Subject Topic: Micromite eXtreme, GPS & more new goodies Post ReplyPost New Topic
Posted: 30 January 2017 at 2:37pm | IP Logged Quote matherp
This release of the firmware has a number of significant new capabilities.
2017-01-30_144811_Micromite_eXtreme_Manual.pdf
2017-01-30_140238_MMX5.3b10v9.zip
Text output in all orientations
It supports text output in all four orientations + vertical directly from Basic on all supported displays including VGA. This is achieved by simply including the orientation in the justification string so:
text 100,100,”ABC”,ICM
will output ABC inverted with the string centered on 100,100 horizontally and vertically. Valid codes are N(ormal), I(nvert), U(p), D(own) and V(ertical)
Automatic GPS data input and NMEA decoding
It supports automatic decoding of NMEA input from a GPS. This is simply activated using
OPEN "COMz:baudrate" as GPS [,timezoneoffset]
The timezone_offset parameter is used to convert UTC as received from the GPS to the local timezone. If omitted the timezone will default to UTC. The timezone_offset can be a any number between -12 and 14 allowing the time to be set correctly even for the Chatham Islands in New Zealand (UTC +12:45)
Once the GPS is "opened" the function GPS will give immediate access to individual parameters
GPS(ALTITUDE) returns current altitude if sentence GGA enabled
GPS(DATE) returns the normal date string corrected for local time e.g. “12-01-2017”
GPS(DOP) returns DOP (dilution of precision) value if sentence GGA enabled
GPS(FIX) returns 0=no fix, 1=fix, etc. if sentence GGA enabled
GPS(LATITUDE) returns the latitude in degrees as a floating point number, values are –ve for South of equator
GPS LONGITUDE) returns the longitude in degrees as a floating point number, values are –ve for West of the meridian
GPS(SATELLITES) returns number of satellites in view if sentence GGA enabled
SPS(SPEED) returns the ground speed in knots as a floating point number
GPS(TIME) returns the normal time string corrected for local time e.g. “12:09:33”
GPS(TRACK) returns the track over the ground (degrees true) as a floating point number
GPS(VALID) returns: 0=invalid data, 1=valid data. ALWAYS CHECK THIS VALUE TO ENSURE DATA IS VALID BEFORE USING OTHER GPS() FUNCTION CALLS
Sensor fusion for applications needing orientation information
It supports automatic calculation of pitch, roll and yaw from 9-axis sensors allowing applications like a tilt-compensated compass to be programmed entirely in Basic - code attached below
watch the video
Measurement of unknown input baudrates
It supports a new function BAUDRATE which will report the baudrate of an active serial input on any of the comms ports
Paged display for 4.3" SSD1963
It supports the 4.3" SSD1963 display using a new driver SSD1963_4P
This sets the 4.3” SSD1963 display up in 480 x 864 (landscape or reverse landscape) or 864x480 (portrait or reverse portrait) pixel mode. The screen viewport is 480x272 or 272x480 and the position of the viewport is controlled by GUI STARTLINE n. This mode of operation allows display updates to be done on a non-visible part of the graphics memory and then the viewport moved to see the updated image completely eliminating tearing effects. The 4P display controller is fully compatible with TOUCH, MOUSE, CURSOR and GUI controls. and is used in the compass program
Arrays as inputs to drawing routines
It supports arrays as inputs to the basic drawing routines. This can provide huge speed improvements in some cases. For example outputting individual pixels in a loop can achieve 22000 pixels per second. Using arrays to contain the pixel coordinates speeds of over 400,000 pixels per second are possible.
More details of the new functionality are included in the Micromite eXtreme manual attached above.
Errata
Any bugs in Geoff's 5.3b10 beta release for the MM+ will probably also be in this code. Other bugs are entirely my own creation.
Code and background image for the compass
2017-01-30_142749_compass.zip
Edited by matherp on 30 January 2017 at 4:06pm
palcal
Posted: 30 January 2017 at 8:37pm | IP Logged Quote palcal
I find all this a bit hard to believe. AWESOME.
6 years ago I built a MICROMITE and now I'm here.
Paul.
Back to Top View palcal's Profile Search for other posts by palcal
cdeagle
Posted: 30 January 2017 at 8:49pm | IP Logged Quote cdeagle
Very useful and easy to use "extended" functions.
Great work Peter .
Back to Top View cdeagle's Profile Search for other posts by cdeagle
Posted: 30 January 2017 at 9:22pm | IP Logged Quote WhiteWizzard
@MatherP
Page18 4th line down: SPI can be 1,2 or 3 (not 1, 2 or 2)
Posted: 30 January 2017 at 11:33pm | IP Logged Quote Grogster
Paul.
Indeed.
The Micromite just keeps getting better and better with chaps like Geoff and Peter working on the development. Impressive new features for the eXtreme family.
panky
Posted: 31 January 2017 at 2:24am | IP Logged Quote panky
Peter,
Terrific job - can't wait for WW's board to arrive.
P23 of your manual SPS(speed) should be GPS(speed)?
Doug.
