Subject Topic: E100 - Version 1D... Post ReplyPost New Topic
Page of 3 Next >>
Posted: 21 November 2017 at 12:23pm | IP Logged Quote Grogster
Version 1A was the prototype - only a few people have that one.
Version 1B was the first official release - most people have that one.
Version 1C adds the on-board 1455 USB interface.
Version 1D will have the 1455 also, but I am planning to get rid of the footprint for the CP2102 USB-serial module(which is optional anyway), and also planning to discontinue CON6, which is the standard console pins, because these are now directly connected to the 1455 USB interface, so there should be no need to have them anymore, as the console now effectively has become a native USB connection as standard now on any MM using the 1455 chip.
Do any of the members here have any major problems with that concept?
Posted: 21 November 2017 at 1:57pm | IP Logged Quote WhiteWizzard
Hi Grogs,
Three things to run past you for consideration:
1> Can you please remove the LED colour names from the silkscreen!
2> Is it worth adding a uSD socket (as with the SC version of this PCB)? Then you can loose the SD header (CON10 I think it is?)
3> Any chance of making it double layer rather than 4-layer? (just asking!)
Cheers buddy.
WW
Posted: 21 November 2017 at 2:24pm | IP Logged Quote Grogster
#1 - I added them cos I was always forgetting which LED went where. Why do you want them removed?
#2 - Not a silly idea. I will look into it.
#3 - Not a chance in Hell.
Posted: 21 November 2017 at 6:13pm | IP Logged Quote WhiteWizzard
I do not like using red LEDs to indicate power (prefer to use them more for 'warnings' - just a silly thing I have).
I like to use green or blue to indicate Power ON). The sequence that works well on the E100 is a traffic like (i.e. from top: Red, Yellow, Green). I still supply assembled E100 units in this sequence but often get customers tell me I put the LEDs the wrong way round!!
I guessed that would be your 'polite' answer (but it would massively reduce PCB cost). As the leading PCB expert here, are you sure you don't want this PCB challenge?
Edited by WhiteWizzard on 21 November 2017 at 6:15pm
Posted: 21 November 2017 at 6:16pm | IP Logged Quote Grogster
#1 - Ahhhh. I see what you mean now. Fair enough. I would still like to label them, so I will label them as you suggest. Satisfactory?
#2 -
#3 - I like a challenge, but that is impossible. If you are making a custom board, then two-layer IS quite pissable, but as the E100 has so many features on it, four-layer.....C'est La Vie....
Posted: 21 November 2017 at 6:21pm | IP Logged Quote WhiteWizzard
#1 - make sure you don't turn the PCB 180deg when relabelling! Yep - very satisfied
#2 - uSD ok then, or not yet attempted?
#3 - I understand - but worth asking . . .
Posted: 21 November 2017 at 6:34pm | IP Logged Quote Grogster
IN BRUGES wrote:
#1 Why aren't you in when I *** told you to be in. #2 Why doesn't this hotel have phones with **** voicemail and not I have to leave messages with the **** receptionist. #3 You'd better **** be in tomorrow night when I **** call again, or there'll be **** hell to pay, I'm **** telling ya. - Harry.
Sorry - just HAD to get that in there.
#1 - OK.
#2 - Not done yet, but agree with your big-grin.
#3 - On the E100, just not really possible, with I/O lines going everywhere.
jman
Posted: 21 November 2017 at 7:17pm | IP Logged Quote jman
Just my 2 cents worth I would prefer to keep the standard console pins this way the board is usable with OR without the 1455 (The CP2102 should be removed)
Jman
Back to Top View jman's Profile Search for other posts by jman
Posted: 21 November 2017 at 7:29pm | IP Logged Quote WhiteWizzard
It would be useful to have a feature to 'disable' the PIC1455 when not required (to minimise current draw).
I have spoken to Peter about this and he implied to put a link in the 0v line to the PIC. I think it may still see a route to Ground through the other connections to the PIC1455 so am not yet convinced it will draw zero power with just a GND link.
On that basis - I agree with man to leave in the three basic console connections (GND, Rx, Tx)
Posted: 22 November 2017 at 11:10am | IP Logged Quote robert.rozee
the 1455 draws about 10mA, how does this compare with the other stuff on an E100 board?
i'd really not recommend lifting the ground pin of the 1455. a far safer approach would be to socket the 1455 (ie, use a DIP version). alternatively, discuss with peter ways for the 1455 to be persuaded into a low-power sleep mode. this could be signalled, for instance, by having the mode/select pin held low at powerup - a simple jumper across the select switch would then suffice. this would, of course, require a modification to the 1455 firmware, and is dependant on such a change even being possible.
we are currently on version 1.18, with an upgrade fairly straightforward as just about all the 1455s out there included the ds30 bootloader. it would be a useful upgrade for E-28 boards too, as they have a couple of pads right next to each other for mode/select and ground.
rob :-)
MicroBlocks
Posted: 22 November 2017 at 11:10am | IP Logged Quote MicroBlocks
Power the 1455 from USB only, then only when the USB is plugged in it will draw power.
MicroBlocks
Posted: 22 November 2017 at 11:13am | IP Logged Quote MicroBlocks
That is not a cue for members to start suggesting flux capacitors and time circuits.......
He, did Grogster post in the future? (Or did i go back in time?)
Page of 3 Next >>
