCount-1 a$="" for j=1 to len(faceData(t)) if mid$(faceData(t),j,1)="," then fv(index1)=val(a$) a$="" index1=index1+1 else a$=a$+mid$(faceData(t),j,1) endif next j next t draw3d create objNum, vertCount, faceCount, v(), fc(), fv(),bcol(),bcol() end sub function LTrim$(a$) LTrim$=a$ do while instr(" ", left$(LTrim$,1)) LTrim$=Mid$(Ltrim$,2) loop end function function RTrim$(a$) RTrim$=a$ do while instr(" ", right$(RTrim$,1)) RTrim$=Mid$(Rtrim$,1,len(RTrim$)-1) loop end function function Trim$(a$) Trim$=RTrim$(LTrim$(a$)) end function |
LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 445 |
Very cool Peter. Concave faces should be resolved with Painter or Z-buffer. I'm still working on the camera example but I do not have a lot of time to work on it because I'm studying for a certification exam. How are you thinking to implement the camera? |
Page 11 of 11 |
