Subject Topic: F&P 36 pole aluminium stator power output Post ReplyPost New Topic
DaveP68
Posted: 20 September 2017 at 10:18pm | IP Logged Quote DaveP68
Tried a F&P 36 pole aluminium stator today for the first time just to check how it compares to a copper version.
Results were 615 W at 588 RPM on my crude test rig. Other reading are 410 VDC and 1.5 Amps into my controlled current load. This is about 7% less output power than the copper stator.
Open circuit volts reading is about 1.1 VDC per 1 RPM. Copper stator is around 1.185 VDC per 1 RPM. This implies that there are less turns per pole. The resistance reading phase to phase star is 38 ohms vs 32 ohms for the copper stator.
It's possible to get a good output from them but rewiring them becomes a challenge. Solders used for aluminum generally contain zinc with some lead, cadmium, tin, copper, or aluminum. However, any solder that contains tin may cause an electrochemical corrosion problem due to its galvanic potential.
Edited by DaveP68 on 21 September 2017 at 3:00am
Thai
Posted: 06 June 2018 at 1:31am | IP Logged Quote Thai
Is the stator used, one with redesign black cap?
Edited by Thai on 06 June 2018 at 1:39am
Back to Top View Thai's Profile Search for other posts by Thai
DaveP68
Posted: 06 June 2018 at 10:04am | IP Logged Quote DaveP68
Well not exactly the one outlined in this topic is a 36 pole aluminum stator using a 48 magnet black rotor cap. These are used on all top loading washing machine currently in production.
The FP640 stator that you have is a 27 pole aluminum stator that uses a 36 magnet black rotor cap.
Thai
Posted: 08 June 2018 at 2:56pm | IP Logged Quote Thai
Oh i see. I can't find any info on the motors I have. Thanks for the info
Privacy Policy     Process times : 0.06, 0, 0, 0.09
