Subject Topic: Picromite Aug 18 Post ReplyPost New Topic
<< Prev Page of 3
lew247
Posted: 19 September 2018 at 5:05pm | IP Logged Quote lew247
Sorry
TO make it clearer
and EVERYTHING works perfectly other than when I try and calibrate the touch
The top 2 calibration points work, once I touch the 3rd one I get "Hardware Failure" message
I'm 98% the pins are correct - ?
Edited by lew247 on 19 September 2018 at 5:06pm
Back to Top View lew247's Profile Search for other posts by lew247
Posted: 19 September 2018 at 5:37pm | IP Logged Quote matherp
Given this we know that T_IRQ is wired correctly.
Check the Pi is all OK. First remove the display.
For each of the 5 pins set them up as DIN. Connect wires at the display header between the pins and GND then the pins and 3.3V and check they read correctly ("PRINT PIN(n)")
Connect SPI-OUT to SPI-IN at the display header then initialise SPI and execute "PRINT HEX$(SPI(&H55))" check it prints "55"
Initialise SPI at a slow speed. Connect SPI-CLK to one of the COUNT inputs (e.g. SETPIN 12,CIN). Execute a single SPI transfer and check the count is incremented by 8
GoodToGo!
Posted: 19 September 2018 at 10:44pm | IP Logged Quote GoodToGo!
You really need to be 100% sure. Pull both boards off and check for continuity and shorts between pins.
One other thing, have you got the display SD card SPI pins connected to anything? I wonder if leaving them floating could cause issues?
Cheers,
GTG!
Back to Top View GoodToGo!'s Profile Search for other posts by GoodToGo!
lew247
Posted: 21 September 2018 at 11:49pm | IP Logged Quote lew247
I found the problem eventually after checking about 10 times and 9 times I missed it
T_DIN and T_DOUT were swapped
so annoyed with myself
lew247
Posted: 22 September 2018 at 3:58am | IP Logged Quote lew247
GoodToGo you were correct, thank you
Azure
Posted: 22 September 2018 at 9:16am | IP Logged Quote Azure
The important thing is you stuck at it and got it sorted out, well done.
GoodToGo!
Posted: 25 September 2018 at 6:31pm | IP Logged Quote GoodToGo!
Don't beat yourself up about it. As they say, s*!t happens. Joint effort by many people here that helped you out, not just me.
Now have fun with it!
Cheers,
GTG!
<< Prev Page of 3
This page was generated in 0.1719 seconds.
Privacy Policy     Process times : 0.06, 0, 0, 0.11
