Subject Topic: Pi-cromite V5.4.05 with documentation Post ReplyPost New Topic
Page of 6 Next >>
Posted: 11 August 2017 at 10:35am | IP Logged Quote matherp
The Pi-cromite code has been stable for a bit now so I've tried to pull together as much of the information in the original huge thread as possible and incorporate it into a Pi-cromite manual
2017-08-11_102341_Pi-cromite_Manual.pdf
I've also re-versioned the code and included some additional MMX features to maintain compatibility with the Micromite/MMX versioning
2017-08-11_103150_mmbasic.zip
As always the primary source of information on the MMBasic language and most commands is the Micromite and Micromite+ manuals
Posted: 11 August 2017 at 10:40am | IP Logged Quote WhiteWizzard
Brilliant stuff - THANKS
paceman
Posted: 11 August 2017 at 12:36pm | IP Logged Quote paceman
Thanks for that from me too Peter. I've been chickening out of trying it out on the Zero-W I bought about two months ago - partly because I wasn't sure where to start in the thread! No excuse now - I'm going to have to bite the bullet and give it a go.
Greg
Edited by paceman on 11 August 2017 at 12:38pm
Back to Top View paceman's Profile Search for other posts by paceman
RonnS
Posted: 11 August 2017 at 1:12pm | IP Logged Quote RonnS
... thank you very much Peter ... i like it !
I'm still working on my smart home system - it's running with the Raspberry, but there's still much to make it better
What do you think about my suggestion to use GTK + elements with the PiCromite ---will this be possible? GTK Widgets
regards Ron
Back to Top View RonnS's Profile Search for other posts by RonnS
Posted: 11 August 2017 at 2:06pm | IP Logged Quote matherp
If I understand it this layers on top of X-windows so would need the full version of Raspbian installed. For the Pi Zero this is really too much overhead so I think it makes sense to stick with console window but I may be missing something
RonnS
Posted: 23 August 2017 at 12:00pm | IP Logged Quote RonnS
hi Peter ,
i like the PiCromite so we have all in one, a finishesd PCB without any soldering and so on and its run at 1200 mhz
for some test i have decrase the clockspeed to 800 mhz .. it works well and the bitstream command does not make problems
the cpu have to be cooled above 74 degrees mmbasic will stopp elesewere
I bought a 3.5 inch display hoping it worked but it only shows half the screen you can help me ??
main parameter
Type           :TFT
Interface       :SPI
Touch panel control chip  :     XPT2046
The color index  :     65536色
Backlight:       LED
resolving power:     320480 (Pixel)
Size proportion:     8:5
power waste:     TBD
Back facet current:     TBD
Working temperature (c):     TBD
Interface definition
Pin number                         identification          describe
1、17                               3.3V       ------   Power supply positive (3.3V power input)
2、4                               5V          -- ----     Power supply positive (5V power input)
3、5、7、8、10、12、13、15、16       NC             --- ---         NC
6、9、14、20、25                   GND          -------          Power GND
11                                   TP_IRQ      ------ Touch panel interrupt, detect the touch panel is pressed down to a low level
18                                  LCD_RS           -------   Instruction / data register selection
19                                  LCD_SI / TP_SI   ------ LCD display / touch panel SPI data input
21                                  TP_SO             -----  SPI data output of touch panel
22                               RST                 -----        reset
23                                  LCD_SCK / TP_SCK     LCD  --------    SPI clock signal for display / touch panel
24                                  LCD_CS               --------          LCD chip select signal, low level LCD
26                                  TP_CS       ---------   The touch panel chip select signal, low level selection of touch panel
Specifications
    LCD Type      TFT
 LCD Interface      SPI
 Touch Screen Type      Resistive
 Touch Screen Controller      XPT2046
 Colors      65536
 Backlight      LED
 Resolution      320*480 (Pixel)
 Aspect Ratio      02:03
 Power Consumption      TBD
 Backlight Current      TBD
 Operating Temp. (℃)      TBD
Interface
    PIN NO.      SYMBOL      DESCRIPTION
 1, 17      3.3V      Power positive (3.3V power input)
 2, 4      5V      Power positive (5V power input)
 3, 5, 7, 8, 10, 12, 13, 15, 16      NC      NC
 6, 9, 14, 20, 25      GND      Ground
 11      TP_IRQ      Touch Panel interrupt, low level while the Touch Panel detects touching
 18      LCD_RS      Instruction/Data Register selection
 19      LCD_SI / TP_SI      SPI data input of LCD/Touch Panel
 21      TP_SO      SPI data output of Touch Panel
 22      RST      Reset
 23      LCD_SCK / TP_SCK      SPI clock of LCD/Touch Panel
 24      LCD_CS      LCD chip selection, low active
 26      TP_CS      Touch Panel chip selection, low active
many thanks Ronald
Posted: 23 August 2017 at 2:18pm | IP Logged Quote matherp
Can you provide a link to the specific screen?
The problem is that there are at least three chips on these 3.5 boards ILI9341, ILI9488, ILI9327 which seem to be used interchangeably but are not exactly the same. They need different initialisation although run-time is the same
Edited by matherp on 23 August 2017 at 2:19pm
RonnS
Posted: 23 August 2017 at 3:31pm | IP Logged Quote RonnS
thank you Peter , here is the link
https://www.amazon.de/gp/product/B06X191RX7/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
i have a cd with installing instructions files
the driver is called :
LCD-show-160701.tar.gz or
LCD-show-170315.tar.gz
Posted: 23 August 2017 at 4:11pm | IP Logged Quote matherp
Not sure I understand but if I assume that you are trying to use the TFT as a Pi console rather than using it from MMBasic then you need to tell MMBasic to leave the pins used by the display alone.
The command for this is OPTION PINS nnnn (see manual for more info)
Try OPTION PINS &B10111101100000010000000000
RonnS
Posted: 24 August 2017 at 7:00am | IP Logged Quote RonnS
hi Peter..,
I wanted to use it as mmbasic display
First I tried it with a zero W-
today I tried it with a RPi 3 and its working
this pic shows the 3.5 Zoll LCD with an RPi3
I think the Zero-W is broken
and this pic shows the 4 Zoll LCD with an RPi3
if someone is interested in it the casing is from Combiplast Link
Edited by RonnS on 24 August 2017 at 7:16am
RonnS
Posted: 25 August 2017 at 10:26pm | IP Logged Quote RonnS
Syntax help needed:
if i try:
save image "Screen"
i got an error: expected a string
what im doing wrong ??
Edited by RonnS on 26 August 2017 at 4:57am
Posted: 26 August 2017 at 8:02am | IP Logged Quote matherp
Looks like SAVE IMAGE has gone missing - leave it with me
One question though are you trying to use it on the display you reference above? If so it won't work because of the way the display is wired you can't read from the graphic memory
Edited by matherp on 26 August 2017 at 8:18am
Page of 6 Next >>
