Subject Topic: auxiliary SD card drive Post ReplyPost New Topic
chronic
Posted: 15 May 2018 at 6:36pm | IP Logged Quote chronic
As part of incorporating file I/O and more datatypes into my interpreter program I have been able to set up a SD card as an auxiliary drive.
It uses a small uno for the drivers/housekeeping, and is driven with single 16-bit spi words to open, read, write, and close bytes and csv file as necessary. This means any four micro pins that can bit-bang some spi can be used to connect it.
eg to write a line of some test variables into a csv file:
PROGRAM testwrite
C
      CHARACTER*20 s
      INTEGER*1 a
      INTEGER*4 b, n
      REAL c
      DOUBLE d
      UNSIGNED*1 e
      a = 123
      b = 1222333444
      c = 1.123456
      d = 1.12345678
      e = 234
      s = 'squarkoid'
      OPEN WRITE
      CALL longd()
      WRITE (1,*) a, b, c, d, e, s
      CLOSE
      END
and then read it
      PROGRAM testread
C
      CHARACTER*20 s
      INTEGER*1 a
      INTEGER*4 b, n
      REAL c
      DOUBLE d
      UNSIGNED*1 e
      OPEN
      CALL longd()
      READ (1,*) a, b, c, d, e, s
      PRINT a," ",b," ",c," ",d," ",e," ",s
      CLOSE
      END
displays the line
123 1222333444 1.123456 1.12345678 234 squarkoid
A main advantage is that using a uno means the SD drivers are separately maintainable .
Any errors are reported back via the word exchange. On power-up a check is done for directory access etc. I found a small delay was needed between opening a file and accessing it.
So far I have run files of 185k without problems, it should be good for 4Gb. It might be useful for other systems, if there is further interest.
Back to Top View chronic's Profile Search for other posts by chronic
Quazee137
Posted: 15 May 2018 at 8:05pm | IP Logged Quote Quazee137
Thanks.
As I understand it this is an SPI based SD raw drive?
And will/is there file handling?
Using this will use less of the 170's flash to store
setup or log files on SD. I have been looking into I2C/SPI
fram / flash for this but your way allows so much more storage
and is removable. Looking forward for more.
Quazee
any thoughts on I2C as thats what I playing with now.
Back to Top View Quazee137's Profile Search for other posts by Quazee137
chronic
Posted: 15 May 2018 at 11:10pm | IP Logged Quote chronic
The data is saved as strings of bytes, the files are csv files and can be seen/used as text or excel etc. [I did have an early version that could save values as native binary eg 4 bytes for a 32bit value but it is not developed.]
So far it uses two preset filenames, one for reading, another for writing; writing will create a new file if it is not already present, or append data to a file already present.
It is fairly slow - there is a preset delay in the uno which I have not changed - but it chugs away logging gps values well enough.
ed - re I2C - I have tried to stay clear of it, there seemed to be problems in the early versions but it looks popular now. I have stuck with spi as it offers higher speed maximums, it too has had its gotchas though.
Edited by chronic on 16 May 2018 at 9:55am
chronic
Posted: 27 May 2018 at 1:41pm | IP Logged Quote chronic
This is the semi-prototype, using a "pro mini" (approx 4$), and
a sd micro socket.
The four connections at at the left are used like miso, mosi, clk, ss.
(I am using pic port B0, B1, B2, B3 just as ordinary port B i/o,
it is arbitrary)
There are 5v-3.3v dropping resistor dividers, and the leads are
3.3v and ground. (ed - also two more for 5v/0 for the mini)
To use it with other systems, some routines are needed eg
OPEN, READ, WRITE, CLOSE
which just send constructed 16 bit words exchanged as per spi.
It will be more useful with filename selection, which is in
final progress, hopefully something like
OPEN 'filename.csv'
OPEN 'filename.csv' WRITE
etc.
ed - PS I used one of Mik's protoboards - excellent thanks Mik
Edited by chronic on 27 May 2018 at 1:51pm
chronic
Posted: 15 June 2018 at 11:17pm | IP Logged Quote chronic
OK the arbitrary filename version is working.
eg to write a file called "cruddtxt.csv"
      a = 122
      b = 1222333444
      c = 1.123456
      d = 1.12345678
      e = 234
      OPEN 'cruddtxt.csv'
      CLOSE
and read it and print
      OPEN 'cruddtxt.csv' READONLY
      CLOSE
122 1222333444 1.123456 1.12345678 234
It is working so far (small files), I will test it further and write it up a bit.
This page was generated in 0.1719 seconds.
Privacy Policy     Process times : 0.05, 0, 0, 0.12
