Subject Topic: MM Plus restart? Post ReplyPost New Topic
davematt
Posted: 09 November 2018 at 2:31pm | IP Logged Quote davematt
Hi all, I have 2 MM Plus mites running 5.04.09 running a counting program that reliably goes for 5 mins exactly and then restarts itself. Problem is, it's not supposed to! Can post the code, but truly, it's nothing but increment a counter and print.
Mites are freshly flashed, can see nothing to imply some sort of timeout. Can anyone help?
TIA, Dave
Back to Top View davematt's Profile Search for other posts by davematt
Posted: 09 November 2018 at 2:47pm | IP Logged Quote TassyJim
Try the latest beta.
There were a few problems with calling SUBs if that is what you are doing.
There were also problems with the USB console if that is what you are using.
Posted: 09 November 2018 at 3:09pm | IP Logged Quote Grogster
Yes, or go back to the last STABLE release: 5.04.08
davematt
Posted: 09 November 2018 at 4:59pm | IP Logged Quote davematt
Hopefully this shows both code and result...
Thanks Jim and Grogster. Above is using 5.04.04. I cant find 5.04.08 in the archive, is it available somewhere else?
Will try the latest beta.
2 extra thoughts...
This test was on a brand new chip in an adapter socket, no change.
Can't see how this didn't emerge earlier, been playing with mm plus for years.
Only change my end has been a switch to Win 10. Oh hell...
Posted: 09 November 2018 at 5:24pm | IP Logged Quote TassyJim
NO problems running the same code here on 5.4.10 beta 13
but I don't use the USB port
Edited by TassyJim on 09 November 2018 at 5:24pm
erbp
Posted: 09 November 2018 at 7:14pm | IP Logged Quote erbp
I have test run your code on my early style E64 module (without the 1455 USB interface). I did 2 runs - first used an external Microbridge (1455) module to interface the serial console pins to the PC USB cable, the second used the USB cable connected directly to the USB socket on the E64 module. Both cases used an external 5v PSU. Both tests ran over 7 minutes without any hint of a restart and I'm sure they would have just continued running if I hadn't stopped them!
My E64 is running firmware version 5.04.08 and my PC is running Window 10 ver 1803.
Cheers,
Phil.
Back to Top View erbp's Profile Search for other posts by erbp
Geoffg
Posted: 09 November 2018 at 10:56pm | IP Logged Quote Geoffg
The problem could be the 10uF capacitor connected to the VCap pin. A faulty VCap has been known to cause intermittent restarts. Powering the MM+ from a PC or USB charger can also cause the same problem. Try using a solid lab supply or three fresh batteries in series.
Back to Top View Geoffg's Profile Search for other posts by Geoffg Visit Geoffg's Homepage
davematt
Posted: 10 November 2018 at 3:29pm | IP Logged Quote davematt
Hmmm, not sure if this classifies as solved, but problem was cheap power supply with almost no current reserve at all. Spot on 5 minutes the mite (with nothing else connected!) will draw enough current to drop the supply voltage and crash itself. Any normal quality supply will handle this, just not mine.
But I would just love to know what's happening here. Anyone?
This page was generated in 0.1113 seconds.
