Forum Index : Microcontroller and PC projects : Maximite Basic for the Raspberry PI?
Author | Message | ||||
aargee Senior Member ![]() Joined: 21/08/2008 Location: AustraliaPosts: 251 |
Geoff, This might be quite difficult, but seeing how you've got a DOS version, how hard would MM Basic on the Raspberry Pi be? It would be a killer application!! - Rob. For crying out loud, all I wanted to do was flash this blasted LED. |
vasi![]() Guru ![]() Joined: 23/03/2007 Location: RomaniaPosts: 1697 |
Options for BASIC language in linux: 1. http://www.basic256.org/index_en 2. http://sourceforge.net/projects/sdlbasic/ 3. http://www.bwbasic.at/info.htm 4. http://gambas.sourceforge.net/en/main.html VisualBasic approach - probably others... MMBasic for DOS can be run in Linux with DOSBox (full screen if you want) emulator. All these can be found in an Ubuntu repository. Of course, don't know if all are available (should be, considering the target of rPI) for Raspberry PI... Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
