Subject Topic: Armmite-H7 V5.04.33: HDMI output Post ReplyPost New Topic
Posted: 09 October 2018 at 3:37am | IP Logged Quote matherp
This version includes support for an HDMI monitor using a Raspberry-Pi Zero as the HDMI interface
2018-10-09_023933_Armmite1.3.zip
Pin connections between the two are 1:1 as per the 8-bit SSD1963 pinout in both cases with the exception of the RD pin so there are 8 data pins and 3 control lines (+ a ground connection).
Support includes full console functionality including edit, and transparent text but not BLIT or SPRITE.
the command to enable HDMI output on the Armmite H7 is:
OPTION LCDPANEL HDMI, hres, vres
hres and vres should be set to the same as the Pi.
The new version of the Pi-cromite software 5.04.24 that supports this is attached.
2018-10-09_032630_mmbasicjessie.zip
2018-10-09_032704_mmbasicstretch.zip
To put the Pi into the HDMI I/F mode do as follows:
rm .options
run the Pi-cromite software as normal (sudo ./mmbasic)
OPTION REMOTE 8
You should see the following screen:
You can return to the Pi-cromite Basic prompt by typing Ctrl-C
and cancel the remote functionality with
OPTION REMOTE 0
To configure the Pi to work correctly with your HDMI display you may need to edit the file "boot/config.txt"
for a 800x480 display insert the commands
hdmi_group=2
hdmi_mode=87
hdmi_cvt=800 480 60 6 0 0 0
hdmi_drive=1
for a 1920x1080 display as in the picture I've used
sdtv_mode=2
sdtv_aspect=3
hdmi_group=1
hdmi_mode=16
disable_overscan=1
for other formats google is your friend.
I will also make this functionality available on the MMX and as a loadable driver on the MM+ in the near future
Edited by matherp on 09 October 2018 at 5:10am
Posted: 09 October 2018 at 5:32am | IP Logged Quote WhiteWizzard
Wow Peter, very impressive (yet again!) - you keep us very busy with new & exciting things to try out.
One Question: You mention above that this version does not support BLIT or SPRITE. Is this because it is 'not yet done', OR is it just technically not possible and/or feasible?
Posted: 09 October 2018 at 6:14am | IP Logged Quote matherp
Wouldn't sufficiently fast to be useful and worth programming, the best bus speed I've been able to achieve is 800Kbytes/second burst. Loading an 800x480 RGB888 picture takes 3.5 seconds.
This page was generated in 0.4219 seconds.
Privacy Policy     Process times : 0.28, 0, 0, 0.14
