Forum Index : Microcontroller and PC projects : cmm2 wii controller classic - fault
Posted: 07:51pm
26 Apr 2024
homa
Hello @peter and all the other cmm2 experts,
I'm new to the cmm2. I am using Peter's V2 G1.5 board.
My second hand wii classic controllers have finally arrived and I have tested them on the cmm2. I wrote the following code:
controller classic open 3,dada
do
 'cls
 circle classic(Lx)+10, (classic(Ly)*-1+256)+10, 10,,, 0, RGB(255,255,255)
 circle classic(Rx)+10, (classic(Ry)*-1+256)+10, 10,,, 0, RGB(127,196,127)
loop
END
sub dada
  print classic(b)
  print classic(Lx), print classic(Ly)
  print classic(Rx), print classic(Ry)
  print classic(L), print classic(R)
  print hex$(classic(T))
end sub
Now the output of the print command shows an extra 0, which I don't understand! The HEX value also seems to be different from the one given in the manual for this type of controller (A4200101 vs 4200101).
> run
2048
128     0 128
128     0 128
0       0 0
A4200101
1
128     0 128
128     0 128
0       0 248
A4200101
16
128     0 128
128     0 128
248     0 0
A4200101
Then I noticed another flaw in the hardware design. You need a tool to get the plugs out of the sockets ;-)
And I can only get the first controller (3) to work.
If I plug in a 2 (controller classic open 2,dada), I get this message:
Error in line 1: Classic not connected
And with a 1 ((controller classic open 1,dada)) I get this error message:
Error in line 5: Not open
Is this because of the Beta FW V5.07.02b11?
Best regards
Matthias
Posted: 08:38pm
26 Apr 2024
The 0 is because you try to PRINT the value of a variable called print!
E.g.
I think you need to remove the 2nd print or change the , to :
Posted: 08:47pm
26 Apr 2024
homa
Head slap
Thanks John, I had tomatoes on my eyes.
But the other questions still remain ...
Posted: 10:13pm
26 Apr 2024
Hi @homa,
My specialist subject .
  homa said  Now the output of the print command shows an extra 0, which I don't understand! The HEX value also seems to be different from the one given in the manual for this type of controller (A4200101 vs 4200101).
It's a typo in the manual which I've brought up before. The correct code is &hA4200101 (and &hA4200000 for a Nunchuck).
  homa said  And I can only get the first controller (3) to work.
For the two port design the left-hand port is connected to I2C channel 3 and the right-hand one to I2C channel 1. Only the CMM2 Deluxe has a port connected to channel 2.
I believe your mistake is not providing the second parameter in all the calls to the CLASSIC(funct [, channel]) function, if you don't provide a second parameter then it assumes channel 3.
Edited 2024-04-27 08:25 by thwill
Posted: 09:49am
27 Apr 2024
homa
It's been a tough week,
and yesterday was definitely too late.
thank you tom!
matthias
© JAQ Software 2024
