Subject Topic: VS6048 Solar CC Wifi Monitoring System Post ReplyPost New Topic
<< Prev Page of 3
azhaque
Posted: 16 October 2018 at 4:21pm | IP Logged Quote azhaque
Hello everyone,
Progress to report, of the last 2-3 days.
Got the ESP8266 to run a webserver displaying dummy data, on my home network. This Network runs on an old Linksys router (pic below).
The Arduino/ESP8266 code is given below
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
// Replace with your network credentials
const char* ssid = "TeenZaitoon";
const char* password = "OliveGrove2018";
ESP8266WebServer server(80);   //instantiate server at port 80 (http port)
String page = "";
double Adata;
double data48A;
double data48B;
void setup(void){
  pinMode(A0, INPUT);
  delay(100);
  Serial.begin(115200);
  WiFi.begin(ssid, password); //begin WiFi connection
  Serial.println("");
  // Wait for connection
  while (WiFi.status() != WL_CONNECTED) {
    delay(50);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  server.on("/", [](){
    page = "<h1>Olive-Grove Solar Power Stats</h1><h3>Analogue: "+String(Adata)+"</h3><h4>ChargeCont-A: "+String(data48A)+"</h4><h5>ChargeCont-B: "+String(data48B)+"</h5>";
    server.send(200, "text/html", page);
  server.begin();
void loop(void){
  Adata = analogRead(A0)-5;
  data48A += 3;
  data48B += 7;
  delay(150);
  server.handleClient();
  server.begin();
void loop(void){
  Adata = analogRead(A0);
  data48A += 3;
  data48B += 7;
  delay(150);
Picture of the data on my Chrome browser
Perusal of the Code would show that the output is essentially dummy data. This would be substituted by the actual data from the MODBUS outputs of the Charge Controllers. The photo below shows the simulated output voltage (0- 5 VDC) from the ACS758 that will indicate battery current, both charging and discharging.
Next step is to test out the MODBUS system and write its software.
Regards all round.
azhaque
Edited by azhaque on 16 October 2018 at 4:36pm
Back to Top View azhaque's Profile Search for other posts by azhaque
<< Prev Page of 3
