Subject Topic: Modbus CRC. Post ReplyPost New Topic
<< Prev Page of 2
Turbo46
Posted: 10 April 2018 at 6:05pm | IP Logged Quote Turbo46
Previously I wrote:
I believe that if you receive a message, then process the whole message (CRC included) with the CRC generation function, the resultant 'CRC' will be zero. That would be a simpler way of checking the validity of the message. I'm yet to try that though.
Well I have tried it with the examples in Jim's CRC calculation function and with some other real world examples and it does work eg:
test1$ = CHR$(01)+CHR$(03)+CHR$(04)+CHR$(&H3F)+CHR$(&H80)+CHR$(0)+CHR$(0)
check1$= CHR$(&HF7)+CHR$(&HCF)
test1$ = test1$+check1$
PRINT HEX$(CRC(test1$),4)
will return zero (0000)
Bill
Edited by Turbo46 on 10 April 2018 at 6:05pm
Back to Top View Turbo46's Profile Search for other posts by Turbo46
Phil23
Posted: 15 April 2018 at 9:08am | IP Logged Quote Phil23
Wondering if anyone can see fault in this variation.
It returns a 2 character string that I can add to the string I'm building to sent.
Appears to test Ok, and I assume from above if I pass a response string to it, it should return "String"=Chr$(0)+Chr$(0).
Phil.
PS, I am now successfully reading the first Six registers with a single request & converting them successfully.
They all reside in the address range from 30001 to 30032.
Really need a second request for the others as they are up at 30071 to 30080.
If I tried to get them all with one request the response string would be too long.
FUNCTION CrcStr(a$) As String
LOCAL ErrorWord% = &HFFFF, n, j, ByteVal, LSB
LOCAL CrcHex As Integer
FOR n = 1 TO LEN(A$)
ByteVal =
ASC(MID$(a$, n, 1))
ErrorWord% = (ErrorWord%
AND &HFFFF) XOR ASC(MID$(a$, n, 1))
FOR j = 1 TO 8
LSB = ErrorWord%
AND &H0001
IF LSB = 1 THEN ErrorWord% = ErrorWord% - 1
ErrorWord% = ErrorWord% /
2
IF LSB = 1 THEN ErrorWord% = ErrorWord% XOR &HA001
NEXT j
NEXT n
CrcHex = ErrorWord%
AND &HFFFF
CrcStr=
Chr$(CrcHex AND &hFF)+Chr$(CrcHex>>8)
END FUNCTION
goc30
Posted: 15 April 2018 at 1:44pm | IP Logged Quote goc30
Hi Phil
In the MODBUS protocol, the frames are limited to 128 bytes, including crc, which means that if a register is 4 bytes long, the slave can only send 30 registers values
Back to Top View goc30's Profile Search for other posts by goc30
Turbo46
Posted: 15 April 2018 at 3:05pm | IP Logged Quote Turbo46
Hi Phil
I think it does work but you are ending up with a null string.
CHR$(0) + CHR$(0) = CHR$(0) = nothing.
Bill
Edit: From what I have found the maximum Modbus frame size is 256 bytes.
Edited by Turbo46 on 15 April 2018 at 3:23pm
goc30
Posted: 16 April 2018 at 12:32am | IP Logged Quote goc30
hi Turbo46
in wikipedia for modbus they say:
Because register values are 2-bytes wide and only 127 bytes worth of values can be sent, only 63 holding registers can be preset/written at once
Wikipedia
Edited by goc30 on 16 April 2018 at 12:34am
Turbo46
Posted: 16 April 2018 at 8:23am | IP Logged Quote Turbo46
Hi goc30
You may well be right! I have only had experience with small RTUs. My reference though is the 'Modicon Modbus Protocol Reference Guide' Here. Check out page 58 where it states:
'The quantity of registers to be read, combined with all other fields in the expected response, must not exceed the allowable length of Modbus messages: 256 bytes.'
Bill
goc30
Posted: 16 April 2018 at 4:22pm | IP Logged Quote goc30
Hi Turbo46
The MODBUS protocol is open, you can create your own function codes (I created some for clients). The 128-byte limit must have a historical reason (maybe for slow speed reasons)
Modicon use a partial modbus protocol (not 100% compatible, and many functions no-standards) but it is not important. They use also an ascii communication, for this they need more bytes maybe
<< Prev Page of 2
This page was generated in 0.1396 seconds.
Privacy Policy     Process times : 0, 0.02, 0, 0.12
