Subject Topic: TFT cannot be calibrated Post ReplyPost New Topic
<< Prev Page of 3
Posted: 13 April 2018 at 5:47pm | IP Logged Quote matherp
Check your soldering of the SDcard socket as well. A short of the MISO (SPI-IN to the Micromite) line there could cause the problems you are seeing. Given that the LCD works it is almost certain that MISO is compromised
miyek.ard
Posted: 16 April 2018 at 11:34am | IP Logged Quote miyek.ard
I done re-solder the PIC but the problem still there
Back to Top View miyek.ard's Profile Search for other posts by miyek.ard
Azure
Posted: 16 April 2018 at 3:07pm | IP Logged Quote Azure
Looking at the pictures you posted (on my PC) it looks like there is some solder under the processor chip pins around 5 O'clock and 11 O'clock. I also looks like a few of the pins maybe dry joints that might look soldered but are connected by some flux residue only.
I would double check soldering on the processor again.
<< Prev Page of 3
This page was generated in 0.0938 seconds.
Privacy Policy     Process times : 0, 0, 0, 0.09
