Local Time 07:27 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMag3
geodav
Posted: 02:44am 10 Nov 2026
Hi brains trust,
trying to interface a micromag3 magnetic sensor in MMBasic
This is an Altronics Z6300 purchase, aro Jim Rowes article in Silicon Chip Mag (June 2024 p64), which was encoded in Arduino language which I have not studied as
I  tend to a-{void} it,
However the module requires a reset  on pin 6 to clear previous data,  and an SPI interface at 9600 baud, with a 40 mS delay following its data request,
as Jim mentioned
followed by DOUT request for, respectively x,y,z magnetic fields as
byte Cmdx = B01100001 , and for Y ....01 and Z ....011.
followed by 16 bit data in...
Question is:  what code in MMBasic is required ?
Its ok I know the Pins
Pin x, high 1 for 10 uS ?
Open "Com1:9600, 9 bit" as #1   ?
and so on.
Not quite sure, and struggling here
regards
Geodav ( a newbie)
panky
Posted: 05:35am 10 Nov 2026
Hi GeoDav,
Welcome to TheBackShed forum.  To assist you, can you say what MicroMite you plan to use to talk to the MicroMag3 and also what version of MMBasic you have installed (there are some minor differences in the SPI usage between versions and models of MicroMite/PicoMite)? Also, does your MicroMite have a display and if so, what type?
Doug
The following is a translation by Gemini - it should be close to what you need - you will need to adapt it to your particular platform and MMBasic version.
' MicroMag3 Magnetic Sensor Control Program
' Translated to MMBasic for Micromite / Maximite / PicoMite
' Based on Silicon Chip June 2024 (Jim Rowe) and September 2024 updates
Option Explicit
' Define Pin Numbers (Adjust these to match your hardware layout)
Const pinSSNOT  = 1    ' Slave Select / Chip Select (Output)
Const pinRESET  = 2    ' Reset Line (Output)
Const pinDRDY   = 3    ' Data Ready Line (Input)
' Note: Hardware SPI pins (SDI, SDO, SCK) are automatically managed by SPI OPEN.
' Global tracking variables
Dim x_val, y_val, z_val
Dim heading_deg
Dim PI : PI = 4 * Atn(1)
' Initialise I/O Pins
SetPin pinSSNOT, DOUT : Pin(pinSSNOT) = 1 ' Set High (Idle)
SetPin pinRESET, DOUT : Pin(pinRESET) = 0
SetPin pinDRDY, DIN
' Initialise Hardware SPI channel
' Configures SPI Mode 0, Master, 8-bit data, and a safe clock speed (e.g., 100kHz)
SPI Open 100000, 0, 8
Print "MicroMag3 MMBasic Controller Initialised."
Print "-------------------------------------------"
' Main Executive Loop
 x_val = ReadAxis(1) ' Read X-Axis (Command offset 1)
 y_val = ReadAxis(2) ' Read Y-Axis (Command offset 2)
 z_val = ReadAxis(3) ' Read Z-Axis (Command offset 3)
 heading_deg = GetHeading(x_val, y_val)
 Print "X: "; x_val; " | Y: "; y_val; " | Z: "; z_val; " | Heading: "; heading_deg; " deg"
 Pause 2000 ' Update rate (2 seconds)
' FUNCTION: ReadAxis
' Pulses the MicroMag3, sends the axis command, and extracts 16-bit signed data
Function ReadAxis(axisNum)
 Local cmdByte, highByte, lowByte, rawWord
 ' Formulate the command byte based on the desired axis:
 ' Core measurement control configuration: division ratio /2048 (Bits: 01100)
 ' End bits map: X=01 (1), Y=10 (2), Z=11 (3)
 If axisNum = 1 Then
   cmdByte = &B00110001 ' X Axis
 ElseIf axisNum = 2 Then
   cmdByte = &B00110010 ' Y Axis
 Else
   cmdByte = &B00110011 ' Z Axis
 EndIf
 ' 1. Cycle Reset to begin measurement sequence
 Pin(pinRESET) = 1 : Pause 2 : Pin(pinRESET) = 0 : Pause 2
