ILI9488 drivers: MM2 and MM+
Posted: 12:03pm 06 Jan 2022
If you think interference is an issue it may be worth wrapping a piece of sheet metal in plastic and sliding it between the display and the MM+. May not work but easy enough to try. Cut up and flatten a tin can if you have nothing else.
