Forum Index : Microcontroller and PC projects : ESP8266 AT support in MMBasic
Page 2 of 3 | |||||
Peter Have a look here *Custom Compiled ESP-AT Firmware Binaries* It has links for a simple ESP flash tool with instructions and there is only 1 binary to flash This is the espress gitgub page with more information including the roadmap These are the AT commands ***The next version of ESP-AT firmware (v2.4.0.0) is planned to be released in March 2022. At present, only ESP32-C3 series firmware is planned to be released, and ESP32-C3 firmware would support Bluetooth LE 5.0.*** This should do what everyone wants? and be easy enough to use? And once it's flashed it can be updated over the air {if neeeded} Edited 2022-01-20 19:08 by lew247 |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8569 |
MQTT seems to be missing Edited 2022-01-20 19:27 by matherp |
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3496 |
@lew247 The ESP family is like the raspberry pi (not pico, but pi0,1,2,3,4) as they are platforms that are widely under development (and change). That is why it may be better to NOT allow things like updates over the air. With the update over the air the ESP may become inoperable from MMBasic. That is why it may be best to write the pre-made image from MMBasic (and not through some PC tooling) since you have better control over what software is running on the ESP. If you suggest PC tooling, even if you stipulate "use 1.7.4" people will put the latest firmware on to it, and Peter is constantly debugging why person X has a problem. That was also the death of PicRomite. The constant change of the Raspberry Pi platform. Uderstand why Peter is hesitant to implement ESP. I hope this clarifies, Volhout PicomiteVGA PETSCII ROBOTS |
That was precompiled binaries and the information on their page This is the MQTT AT Commands AT+MQTTUSERCFG: Set MQTT user configuration AT+MQTTCLIENTID: Set MQTT client ID AT+MQTTUSERNAME: Set MQTT username AT+MQTTPASSWORD: Set MQTT password AT+MQTTCONNCFG: Set configuration of MQTT connection AT+MQTTALPN: Set MQTT Application Layer Protocol Negotiation (ALPN) AT+MQTTCONN: Connect to MQTT Brokers AT+MQTTPUB: Publish MQTT Messages in string AT+MQTTPUBRAW: Publish MQTT messages in binary AT+MQTTSUB: Subscribe to MQTT topics AT+MQTTUNSUB: Unsubscribe from MQTT topics AT+MQTTCLEAN: Close MQTT connections MQTT AT Error Codes MQTT AT Notes Full AT command set This page has the official EspressIF binaries for the various ESP chips along with the flashing tool Edited 2022-01-20 20:14 by lew247 |
This is the MQTT AT Commands They have to be compiled into the binary otherwise they aren't there. Without a major amount of work it seems impossible to know what is included in who's local build and Expressif (possibly deliberately) have clearly broken the ESP-01(S) This is my last post on this issue I'm not pursuing it further and not including support in any port of my ports of MMbasic, too messy and too chaotic - sorry Lewis |
They have to be compiled into the binary otherwise they aren't there. Without a major amount of work it seems impossible to know what is included in who's local build and Expressif (possibly deliberately) have clearly broken the ESP-01(S) This is my last post on this issue I'm not pursuing it further and not including support in any port of my ports of MMbasic, too messy and too chaotic - sorry Lewis I totally understand, but for anyone interested I found this Which tells you how to simply and easily make your own binary with only the actual modules you need using the NODEMCU page HERE You simply select which branch you want to build your binary from, select and it builds it for you online. The 512K branch is for the ESP8266-01 with memory of less than 1Mb (most of the early ones released) This is the full list of modules you can select, you just pick the modules you want It might be of use to anyone that has or wants to use any of the ESP modules from 8266, 8285, esp32 wifi mqtt (still no idea what that is) or other things This way you're using your own binary that has only the actual modules you want/need in it The only issue is it doesn't use the AT command set but is NODEMCU it seems easy to use but I can't say, it does however look like sending commands to it from any MM device would be really simple Programming Model The NodeMCU programming model is similar to that of Node.js, only in Lua. It is asynchronous and event-driven. Many functions, therefore, have parameters for callback functions. To give you an idea what a NodeMCU program looks like study the short snippets below. For more extensive examples have a look at the /lua_examples folder in the repository on GitHub. -- a simple HTTP server srv = net.createServer(net.TCP) srv:listen(80, function(conn) conn:on("receive", function(sck, payload) print(payload) sck:send("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1> Hello, NodeMCU.</h1>") end) conn:on("sent", function(sck) sck:close() end) end) -- connect to WiFi access point wifi.setmode(wifi.STATION) wifi.sta.config("SSID", "password") -- register event callbacks for WiFi events wifi.sta.eventMonReg(wifi.STA_CONNECTING, function(previous_state) if(previous_state==wifi.STA_GOTIP) then print("Station lost connection with access point. Attempting to reconnect...") else print("STATION_CONNECTING") end end) -- manipulate hardware like with Arduino pin = 1 gpio.mode(pin, gpio.OUTPUT) gpio.write(pin, gpio.HIGH) print(gpio.read(pin)) |
lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3010 |
Those are useful links, Lew--thanks for researching and posting. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
flasherror Senior Member Joined: 07/01/2019 Location: United StatesPosts: 159 |
I have built NodeMCU binaries a few times at various times using the online builder and never got it to work reliably despite trying different ESP8266 modules etc. Lots of crashes/reboots. Same hardware was rock solid using Arduino IDE so I gave up on NodeMCU. I think the NodeMCU firmware overhead was too much for a resource limited device like the 8266. I was looking for a tiny ESP32 module with through hole header pins like the ESP01 but couldn't find one. Is there a ESP32 version of ESP01? Edited 2022-01-21 03:53 by flasherror |
bigfix Senior Member Joined: 20/02/2014 Location: AustriaPosts: 124 |
Posted this accidently in the SPI thread - better fit here Another interesting SW option for ESP8266 is Tasmota Tasmota GitHub Tasmota getting started It started as an alternative SW for some chinese Sonoff WIFI actuators In the meantime it became a very powerful and flexible SW for ESP8266 and ESP32 I use it on a relay board to control my gardensprinklers via a WEB IF and some timers Since I installed it 10 month ago, it did not have a single problem I use a free Android App to interface to the API, but the WEB IF also works fine Being lazy, I bought preflashed units from Athom - everything worked fine so far (You need to specify Tasmota as SW when ordering) Athom Ali Store Besides WEB IF & API it fully supports MQTT and a serial command IF It can act as a MQTT to serial bridge, I am not sure about serial to MQTT function But about everything is possible by issuing commands to the serial console So it could be interesting as a WEB & MQTT frontend to a mite Edited 2022-01-25 04:39 by bigfix |
8266 seems not in their shop anymore. I guess it is phasing out everywhere. Volhout PicomiteVGA PETSCII ROBOTS |
Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 5707 |
Could just be the general silicon shortage. There still seems to ba a lot on ebay. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Been experimenting with my Raspberry Pi - Picomite combination. Raspberry Pi (could be a Pi Zero W)running Node-Red works extremely well parsing HTTP "Get" to APIs in this case OpenWeatherMap. This makes all types of Network/Internet comms possible (HTTP, MQTT, UDP ) etc. In this case I did a HTTP request to OWM as a 7 Day Forecast request and I have just selected a few nodes to send to the Pico. Here is screenshot of the "Flow" (Node-Red speak) and the received data on the Pico. Edited 2022-01-26 18:33 by MikeO Codenquilts |
That's so pretty - but completely beyond my comprehension. :) I may have to go and lie down in a darkened room now... Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
georgestheking Newbie Joined: 21/12/2021 Location: BelgiumPosts: 20 |
Hi, I think the best is select a specific hardware and select and publish a firmware. For example ESP01S with firmware X.X. ( link for download ) To be sure that everybody use the same peripherical with the same firmware. Then you can add a library into picomite. That is only my advice, Georges |
For example ESP01S with firmware X.X. ( link for download ) To be sure that everybody use the same peripherical with the same firmware. Then you can add a library into picomite. Fully agree - download should be "frozen" and longterm available on a MMite site |
That's fine, not advocating, just suggesting as others had done, until someone writes such universal code for suitable hardware, there are other ways that may suit as a solution for some situations. Cheers, Mike Codenquilts |
ESP8266 flashed with the AT command set From what I can see it has the full AT command set installed IF I can find an ESP8266 and a programmer I'll try flashing it with the firmware which can be downloaded here and see what commands actually are installed This firmware is for the 1MB and doesn't support OTA This image is for the larger ESP8266-12 I think I might have got rid of the programmer though so if anyone else has an ESP8266 and actually wants to try it? For those with the 512K esp8266 here's a link to the last version of Espressif's 1.74 binary for that one |
thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 3833 |
@lew247, sorry to hijack the thread, but did you see my email reply yesterday? Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
It's the same support problem, isn't it? They put up version 2.2.0 binaries, but where's the command list? It would have been easy to include that on Github - after all, someone put the binaries there. Why should the user have to try every possible combination of every command to see if it works? What about new commands that weren't in previous versions? How do we know they are there? Do these people not care about their users? We know the Cytron AT commands aren't exactly Hayes compatible in some ways, but in *what* ways? This *may* help: https://drive.google.com/file/d/1zrOoTNiCZ-GEth75b6xNpIUiE0UkjG61/view Edited 2022-01-26 23:00 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Fully agree. One of the key requirements is MQTT is it included? Nowhere is there any useful information. Makes me appreciate even more Geoff's wonderful manuals |
Page 2 of 3 |
