Forum Index : Microcontroller and PC projects : I need a Pico 3 Computer at a reasonable price.
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 531 |
I was offered one here in America for 150 and I simply can't swing that. Seeing as. The first pico. I got was one of the originals and it was only like $40. In a case. Is anyone producing A run here in America. That I can get. Is it really that much more expensive to make? They call me Shai-Hulud (The maker) |
| hhtg1968 Guru Joined: 25/05/2023 Location: GermanyPosts: 312 |
why is it so expensive for you? because of the sending to usa? I could order one here in germany. but I do not now how exp. it will be to send it to the usa. |
| crazycloud Regular Member Joined: 20/08/2023 Location: United StatesPosts: 45 |
I just bought one from here for $150 https://www.rictech.nz/micromite-products |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3428 |
You may be able to build one cheaper using modules. Several TBS members have done so. Here is Mixtel90's version. Modular Pico Computer 3 |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 260 |
My thoughts - there does seem to be a need for an inexpensive, functional Pico 3 clone for folks in the US. On September 26, someone asked if there was a widely available RP2350B with all the GPIO's, WiFi and Webmite compatability and Peter replied with the Pimoroni Pico Lipo 2 XL W in this thread https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=19134 This module is available in the US for $24.95 https://www.pishop.us/product/pimoroni-pico-lipo-2-xl-w/?srsltid=AYCX9vKFJCRpiXIM4VXyAl5lgKut5Vn71NQfpUFjLnO1cUoZKYrzJJUVrNU If someone could design a carrier board for this module that includes the HDMI socket and components or a footprint for an Adafruit DVI Sock https://www.adafruit.com/product/5957?srsltid=AYCX9vJMS5M-Sij-BlnoagMv147GyBgAYXANuBadiir6HEeXfGOiYKPK along with the USB controller and USB sockets and all the other important circuits, this would be ideal. The USB purchaser could purchase the Pimoroni board here, avoiding all the import fees/tariffs. |
Yes, that's where I found it as well. But that's way above what I can afford right now. It seems odd that the pico version costs more than the Color maximite 2. It's too much. Hence my Topic. I'm looking for someone who's making a production run that can be Inexpensively Sent in America. They call me Shai-Hulud (The maker) |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9327 |
How about my PC3x design if you are willing to do some building? The components are cheap enough. Version 1.1 Basically it's a PGA2350 (or a CORE 2350B, there are 2 versions) with a Adafruit HDMI board, USB hub, SD card module, RTC and a few bits. Very little surface mount soldering. I know the PGA2350 version works. It is recognised as a real PC3 and is set up using OPTION RESET PICO COMPUTER 3 Version 2 can use the Waveshare CORE 2350B. I'm just building the prototype of this at the moment. This has the option of using a lot of surface mount, but you can still build most of it using through-hole. Construction details to be released soon. In all cases most of the components are from AliExpress and the boards are the cheapest price from JLCPCB. (You MUST download their JLCONE app and order using that to get the cheap price. It's not available via their web site now.) Here's the thread I'm currently playing with an idea for a Version 3, but that's all it is at the moment, an idea! Mick Zilog Inside! nascom.info for Nascom & Gemini |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4396 |
I think the cost issue occurs when the USA tariff/postal stuff hits, which happens especially with ready built units. Maybe Trump will change them again but to something saner. John |
