Forum Index : Microcontroller and PC projects : "The Most Basic Basic Computer"
Page 2 of 2 | |||||
marcwolf Senior Member Joined: 08/06/2009 Location: AustraliaPosts: 119 |
Essentially. in the end - every computer language is Binary :) It's just the steps one takes to get there. Coding Coding Coding.. Keep those keyboards coding.. RAW CODE!!!!! |
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 9083 |
Good point! Smoke makes things work. When the smoke gets out, it stops! |
Actually - one of my favourites comments re troublesome computers is... "Grasp power cord firmly in both hands and execute a Non-Maskable Interrupt" Problem is I having to explain what a NMI is more and more :) Coding Coding Coding.. Keep those keyboards coding.. RAW CODE!!!!! |
It is what the TRS-80 used for a RESET (jumped to address 66 -- I think) Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Oh I know what it means.. but most people around computers don't know assembly language or OP Code terms :) It's a humorous line along the terms of "Try and MASK That you Bugger" *YANK* Usually followed by a little ORAC type Whine :) Coding Coding Coding.. Keep those keyboards coding.. RAW CODE!!!!! |
plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
NMI Rulezt ! |
I didn't realise H-A-D or jack were the way mentioned and left a brief comment a few days ago correcting his "facts" and pointing out I'm the author of the programmer and it's in C, but I see it's not been published. That itself says something very bad about H-A-D. John |
Page 2 of 2 |
