Subject Topic: Pi-cromite 5.04.17: Sprites Post ReplyPost New Topic
Page of 5 Next >>
Posted: 08 February 2018 at 11:20pm | IP Logged Quote matherp
Please find attached release 5.04.17 for Stretch
2018-02-09_053145_Pi-cromite5.4.17stretch.zip
and for Jessie
2018-02-09_053643_Pi-cromite5.4.17jessie.zip
and the updated manual
2018-02-09_053748_Pi-cromite_Manual.pdf
This contains the full current implementation of SPRITES as per the various recent threads
Edited by matherp on 09 February 2018 at 5:37am
goc30
Posted: 10 February 2018 at 2:09pm | IP Logged Quote goc30
Hello
first, congratulations for the work.
I have a little problem:
I used this version on a raspi2 / Jessie. I installed a lcd 3.2"/3buttons
ref
I put the option "lcdpanel" (OPTION LCDPANEL ILI9341, L, 15,13,24) and tested with "line 0,0,100,200 ". its Ok
After I added the option "touch" (OPTION TOUCH 16,21), then launched "gui calibrate".
Impossible to calibrate.I dn't know if it is a problem hard or if this option is not installed on the screen, after that I wanted to remove the "touch" option.
the problem is that it has also remove the "lcdpanel" option and impossible to work with lcd in mmbasic. To work correctly, I must delete ".option" , and after that I raise it, and finally I put back the option lcdpanel
I specify that I have not tested with olders versions
Edited by goc30 on 10 February 2018 at 2:14pm
Back to Top View goc30's Profile Search for other posts by goc30
Posted: 10 February 2018 at 5:52pm | IP Logged Quote matherp
Based on docs referenced it should be OPTION TOUCH 26,11
goc30
Posted: 10 February 2018 at 11:20pm | IP Logged Quote goc30
sorry I put 26,11 (its a post mistake). The pb is that it disable also lcdpanel and after i cant use lcd
Posted: 11 February 2018 at 2:46am | IP Logged Quote matherp
This will happen if T_IRQ or T_CS are being held low for some reason. T_IRQ would cause continuous interrupts. T_CS would enable the XPT2046 and corrupt the SPI bus. I haven't used this display but the functionality has been tested OK on a normal ILI9341 with discrete wiring
goc30
Posted: 11 February 2018 at 5:08pm | IP Logged Quote goc30
after some tests, it seems that my lcd is not an ILI9341 but an ILI9325
chines lcd is.... chines
Micro-80
Posted: 11 February 2018 at 5:10pm | IP Logged Quote Micro-80
Tell me please how to make startup mmbasic and the application program when power up Raspberry Pi.
Back to Top View Micro-80's Profile Search for other posts by Micro-80
Posted: 11 February 2018 at 5:55pm | IP Logged Quote matherp
Not done it myself but see this page for suggestions
Micro-80
Posted: 12 February 2018 at 8:17pm | IP Logged Quote Micro-80
Thank`s, Peter!
davematt
Posted: 13 February 2018 at 12:00pm | IP Logged Quote davematt
I love being able to draw to an HDMI screen, but I can't seem to be able to draw text.
Line, box,and circle work fine, but so far text just does not appear. No mention of a text command in the manual, so quite possibly missing something...
Anyone else had more success?
TIA, Dave
Back to Top View davematt's Profile Search for other posts by davematt
disco4now
Posted: 13 February 2018 at 1:53pm | IP Logged Quote disco4now
The pi-cromite manual only has commands that are new or different from the MM and MM+ so for those which have not changed see the MM and MM+ manuals.
Back to Top View disco4now's Profile Search for other posts by disco4now
davematt
Posted: 13 February 2018 at 4:14pm | IP Logged Quote davematt
Further to the above I've found I can display the string Time$ if I use a 'y value' of one.
Anything larger will move the text up and off the screen proportionally.
Text commands that have worked on dozens of mites and lcd screens just dont seem to display...
Page of 5 Next >>
