Subject Topic: Help with a school project Post ReplyPost New Topic
<< Prev Page of 3
Brady
Posted: 22 August 2017 at 10:39am | IP Logged Quote Brady
Ok, right that makes more sense.
By working out how fast the water goes, and how much it takes to produce electricity. I can find out what motor and it's gear ratios to use?
I will most certainly do that if I can work all of that out with just a bit of testing!
Back to Top View Brady's Profile Search for other posts by Brady
Brady
Posted: 30 August 2017 at 11:49am | IP Logged Quote Brady
UPDATE: progress has been a bit slow. Sorry for that..
We have completed the testing model, it's quite small. But it's only made to test the speed of the water. Testing phase will be tomorrow. Going off of the suggestions from this form, tommorow we will a) test the speed of the river. B) find out the rotations per minute for our system, and C) find out the tides will be at that time. By working these three out, we should be able to predict how fast the water will go at its peak, and how much power it can produce. Then we can go into our working model.
Hmm it won't let me upload the image of the model... got it.
Edited by Brady on 30 August 2017 at 11:51am
flc1
Posted: 31 August 2017 at 8:00am | IP Logged Quote flc1
looks like your on your way Brady
, good stuff,maybe a little bit of bracing wood between the base of each paddle by the shaft?
Edited by flc1 on 31 August 2017 at 8:04am
Brady
Posted: 03 September 2017 at 11:39am | IP Logged Quote Brady
Uh, sorry, another late reply.
The test was sort of disappointing, the river was moving incredibly slowly.
Using a measuring tape, we measured out 20 metres from the footbridge across the bank. From the footbridge, we dropped a plastic bottle (tied to string) into the river and timed how long it took to get to that 20 metres. I found out that the water speed was 0.385m/s. Very slow, I know.
After that, we tested how many rotations our system would do in one minute. We got around 22 rotations per minute. I observed some things, for one, the system was tilted at an angle, as we only used a single piece of string to hold it. The paddlewheel would also stutter, it would have trouble climbing, and then decline fast. Most likely due to unbalance.
There are quite a few things that I think may have got in the way of a much better result.
A) The device was not in the fastest part of the river (the centre), as this was only a model, and it wasn't attached to the gate pole.
B) We simply dropped the system into the water using a single piece of thick fishing wire. Because of this, the system was always at an angle, and it never got the full power of the river.
C) The river was running abnormally slow, however this was a natural challenge, and we obviously aren't at fault for this one.
D) I also believe there may have been a bit of friction on the shaft, preventing the paddle from moving faster, we did oil it, and sand paper the wooden shaft before hand, but I believe there is room for improvement.
E) The paddles were unbalanced. While they were cut as evenly as possible using machinery, there may have been some unbalance. The hot glue may have caused unbalance, and they may have not been glued on evenly apart. We also added tape on one of the paddles to distinguish one rotation, I believe I put too much tape on.
F) around half of the individual paddles on the paddlewheel didn't touch the water. I'm wondering if the useless parts of the paddle added unnecessary weight, in which lowered the rotations.
The system, in the end, floated and rotated, without any leakage occurring after the testing. There are obviously many things we will need to improve on to get the most efficient design. But, it was a success at least
Brady
Posted: 03 September 2017 at 11:49am | IP Logged Quote Brady
The green line is where I want some sort of plank or pipe for the system to rise up and down. Also you can see how tiny our model system is. My hope it that we'll get it a lot larger.
Quality is kinda potato, but we put in tiny bent nails in the shaft to stop it from moving side to side. Flc1 is that what you meant?
Posted: 03 September 2017 at 6:39pm | IP Logged Quote Warpspeed
That test was a great success in that you have learned a great deal about some of the problems to expect when developing the next prototype.
Probably the first thing is a means of keeping the turbine in a stable position in the fastest part of the flow. Your two floats need to be placed as widely apart as practical to prevent the turbine from tilting sideways, especially in choppy water.
So the whole turbine probably needs to be a lot wider than it is tall so it always floats fairly level.
And if the whole thing was mounted on a fairly long trailing arm, that should keep it steering straight and in the centre of the main flow.
Because it turns so very slowly it needs to be made quite large, otherwise as soon as you place any significant load on it, its just going to stop turning. Its one thing to just make something that turns, but to charge a battery, it also needs to generate some useful mechanical power.
To get a nice even turning, there need to be several blades in the water at the same time. The amount of "pull" the water can exert on the blades depends on the surface area of the blades. Very wide blades will generate much more force than narrow blades.
Speed is pretty much fixed by the flow velocity, so to extract more power, the paddles need to be made deep and wide.
Cheers, Tony.
Boppa
Posted: 04 September 2017 at 1:26pm | IP Logged Quote Boppa
I suspect your prototype has a lot of friction in its 'bearings' (where the rotating axle goes into the floats) which would slow its rotational speed significantly as well
A set of bearings would probably show a major speed increase
(if you have a pair of those spinets things like these (spinnets) - use one bearing for your axle to go through, and the other two bearings to put screws/bolts into your float)
As suggested, making your axle and paddles wider will make it more stable, and develop a lot more power as well
Edited by Boppa on 04 September 2017 at 1:28pm
Back to Top View Boppa's Profile Search for other posts by Boppa
flc1
Posted: 04 September 2017 at 6:17pm | IP Logged Quote flc1
Gday Brady, like your pics, I was just hinting at putting a small bit of wood between each blade down by the shaft, to give a bit more sapport to the blades.But its probably not needed, keep up the good work. I look forward to seeing it finnished and charging your battery.
Posted: 04 September 2017 at 9:56pm | IP Logged Quote Warpspeed
I have been thinking about what to use as an electrical generator.
Check out these low cost Chinese hand crank generators on e-bay. For only a very few dollars you might find something that can easily be adapted for pulley drive.
This is just one example, there are several different sizes, styles and types of hand crank generators advertised on e-bay, all of them cheap.
http://www.ebay.com.au/itm/USB-Emergency-Charger-Dynamo-Hand-Crank-Generator-For-MP3-MP4-PDA-Cell-Phone-/201985181592?va r=&hash=item2f07414798:m:m1ccfcM4LvPiMnM_MksIIQQ
Hand cranking suggests about one turn per second ?
But I have no idea what speed you will finally end up needing, or how hard these are to turn. No specifications provided unfortunately, only way to find out is to get one and do some testing.
A standard BMX bike rim is usually 20 inches or very close to 500mm diameter.
Circumference will be around 1.57 metres.
Flow is roughly 23 metres per minute.
So a bike wheel might turn perhaps 14 turns per minute.
If you can work out how many turns per minute a hand cranked generator needs to turn, that will give you a reasonable starting point to further experiment with different pulley ratios.
Edited by Warpspeed on 04 September 2017 at 10:15pm
Cheers, Tony.
<< Prev Page of 3
Privacy Policy     Process times : 0.02, 0, 0, 0.11
