Subject Topic: Multiple Microbridges on one Computer Post ReplyPost New Topic
Page of 2 Next >>
kg4pid
Posted: 06 December 2017 at 7:38am | IP Logged Quote kg4pid
Would there be any problems using more than one microbridge on one system? Linux or Windows. Not for programming but for USB to Serial. Are all microbridges going to have the same serial number? I've had problems with some of the cheap USB to Serial converters over the years changing ports. I want to make sure my ports stay the same across reboots. My 16F1455 chips are on order but haven't shipped yet so I can't do any testing.
Thanks in advance, Max
Back to Top View kg4pid's Profile Search for other posts by kg4pid
Online Status: Online
Posted: 06 December 2017 at 8:14am | IP Logged Quote Grogster
I don't see any reason why not. Try it and see. Windows will assign a VCP COM port number to any new USB-serial adaptor you plug in, even if one of exactly the same type is still plugged in. Therefore, if one you have plugged in was COM4 for example, you could plug in another one, and windows SHOULD assign a new COM port number to that - say COM5 or something. I have often had multiple CP2102 USB-serial adaptors plugged in at the same time, and windows does not care - it just issues another COM port number.
Linux should have no issues at all. It should just show up as a duplicate folder under /dev/ if you already have one plugged in and working.
On Linux, provided Linux sees them at all, you are less likely to have the changing port numbers problem. Windows loves to change COM port numbers on you all the time, depending on what it thinks you have plugged in and where. I think there is a system setting you can change to force Windows to NOT assign COM port numbers higher then a certain point, but that still means the actual number a USB-serial adaptor gets assigned by Windows is at the discretion of the operating system - it's a pain, actually, to be honest.
kg4pid
Posted: 06 December 2017 at 10:07am | IP Logged Quote kg4pid
Most higher quality USB devices have a unique serial number which allows you to use two or more of the same type of device on a system. But not all USB devices are created equal. As I already stated I can't test yet bcause my parts are in shipment. If I know for sure one way or the other I can plan ahead. Since there is only one hex file I have a feeling it may be a problem, unless it is in the chip itself. I couldn't find anything in the 16F1455 datasheet that said for sure.
Max
Posted: 06 December 2017 at 10:35am | IP Logged Quote Grogster
I will plug in several E28's all of which use the 1455 chip, and let you know.
I am still not expecting a problem, but you may in fact be correct so I will post back shortly.
EDIT: Plugged in two E28's and one MMX all with 1455 chips. All running at the same time, all of which were assigned unique COM ports, and I can talk to all of them. Here is a shot of my accessing two different 1455 projects at once:
Edited by Grogster on 06 December 2017 at 10:45am
MicroBlocks
Posted: 06 December 2017 at 10:46am | IP Logged Quote MicroBlocks
Should not be a problem.
The first part that is used to identify one is the VID/PID.
After that a serial number.
If those are the same (which is often) then it will be enumerated according to which USB port it is connected to.
If you have a USB-HUB it will also use that as part to uniquely identify it.
kg4pid
Posted: 06 December 2017 at 10:47am | IP Logged Quote kg4pid
On page 10 of the MCP2200 datasheet it says 2.2 "The MCP2200 is supplied from the factory with a serialied USB serial string."
Itn't the MCP2200 the same chip with simular code? Was this the code that was used and modified to create the microbridge?
Max
kg4pid
Posted: 06 December 2017 at 10:52am | IP Logged Quote kg4pid
If I understand you correctly I'll be ok as long as I don't move them to a different USB port.
My FTDI USB to serial converters don't do that, they stay the same. But they cost a whole lot more.
Max
kg4pid
Posted: 06 December 2017 at 11:58am | IP Logged Quote kg4pid
Grogster, try moving them to different USB Ports. Does the same 1455 get the same port or does it move? I think that will tell me what I need to know.
Thanks, Max
Posted: 06 December 2017 at 8:33pm | IP Logged Quote JohnS
Linux should be happy. It knows enough (like its internal path to the physical USB port) to make it just work (even if there is no unique serial #).
Posted: 07 December 2017 at 8:18am | IP Logged Quote Grogster
No, it assigned it a new COM port number. It was COM11. I move it to another USB port, and it is still accessible, but has been assigned COM14 not COM11.
I don't THINK there is much you can really do about that. Windows assigns the VCP number when you plug the USB thing in, and you don't get a choice as to the actual number that the operating system assigns to that adaptor.
kg4pid
Posted: 07 December 2017 at 1:25pm | IP Logged Quote kg4pid
Thanks Grogster, as long as the OS assigns the same port after a reboot I'll be OK.
Max
Posted: 07 December 2017 at 1:28pm | IP Logged Quote Grogster
So long as you stick to a certain USB port physically, the COM port number SHOULD stay the same. Note I said 'Should'..... Windows does odd things.
Page of 2 Next >>
Privacy Policy     Process times : 0.02, 0, 0, 0.11
