flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 140
Posted: 05:37am 22 Nov 2026
Glenn, A really minor one. I posted on the RP2350 Release thread some text and no matter what I tried, the closing square bracket disappeared after posting Some blue text then I put square brackets [LIKE THIS which definitely had a closing bracket when posted Regards Phil Edited 2026-11-22 15:38 by flip
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10147
Posted: 09:25pm 22 Nov 2026
Square brackets are probably trying to be interpreted by the forum, as some kind of formatting commands. When the forum CAN'T find a command that matches to anything you have put in the square brackets, it probably gives up and thus ignores the end ] bracket symbol, then just posts the remaining text.
It's probably not a good idea, to use square brackets in a post for anything OTHER then the supported formatting stuff like Bold, Italic, Underline, font size and colour.
Anything else with a square bracket is likely to trip up the forum software when it tries to process the post.
My 2c - might not be that, but I HAVE seen odd things happen when I myself, have tried to use square brackets for things in posts in the past. Now I use either {} or () - they work fine.
Glenn will know for sure. Edited 2026-11-23 07:28 by GrogsterSmoke makes things work. When the smoke gets out, it stops!
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3455
