Subject Topic: Micromite and Chromebook Post ReplyPost New Topic
<< Prev Page of 3 Next >>
SteveA
Posted: 10 April 2018 at 5:55am | IP Logged Quote SteveA
My system see MicromitePlus connected by USB as "ttyACM0". Then in Linux I try with "ln -s /dev/ttyACM0 ~/.wine/dosdevices/com7".
I did exactly the same and gtkTerm and MM edit can connect to the MM.
Then start "wine MicromiteCons.exe" , add COM1 and I connected with console.
This is the bit that doesn't work, the program runs but the dropdown list isn't populated and although I can add a port it doesn't connect.
There is obviously something very obscure going on between wine/ubuntu/chromeOS! I'm not a Linux expert, and I don't think I'll get to the bottom of it, so I'll carry on using MM edit.
Thanks for your help.
Steve
Back to Top View SteveA's Profile Search for other posts by SteveA
sagt3k
Posted: 10 April 2018 at 3:48pm | IP Logged Quote sagt3k
Hi SteveA
Ok, thank you gor sharing you experience. Now I will work to give more suport on linux/wine.
Antonio
Back to Top View sagt3k's Profile Search for other posts by sagt3k Visit sagt3k's Homepage
Posted: 10 April 2018 at 6:45pm | IP Logged Quote robert.rozee
hi steve,
i'd be interested to hear if you have any success with gfxterm:
http://www.thebackshed.com/docregister/ViewDoc.asp?DocID=22
this also uses the registry to locate comm ports.
rob :-)
SteveA
Posted: 10 April 2018 at 8:12pm | IP Logged Quote SteveA
No problem, it runs but says 'No Serial Ports Found'
sagt3k
Posted: 10 April 2018 at 8:25pm | IP Logged Quote sagt3k
Hi SteveA
If you use wine on linux,you need execute a link between /dev/ttyXXX and logic link comx win compatible
Antonio
SteveA
Posted: 10 April 2018 at 8:46pm | IP Logged Quote SteveA
I've been doing this:
'ln -s /dev/ttyUSB0 ~/.wine/dosdevices/comx'
where 'comx' is the port number I want to assign, for example com1..com2..etc
Is that what you mean?
sagt3k
Posted: 10 April 2018 at 9:10pm | IP Logged Quote sagt3k
Hi SteveA
With command dmesg in linux you can see exatly how your device is,recognized. Micromite Plus perhaps it seen a ttyACM0.
Antonio
SteveA
Posted: 10 April 2018 at 10:53pm | IP Logged Quote SteveA
MM+ show as ttyACM,USB to serial adaptors show up as ttyUSB.
Edited by SteveA on 10 April 2018 at 11:38pm
sagt3k
Posted: 11 April 2018 at 12:22am | IP Logged Quote sagt3k
Ok SteveA.
Can you summarixe what kind of hw you are using, which micromite etc?
Posted: 11 April 2018 at 1:14am | IP Logged Quote Volhout
I own a chromebook (ACER C720) that I run Elementary OS on, based on ubuntu.
I used the exact same method as described here and I can use both gtkterm as well as putty to connect to the Micromite, and also the Maximite.
The only difference with he system you describe is that I have removed Chrome OS, and have reflashed the BIOS.
Another thing I can think of is there may somewhere be a conflict with rights. I did not run into this since all modifications I make in the Ubuntu environment always start with a "sudo su".....
That is a habit after working with Puppy Linux, where you are root unless specified otherwise, and you simply get used to that.
I can confirm that the chromebook function keys give different keycodes, and you have to use the CTRL-Q/CTRL-T keys to work with the editor build in into the Micromite.
Edited by Volhout on 11 April 2018 at 1:17am
If nothing goes right ... turn left
Back to Top View Volhout's Profile Search for other posts by Volhout
SteveA
Posted: 11 April 2018 at 9:31pm | IP Logged Quote SteveA
28 pin Micromite (MX170) -> CP2101 USB to Serial adaptor -> Dell P22T Chromebook
dmesg shows cp210x attached to ttyUSB0
or
64 pin Micromite+ (MX470F512H) -> Chromebook
dmesg shows Product: Micromite Plus, Manufacturer Silicon Chip ttyACM4: USB ACM device
Software versions:
Chrome OS 66.0.3359.79
Ubuntu 16.04.4 LTS
Wine 1.6.2
SteveA
Posted: 13 April 2018 at 8:03pm | IP Logged Quote SteveA
GFXterm now works!
Using the info here: Set Up The Serial Port In Wine
I added
[Hardware\\Devicemap\\Serialcomm] 1231984861
"Serial0"="COM1"
to ~/.wine/system.reg
The serial port is found and GFXterm works.
MicromiteCons also now finds the port, but it still doesn't talk to the Micromite.
