ILI9488 drivers: MM2 and MM+
Turbo46
Posted: 12:29am 20 Mar 2021
I probably can't help but more information would be helpful.
Which driver are you using? Peter's or SC's? Did you follow the setup procedure from the article and set the screen parameters to suit the board as per the article?
SC does mention the problem with the MISO pin.
Bill
