Forum Index : Microcontroller and PC projects : CMM2 G2 V2 design files
Posted: 11:45am
04 Apr 2024
The CMM2 G2 V2 is designed to be much cheaper to manufacture than all previous designs. JLC can build it ready-to-run for about £133 for 5 boards (+, of course, shipping and any local taxes). It is functionally identical to the previous versions with the exception that it does not support the Hobbytronic USB mouse I/F chip. PS2 mice are still widely available and plug directly into the bottom USB socket (USB keyboard in the top). As before the Microsoft Basic Optical Mouse is highly recommended and both the V1.1A and V2.0 versions work well the the CMM2.
I have 3 boxed CMM2 G2 available for sale (2 off G2 V2 and 1 off G1 V1.5) as I'm rather "over-stocked" for my development needs. Contact me by PM if interested
Gerbers
CMM2G2V2.0.zip
Bill of materials and placement files
CMM2G2V2.0BOM.zip
Design files for box ends: Cambam, dxf, Sketchup, stl
CMM2G2V2ends.zip
EasyEDA design files
CMM2G2V2.zip
Schematic
CMM2G2V2Schematic.pdf
Currently all parts are in stock at JLC
Edited 2024-04-04 21:52 by matherp
Posted: 09:30pm
04 Apr 2024
Excellent, thanks Peter!
Footnote added 2024-04-05 17:19 by Grogster
I will be listing these for sale on my website.  As they will be much cheaper then the boards that I had to manually complete, it might really help the CMM2 become the machine it was always destined to be.
Posted: 01:00pm
05 Apr 2024
All my surplus CMM2 G2 now sold.
Posted: 06:04pm
06 Apr 2024
joker
Thumbs up also from me
This is outstanding.
Thank you very much
Matthias
Posted: 11:48am
13 Apr 2024
homa
I received my CMM2 yesterday.
Finally I am a CMM2 owner :-)  Thanks a lot Peter.
Matthias
Posted: 08:59am
17 Apr 2024
PilotPirx
My CMM2G2V2 board has also arrived and is working perfectly. The Microsoft mouse also works perfectly. The picture is razor sharp. The system only hangs (frozen, have to reset) from time to time with subdirectories of my SD-card (which works in the old G1). I still have to test it with other SD cards.
I have only noticed that the I/O pin assignment corresponds to the CMM G1 again. The 180 degree rotation of the G2 is no longer necessary.
But the PIN-numbers are switched. Pin1 is now Pin 40 in schematic. How to set the Pin now? With the old system?
Edited 2024-04-17 19:39 by PilotPirx
Posted: 04:12pm
18 Apr 2024
joker
Hello,
I just got my oder from JLCPCB.
I programmed it with the latest firmware V5.07.02b11.
All five boards are working. The packageing from JLCPCB was a bit cheaper than for my first order last year, but the boards are ship shape and bristol fashion. Nothing to complain here.
The first startup of the board was sometimes quite rough. Multiple resets were necessary.
Mostly the keyboard was not detected in the first run. Hopefully this behaviour will go away with batteries installed.
I also tried a PS2 mouse. In my first board I used the USB mouse chip but never get it working, so I was really exited to see the mouse working. And it did. Unfortunately, the interface is not very stable. After some clicks in the file explorer I got garbage on the screen and the machine finally froze. I will check this with another board later again.
There is onne thing, that is suboptimal. The on/off switch is difficult to operate without an extra tool if an USB-c cable is connected.
In general, I'm pretty happy with my purchase.
Best Regards
 Matthias
Posted: 07:57pm
18 Apr 2024
eparmstrong
First I'd like to thank Peter for making this and the PicoMiteVGA designs available.
I've only managed to get 3 of the 5 boards from JLCPCB that I ordered working.   Same sort of issue as joker.  I'm able to program them all fine, but it seems very difficult to get them to boot the first time.  Nothing will show on either the serial or VGA, and then suddenly it will start working, and once configured the first time, they continue to work fine.
I'd appreciate any suggestions on how to get the initial configuration screen to show up reliably.
Posted: 08:49pm
18 Apr 2024
homa
Did you recognise this in the manual?
Matthias
Posted: 09:14pm
18 Apr 2024
homa
Hi Matthias
Shouldn't a keycap like this help?
https://images.app.goo.gl/omCwqYFTLvCYfKBK6
Do you need all 5 boards or would you part with one? Just send me a PM. Gladly also in German.
Matthias
Posted: 07:41am
19 Apr 2024
PilotPirx
The pin assignment is not as printed on the board. If you look on the back, pin 40 is upper right (where the arrow is)and pin 1 is down left. I measured this with a voltmeter- its like first Gen CMM2. But the print on the board is vice versa.
And Pin40 in the schematic was previously Pin 1.
Here the new pinning
and here the old one:
same functions, but pin numbers switched
Edited 2024-04-19 18:02 by PilotPirx
Posted: 08:47am
20 Apr 2024
homa
  PilotPirx said  The pin assignment is not as printed on the board. If you look on the back, pin 40 is upper right (where the arrow is)and pin 1 is down left. I measured this with a voltmeter- its like first Gen CMM2. But the print on the board is vice versa.
@peter: Can you clarify this?
I am now totally confused.
Since I have the CMM2 Gen2 as V1.5, a new change would bother me now :-(
I'm also thinking about getting one of the new boards from Matthias (@matthias: I'll get back to you after I hear back here).
Matthias
Posted: 09:29am
20 Apr 2024
Sorry about the confusion. The boards made from the gerbers published on this thread should have the same pinout as the 1.5 G2
The two G2V2 development boards sold to PilotPirx and stoke_ferry had the G1 pinout as a result of me copying the wrong layout. I had forgotten I made this change between the prototype G2V2 and the final version as above and should have communicated this to the two recipients
Posted: 09:52am
20 Apr 2024
homa
Thank you for the clarification.
Posted: 10:28am
20 Apr 2024
stoke_ferry
Thanks Peter, and noted. Apart from checking it works I haven't used the CMMG2V2 yet.
Stuart
Posted: 11:59am
20 Apr 2024
homa
Hi Peter,
Another question about the CMM2 enclosures.
Where can you buy them in Europe? I only found one source in Australia. But shipping is too expensive for me.
Do you have 3D print files for them?
Kind regards
Matthias
Posted: 12:57pm
20 Apr 2024
Its a very standard box G738. Try de.farnell.com part 1526699 or 1094711
Posted: 08:25am
22 Apr 2024
PilotPirx
Hi Peter,
thanks for the new information. Now it makes sense to me.
At the moment, i have the problem that the system hangs (frozen, have to reset) from time to time in subdirectories of my SD-card (which works in the old G1). Changing the cards does not change the behaviour. A Power On Reset helps sometimes. Whats the reasion for this?
© JAQ Software 2024
