Forum Index : Microcontroller and PC projects : New version of PicoMite/PicoMiteVGA V5.07.03
Page 1 of 3 ![]() ![]() |
matherp Guru ![]() Joined: 11/12/2012 Location: United KingdomPosts: 6225 |
The 5.07.03 firmware is now released and available on Geoff's site together with the updated manual covering both versions Warning: Loading these binaries will automatically wipe all flash the first time loaded so back up anything important first (clear_flash not necessary). This takes a few seconds before you will get the USB connection. https://geoffg.net/Downloads/picomite/PicoMite_Firmware.zip Changes from V5.07.01 - see the manual for full details General changes PicoMiteVGA introduced - see manual for details Program now runs from flash memory freeing up much more memory Maximum program size now 124Kbytes (108 for VGA version) Flash slots reduced from 10 to 7 (8 for VGA version). FLASH RUN and FLASH CHAIN now execute direct from the specified flash slot without changing the main program Support for a PS2 Keyboard added Significant performance tuning Improved USB console receive Increased the maximum display width in OPTION DISPLAY to 240 characters Enables F1 as a user programmable function key Implements support for SSD1963 parallel displays Support for 240x240 round GC9A01 display Reduces maximum file name length to 63 characters but increases maximum files that can be listed with FILES command to 1000 Increases drive level for SDcard output pins (CS, MOSI and CLOCK) New font added FONT 8 is a very small 6x4 font useful for 320x240 screens OPTION MEMORY removed as no longer relevant OPTION BAUDRATE n now sets the baudrate for when a serial console is used AUTOSAVE can now be terminated by entering Control-Z or F1 which will then cause the received data to be transferred into program memory overwriting the previous program. Use F2 to exit and immediately run the program. Reading from the framebuffer now available and bug fixed on SSD1963, ILI9341, ST7789_320 and ILI9488 This enables the following on these displays: PIXEL(x,y) function SAVE IMAGE command Transparent text BLIT Bug Fixes and functional corrections Various bug fixes to CSUB code, new header files for CSubs Fixes bug in ON KEY keyno,int Fixed memory leak caused by ctrl-C out of FILES command Fixes bug in loading F6-F9 user function definitions Fixed bug in PWM timings Fixes a bug where LINE INPUT would not read the last line in a file if it was not terminated with a CR Fixes bug in cursor positioning in editor Fixed bug in error message when an invalid flash page is selected Fixes bug in day$(now) function Fixes bug where writing text to an SPI LCD that overlapped the bottom of the screen would fail to de-assert LCD_CS Fixes bug that added an extra space after a REM command each time the program was edited. Fixes bug in BACKLIGHT 0 Fixes bug in using SYSTEM I2C or I2C2 for general I2C use if I2C READ does not use a string as the variable. Fixes bug in COM1 where buffer overrun is losing characters. Tidied up system response when OPTION LCDPANEL has an error Change to DIR$() function to allow use with a single parameter as specified in the manual Changes to FILE command to properly deal with relative paths from a sub-directory New or enhanced commands and functions LOAD JPG fname$ [,xleft%] [,ytop%] FORMAT$() FLUSH [#]filenumber INTERRUPT [myint] OPTION KEYBOARD nn [,capslock] [,numlock] [repeatstart] [repeatrate] PRINT @(x, y [,mode]) OPTION LCDPANEL CONSOLE [font] [,foregroundcolour] [backgroundcolour] [backlight] OPTION LCDPANEL NOCONSOLE POKE DISPLAY command [,data1] [,data2] [,datan] SETPIN pinno,CIN [,change] SETTICK PAUSE, myint [,tickno] SETTICK RESUME, myint [,tickno] FLASH LIST no [,all] FILES [fspec$] [, sort] POKE DISPLAY HRES n POKE DISPLAY VRES m Edited 2022-01-19 21:08 by matherp |
Geoffg![]() Guru ![]() Joined: 06/06/2011 Location: AustraliaPosts: 2953 |
Another tremendous job by Peter. Especially the PicoMiteVGA version which gives you a modern day Maximite for just a few dollars. Just amazing. Geoff Edited 2022-01-19 21:56 by Geoffg Geoff Graham - http://geoffg.net |
JohnS Guru ![]() Joined: 18/11/2011 Location: United KingdomPosts: 2777 |
Very impressive! John |
thwill![]() Guru ![]() Joined: 16/09/2019 Location: United KingdomPosts: 2524 |
Very impressive. I look forward to getting my PicoMiteVGA built. Creaky old text adventures anyone? Best wishes, Tom CMM2 Welcome Tape, Creaky old text adventures |
Mixtel90![]() Guru ![]() Joined: 05/10/2019 Location: United KingdomPosts: 2443 |
Definitely, Tom! In green. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs |
hitsware2![]() Guru ![]() Joined: 03/08/2019 Location: United StatesPosts: 531 |
+ 1 kazillion ![]() http://www.hitswares.com/ |
gadgetjack Regular Member ![]() Joined: 15/07/2016 Location: United StatesPosts: 67 |
I have built both of these and am quite impressed with what they can do. Still fighting to get some of the games to run on them , but that is my own lack of skill in converting them. Keep up the great work !!! |
ztoti Regular Member ![]() Joined: 27/10/2011 Location: CanadaPosts: 65 |
I've built all versions, start with the first Maximite but this PicoMite version is so amazing. Thank you guys for your tremendous efforts. Edited 2022-01-20 04:39 by ztoti |
cosmic frog Senior Member ![]() Joined: 09/02/2012 Location: United KingdomPosts: 221 |
Brilliant! The PicoMite is like the Swiss Army Knife of Mites. ![]() Dave. |
Turbo46![]() Guru ![]() Joined: 24/12/2017 Location: AustraliaPosts: 1011 |
Does that mean that you are going to modify SAAINT to run on this? Bill Keep safe. Live long and prosper. |
