Subject Topic: 30th Sept 07. New PVC blades. Post ReplyPost New Topic
<< Prev Page of 2
BobMann
Posted: 05 October 2011 at 5:46am | IP Logged Copy link to clipboard   Quote BobMann
Hello I like the blades and hub good job.
Bob Mann
Back to Top View BobMann's Profile Search for other posts by BobMann Visit BobMann's Homepage
Administrator
Posted: 05 October 2011 at 8:10am | IP Logged Copy link to clipboard   Quote Gizmo
Trev's stuff is at http://www.thebackshed.com/BasiclyNatural/ViewCat.asp?CL1=20 &CL2=56&CL3=NA
The Back Shed
JAQ Software
itsandbits1
Posted: 17 October 2011 at 10:26am | IP Logged Copy link to clipboard   Quote itsandbits1
I've found the flexiness of the pvc to be an issue in gusts and with those two stators on one shaft, doubt you can lean the head back to give the blades some clearance. On a single side i've been able to keep them from whacking the pole and breaking by tipping the head back, same as any other .
Back to Top View itsandbits1's Profile Search for other posts by itsandbits1
<< Prev Page of 2
This page was generated in 0.1104 seconds.
