Subject Topic: HDMI output from MM2/MM+: interesting? Post ReplyPost New Topic
Page of 2 Next >>
Posted: 05 October 2018 at 8:56pm | IP Logged Quote matherp
Using MMBasic running on Pi-Zero as an HDMI I/F for a MM2.
A loadable CFunction display driver on the MM2 (running completely standard MMBasic) communicates over a 4-bit parallel I/F to the Pi-Zero. This is also running MMBasic with a new feature OPTION REMOTE ENABLE which tells it to listen on the 4-bit port for graphics commands.
Surprising, the Pi is very poor at acting as a slave device and receiving high volume data but using the 4-bit i/f I'm getting a reasonable throughput.
Reliability isn't there yet as the Pi seems to crash out of MMBasic after 5 minutes or so but this could just be a wiring issue.
Edited by matherp on 05 October 2018 at 8:59pm
Posted: 05 October 2018 at 9:20pm | IP Logged Quote Grogster
You don't rest for long before coming up with something else, do you?
This is neat. But if you had to have an HDMI output for your MM, surely there are HDMI host chips that can be had these days?
Perhaps not. I know HDMI licensing is a little complicated.
Posted: 05 October 2018 at 9:32pm | IP Logged Quote matherp
Possibly, but you also need a framebuffer, a PCB layout, build and debug etc.....
A Pi-Zero does all this for you for a fraction of the price
Posted: 05 October 2018 at 9:36pm | IP Logged Quote Grogster
Yes, good point.
goc30
Posted: 06 October 2018 at 1:14am | IP Logged Quote goc30
very good idea
Back to Top View goc30's Profile Search for other posts by goc30
Posted: 06 October 2018 at 2:39am | IP Logged Quote JohnS
Are you in effect bit-banging at the Pi end?
Either way, roughly what sort of throughput (*) can you reliably get?
Probably some follow-up questions/ideas depending on the above...
(*) not sure what units make sense: 4-bit transfers per second? MB/s?
Posted: 06 October 2018 at 4:06am | IP Logged Quote matherp
Nibble banging
A 14 byte message takes 75 micro-seconds so 187Kbytes/second when active
Posted: 06 October 2018 at 4:52am | IP Logged Quote JohnS
Thanks.
Would it be better to use an ordinary channel - UART, or whatever?
That way Linux already has a device driver and there may be hardware buffering so overall better throughput / less CPU load.
Does depend on what the MMS/MM+ has available as well as what the RPi has...
Posted: 06 October 2018 at 5:03am | IP Logged Quote matherp
UART is no good as the "proper" UART on Pi's with Wifi is used for Bluetooth. The other one has a baudrate that varies with CPU clock speed (very useful - not)
SPI would be the obvious one but no-one has ever got a Pi to work in SPI slave mode. This uses some "special" I/F H/W (bsc)
I2C too slow and uses the same I/F as SPI, does work sort of but not reliable.
Posted: 06 October 2018 at 6:47am | IP Logged Quote JohnS
Oh.
Sorry, was just a thought.
Er, do you change the CPU clock speed often?
Posted: 06 October 2018 at 7:38am | IP Logged Quote matherp
I don't but Rasbian does it behind your back in response to thermal /load etc.
MicroBlocks
Posted: 06 October 2018 at 4:09pm | IP Logged Quote MicroBlocks
Use a 1455 as a Serial/SPI/Parallel input at the mm side and USB CDC or HID at the Pi side and get a pretty high throughput.
You could use that also to create a 'window' on a windows/Linux machine that can act as a remote screen. (Got that working already, but it is not open source as it is made for a client so can not share).
Page of 2 Next >>
