Forum Index : Microcontroller and PC projects : Frogger Game for CMM2
Posted: 05:21pm
16 Apr 2024
William Leue
I know there is at least one other Frogger-type game (for Picomite?) but this is mine for the CMM2.
Frogger.zip
Enjoy!
-Bill
Posted: 07:22pm
16 Apr 2024
Martin H.
looks good,
but I had to add some Pauses for MMB4W
Posted: 12:04am
17 Apr 2024
William Leue
Martin said
  Quote  but I had to add some Pauses for MMB4W
No surprise there. It runs at an artibrary speed depending on the CPU. It's just about the right speed on a CMM2 but probably too fast on a PC.
-Bill
Posted: 12:42am
17 Apr 2024
May be overkill for this, but one way to make a program less dependent on CPU speed than pauses is:-
Delay = Timer + x 'mS
'Perform Task
Do : Loop Until Timer > Delay
At low CPU speeds it doesn't add a delay.
Posted: 02:33pm
17 Apr 2024
bar1010
Thanks for uploading.  Have played the first two levels so far.
Posted: 05:16pm
17 Apr 2024
Martin H.
  William Leue said  I know there is at least one other Frogger-type game (for Picomite?)
I think you are referring to PicoFrog
At some point I lost the desire to add extras, but as it is, it's fun and playable.
Martin
Posted: 08:58pm
17 Apr 2024
LeoNicolas
I like to compute the delta time for every main loop and use it to multiple the movement variables. I'm using this approach in Knightmare
g_delta_time=(timer-g_prev_frame_timer)/1000
g_prev_frame_timer=timer
© JAQ Software 2024
