Local Time 12:06 21 Oct 2026 Privacy Policy
Forum Index : Guest Book : a view of my set-up
Guests
Guest
Posted: 01:20pm 05 Jun 2004
Hi Glenn and fellow builders
I found a couple of pic's of the way I set up the stator on a hub with a "Hundai" front wheel hub and a steering wheel drive shaft's universal joint -quite compact .those uni joints - .
The system works ,but as Glenn mentioned,you don't get enough RPM's ,unless it blows a gale.
I also re-wired the stator -both series and parallel. and in the different wire sizes.
I haven't tried to get F&P stators from local Qld. repair outlets yet ,but the going price down Syd. was a carton of vb's for the whole machine-you discard of what you don't want -a couple of machines were perfect --just highlights our "throw-away" whitegoods enviroment.
You get -stator;rotor;shaft;bearings;bearing housing;hall sensor;some good electronics and springs Etc from the bowl support system. All in all some very handy parts .
Anyhow ,enough raving , I'll try and post the Pic's.
Bruce