 ' 2. Select the sensor chip
 Pin(pinSSNOT) = 0 : Pause 2
 ' 3. Transmit the command byte via SPI
 SPI Write 1, cmdByte
 ' 4. Wait for the Data Ready line to clear/assert or fall back on a safe timeout
 ' Alternatively, if bypassing IO6 as per Silicon Chip, use a hard delay (e.g., Pause 15)
 Local timeout = 0
 While Pin(pinDRDY) = 0 And timeout < 500
   timeout = timeout + 1
   Pause 1
 Wend
 ' 5. Retrieve 16 bits of measurement data (2 Bytes)
 highByte = SPI(0)
 lowByte = SPI(0)
 ' Deselect the sensor
 Pin(pinSSNOT) = 1
 ' Combine bytes into a raw 16-bit integer
 rawWord = (highByte * 256) + lowByte
 ' Handle 16-bit two's complement sign conversion
 If rawWord >= 32768 Then
   ReadAxis = rawWord - 65536
 Else
   ReadAxis = rawWord
 EndIf
End Function
' FUNCTION: GetHeading
' Implements a manual 4-quadrant arctan safely using the standard MMBasic ATN()
Function GetHeading(x, y)
 Local angle
 ' Trap zero denominators cleanly to avoid division-by-zero math errors
 If x = 0 Then
   If y < 0 Then angle = PI / 2
   If y >= 0 Then angle = 3 * PI / 2
 Else
   ' Basic single-variable arctan
   angle = Atn(y / x)
   ' Quadrant correction logic matching the module's magnetic framework
   If x < 0 Then
     angle = PI - angle
   ElseIf x > 0 And y < 0 Then
     angle = -angle
   ElseIf x > 0 And y > 0 Then
     angle = (2 * PI) - angle
   EndIf
 EndIf
 ' Convert Radians to Degrees and normalise
 Local deg = angle * (180 / PI)
 If deg < 0 Then deg = deg + 360
 GetHeading = Int(degMod(deg))
End Function
' Helper to tightly clamp degrees inside a 0-359 compass bounds
Function degMod(d)
 Dim outD = d
 Do While outD >= 360 : outD = outD - 360 : Loop
 Do While outD < 0    : outD = outD + 360 : Loop
 degMod = outD
End Function
Use code with caution.
Essential Conversion Notes
1. SPI Implementation: Rather than bit-banging the individual pins, the translation implements MMBasic's native hardware SPI OPEN and SPI Write / SPI() stream functions. This reflects the design principles highlighted in the original Silicon Chip article.
2. Quadrant Math (ATN vs ATAN2): Because standard MMBasic does not natively expose a two-argument ATAN2 function, the GetHeading routine features safety boundaries for X = 0 along with explicit block filters to accurately isolate the four vector quadrants.
3. Data Handling: The code transforms raw High/Low incoming bytes back into standard signed variables using 16-bit two's complement logic explicitly parsed for standard BASIC limitations.
To tailor this exactly to your hardware setup, could you let me know:
• Which specific hardware platform are you using to run MMBasic (e.g., a custom Micromite, a Maximite, or a PicoMite)?
• Do you need to adjust the default SPI channel assignments or pin numbers inside the code to match how your module is wired?
Try without personalization
Silicon Chip
September 2024
September 9, 2024 — There is no ATAN2 function on the Micromite, so one has to use the ATN function and then work out which quadrant the heading lies ...
Geoff's Projects
MMBasic
MMBasic is a Microsoft BASIC compatible implementation running on hardware like Maximite (PIC32) and DOS, featuring floats, string...
MMBasic
BASIC Interpreter Overview - MMBasic
MMBasic is a full featured interpreter for the BASIC language. It's focus is on ease of use and rapid software development. This p...
Show all
Edited 2026-11-10 16:12 by panky