Yes, eventually. I tried early on but there were some file-handling differences between the CMM2/MMB4L vs. the PicoMite and because I couldn't run my unit-test framework on the PicoMite to pin those down I instead parked the idea on the back-burner. I'll revisit soon, hopefully the file-handling differences have *magically* vanished. If not then I'll have to make a decision between a one off, by-hand hack or of the more sustainable longterm process of getting my unit-test framework running (by transpiling tests on MMB4L and then running them remotely on the PicoMite). Of course if I provided him with a transpiled but non-working version of SAAINT then Peter if so inclined would probably fix it in half an hour and tell me I was making a mountain out of a mole-hill, and he is probably correct. Best wishes, Tom CMM2 Welcome Tape, Creaky old text adventures |
As long as that? Well I suppose ZMIM was written with running on the CMM1 in mind after being transpiled, but SAAINT was written purely for the CMM2 as far as I know. Bill Keep safe. Live long and prosper. |
He might want to make a cup of tea. Correct, Z-MIM targeted the CMM1 which is a common ancestor of both the CMM2 and PicoMite and thus there was probably very little for Peter to do to make Z-MIM "work" on the PicoMite. "work" being quoted because it is too slow to be playable, that will hopefully not be the case for SAAINT which has a much simpler runtime. Best wishes, Tom Edited 2022-01-20 20:21 by thwill CMM2 Welcome Tape, Creaky old text adventures |
Pity about Z-MIM, but I suppose there's no substitute for real Grue-power. :( Still, I have the necessary hardware. :) Going to fix the keyboard connector on my PicoMite VGA mini V1.0 very soon. Then I can have a proper play on it. I've not had a go with the VGA software yet, just seen it power up and change to colour mode and back. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs |
Currently Z-MIM instruction dispatch uses large CMM1 compatible If ... ElseIf ... ElseIf ... ElseIf ... EndIf blocks. I am hopeful that, user function slots permitting, changing that to use CALL may make the VM fast enough to be playable. Failing that some judicious use of CSUBs will do the job. Best wishes, Tom Edited 2022-01-20 22:56 by thwill CMM2 Welcome Tape, Creaky old text adventures |
Yay! Keyboard now working on the mini too. Now for the SDcard and RTC. The PicoMite VGA is really cool... Thanks again for all your hard work, Peter! :) EDIT: Even better - it works with one of the uSD cards that I was having problems with a while ago. The RTC is working too. With the exception of the PS/2 connector screw up (which I knew about before the boards arrived - some links fixed that) everything on this little PCB has worked first time. I must remember to put bigger holes for 1N4004 leads though. lol EDIT EDIT: Is OPTION DEFAULT FONT 8 supposed to work when editing in colour mode? Also, it's not accepted in colour command mode. These might be correct - I've not been keeping up with the VGA version very well. Edited 2022-01-21 05:56 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs |
mobluse![]() Newbie ![]() Joined: 10/02/2013 Location: SwedenPosts: 24 |
I first installed PicoMiteVGAV5.07.03.uf2 and that worked well, and after setting options for SDCARD and Audio e.g. aritm.bas worked. Then I installed PicoMiteV5.07.03.uf2, but then the terminal wouldn't connect. I had to use Clear_flash.uf2 from PicoMite_Beta.zip with PicoMiteV5.07.03RC10.uf2, then install PicoMiteV5.07.03.uf2 again, and then it worked to connect, and also aritm.bas worked. I have noticed that PicoMite_Beta.zip is empty now, but I guess you could use Clear_Flash.uf2 from PicoMite_Firmware V5.07.02.zip which is still possible to download from https://geoffg.net/Downloads/picomite/Archive/. I have a program "options.bas" on the SD card that sets the options for my board: ' Options for board Maker Pi Pico Rev1.2 by Cytron. On error skip 2 Option SDCARD GP15, GP10, GP11, GP12 Option Audio GP18,GP19 Option COLOURCODE ON Option F1 "FILES"+Chr$(13) I have to set the Option SDCARD manually. The line is there just in case I forget, because then I can read the FAT32 SD card in some other device and see the line. In Linux I use minicom version 2.7.1 to connect: minicom --device /dev/ttyACM0 --color=on Thank you Peter for making this! Edited 2022-01-22 05:24 by mobluse Maker Pi Pico Rev1.2, DuinoMite-Mini, Raspberry Pi 0-4, iCE40HX8K, Arduino Uno, VM111, STK500, ZX81 |
In the PicoMite User Manual it says on p. 149: GPIO pins GP21, GP22, and GP26 are reserved to drive the VGA display in monochrome mode. In addition pins GP18, GP19 and GP21 are also not available in MMbasic when in colour mode. GP21 is mentioned twice. According to the diagram on p. 150, GP16 and GP17 are also used, but GP19 is not connected, but I guess GP19 should perhaps be connected to the cross by VR1. Maker Pi Pico Rev1.2, DuinoMite-Mini, Raspberry Pi 0-4, iCE40HX8K, Arduino Uno, VM111, STK500, ZX81 |
There's been a mix up between pin numbers and GP numbers in the manual. I *think* I've got these right... These are needed for mono: Pin 21 (GP16) is Hsync Pin 22 (GP17) is Vsync Pin 26 (GP20) is green(H) These are the additional pins for colour: GP18 (Pin 24) is blue GP19 (Pin 25) is green(L) GP21 (Pin 27) is red Edited 2022-01-22 06:10 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs |
Yes, your pinouts are correct. I have updated the manual which should be re-downloaded from https://geoffg.net/picomite.html. Clear your browser cache first. Geoff Geoff Graham - http://geoffg.net |
