Subject Topic: Armmite - STM32H7: Developments Post ReplyPost New Topic
<< Prev Page of 15 Next >>
Posted: 01 August 2018 at 12:52am | IP Logged Quote matherp
The STM SD card driver seems to be giving too many problems and performance isn't even that good so I have scrapped the 4-bit parallel approach and re-written the SPI version of the driver. In addition I've made some other performance improvements as reported here and updated to the latest 1.3 HAL library
Version 5.04.26
The SDcard should now be wired as per a normal SPI device
PF7 to SD_CLK
PF8 to SD_MISO
PF9 to SD_MOSI
SD_CS can be wired to any available pin as can (optionally) SD_CD and SD_WR. Use the standard MM+ syntax for setting up the SDcard.
OPTION SDCARD cs_pin [,cd_pin] [,wr_pin]
The driver can detect card removal and replacement without needing SD_CD connected. It has been tested using the card socket on an ILI9341 display and is completely compatible with driving the display and touch over the same SPI channel.
The original pins connecting the SDcard are now available for general use.
Pin-98 = PC8
Pin-99 = PC9
Pin-111 = PC10
Pin-112 = PC11
Pin-113 = PC12
Pin-116 = PD2
Pin-87 = PG2
SPI speed is set to 19.2MHz which should be compatible with most cards but in the event there are still problems I'll add an additional speed parameter.
Edited by matherp on 01 August 2018 at 4:59am
gadgetjack
Posted: 01 August 2018 at 6:40am | IP Logged Quote gadgetjack
That did it! Now it works perfectly. Gotta find a case for it now.
Thank you for all your great work!!!!
Back to Top View gadgetjack's Profile Search for other posts by gadgetjack
Posted: 01 August 2018 at 1:51pm | IP Logged Quote TassyJim
Sounds good and I have a pile of cards to test.
But where is the link to the download gone?
Posted: 01 August 2018 at 5:14pm | IP Logged Quote matherp
2018-08-01_171419_Armmite1.3.zip
Posted: 01 August 2018 at 6:12pm | IP Logged Quote TassyJim
Thanks Peter,
I do have a problem
ARMmite MMBasic Version 5.04.26
Copyright 2011-2018 Geoff Graham
Copyright 2016-2018 Peter Mather
> files
Error: A hard error occurred in the low level disk I/O layer
> option list
OPTION FLASHPAGES 1
OPTION SDCARD 114, 56
I tried with and without the CD pin connected.
Same error with no card inserted
Posted: 01 August 2018 at 6:29pm | IP Logged Quote TassyJim
Another problem.
My SSD1306 test program doesn't talk to the display.
The program runs without any errors but no life on the display.
Are there any changes to I2C in this latest build?
Posted: 01 August 2018 at 7:05pm | IP Logged Quote matherp
This should fix i2c. The change to the updated HAL library somehow changed the pinout
2018-08-01_190416_Armmite1.3.zip
Please try the SD card using the slot on a ILI9341 or similar. There seems to be an issue with the Waveshare card when using SPI (works with pullup resistors removed)
Edited by matherp on 01 August 2018 at 7:32pm
Posted: 02 August 2018 at 12:43pm | IP Logged Quote TassyJim
I2C now working.
I tried a different SDCard module and all cards except a Sandisk extreme worked OK
I then tried an module without any pullups and the extreme card works.
Very happy.
One issue. When attempting to use the card with non present, an error is produced.
> files
R:/
18688 analogclock.bas
18432 ARLECSwitch.BAS
0 directories, 2 files
> files
> files
R:/
Reinserting the card and it works again.
Normally, I would not be reading the drive without a card present.
Edit. No pullup on the CD line!
I will fit one and try again.
No. that didn't help.
Edited by TassyJim on 02 August 2018 at 12:53pm
Posted: 02 August 2018 at 6:08pm | IP Logged Quote matherp
The error is correct just the message is a bit (OK a lot) obscure.
Try this version
2018-08-02_180814_Armmite1.3.zip
Posted: 06 August 2018 at 6:52pm | IP Logged Quote matherp
Version 5.04.27
2018-08-06_234227_Armmite1.3.zip
This has been tested with the new daughter board and all display and other peripheral support now seems solid. This release supports SDcards over SPI so the SDcard on the daughter board V1.0 is not supported and the SDcard slot on a display should be used instead or a separate SDcard module can be used but should not have pullups.
Edited by matherp on 06 August 2018 at 11:42pm
TrevorH
Posted: 10 August 2018 at 6:05am | IP Logged Quote TrevorH
Hi Peter,
the backpack seems so far to work OK for me, my displays all use the LED-A pin
to light the backlight, so strapped pin 37 on TFT connector to +3.3v.
I have 2 tiny problems, 1 is SD card not present on ILI9341 display, 2 SD card on
both SSD1963 display work OK BUT instead of loadimage doing so it displays a patch
of garbage.
Any ideas???
Still waiting for RTC batt holder to arrive.
Still haven't tried touch yet.
I am using 5.04.27
Just tried touch, works 100% fine on ILI9431, but still giving same errors as before on SSD1963 displays.
Trevor.
Edited by TrevorH on 10 August 2018 at 6:22am
Back to Top View TrevorH's Profile Search for other posts by TrevorH
Posted: 10 August 2018 at 4:58pm | IP Logged Quote matherp
The 4-pin connector for the ILI9341 SDcard I/F is directly wired to the same pins on the SSD1963 so there is no difference as far as the H/W or S/W is concerned. Can't explain this - check soldering etc.
SD card on
of garbage.
Can't replicate. Check soldering of the morpho pins. I had an initial problem and found one unsoldered - there are so many of them it is easy to miss one. Does load image work OK on ILI9341?
Same code so difficult to understand but try this version which slows Touch SPI speed a bit and see if it helps
2018-08-10_165734_Armmite1.3.zip
Edited by matherp on 10 August 2018 at 5:00pm
This page was generated in 0.1099 seconds.
