Local Time 13:11 21 Oct 2026 Privacy Policy
Forum Index : Guest Book : Greetings from new member
megantara
Posted: 07:49am 27 Sep 2014
Thank you for admitting me to this forum. Done my 1st vawt project, still under testing, gonna need to learn much more from you experienced builders.
My mill spec:
12 pole 9 coil, 6 wire out from stator for flexibility,
3 x 1mm wire 170 turns coils
1" x 2" x .5" N42
Lenz2 turbine (100cm height, 90cm diameter)Edited by megantara 2014-09-28
