JAQForum Ver 20.06
Local Time 05:39 27 May 2024 Privacy Policy
Forum Index : Electronics : Siglent ISFE Isolated Front End module
Posted: 06:29am 30 Dec 2023
1% is quite good. You must be using quality resistors.
To get closer try 8.72k... or is it 8.88k? One or the other should do it ;)
Edited 2023-12-30 16:43 by phil99
gaspo
Posted: 07:06am 30 Dec 2023
  phil99 said  To get closer try 8.72k... or is it 8.88k?
Next time I'll be ordering from LCSC I'll get some more values from E48/E96 range.
It is good enough for now.
pd--
Posted: 03:00am 07 Jan 2024
Hi gaspo
i am about to make a couple of probes my self and was wondering on the power consumption.
The documentation seas 50ma witch is probably a bit high for a 9v battery.
Any recommendations on weather i should yous 2 x 18650's or a 9v battery is ok
thanks
gaspo
Posted: 06:59am 07 Jan 2024
I recorded a current of approximately 53mA, and with a discharge rate of 50mA, the Duracell 9V battery would only sustain this for approximately 8 hours.
Alternatively, opting for 2x 18650 batteries in series would provide a duration of over 100 hours, or utilizing a 9-12V wall adapter is also a viable option.
© JAQ Software 2024
