Subject Topic: E-28 to Nano Pinouts. Post ReplyPost New Topic
<< Prev Page of 2
Posted: 19 May 2018 at 10:44am | IP Logged Quote Grogster
Is this the sort of thing you are after though?
Can you see any obvious changes you would like made?
Phil23
Posted: 05 June 2018 at 8:09pm | IP Logged Quote Phil23
Hi Grog,
All looks pretty good to me.
Looking about there's a swag of PCB's out there designed to serve a purpose & controlled by a Nano.
Most look like they could also be driven by basic.
Usually their pin usage count from the Nano is fairly small so the few missing ones in the conversion shouldn't count.
I did briefly think that maybe just a 28 pin DIL on a Nano foot print board was an alternate solution, but there'd be no space for the 1455 & USB would be lost; ant that direction would essentially be designing an new alternate Micromite.
Just remapping the E-28 seem a much more sensible solution.
Phil.
<< Prev Page of 2
This page was generated in 0.0942 seconds.
Privacy Policy     Process times : 0, 0, 0, 0.09
