Forum Index : Microcontroller and PC projects : Picomite 7 BTH MMedit 5.4.3
| guma1975 Newbie Joined: 13/01/2023 Location: PolandPosts: 18 |
mam pico2w wrzuciłem firmware rc08 sprawdzalem rc6 wersje 7 ale tak czy siak za pomoca mmedit 5.4.3 nie moge wyslac programuu niby sie wysyla jest ok aa list nic ...zeroooo jak napisze pirint w edytorze bezpisrednio jest ok.... eng wersion ================ 307 / 5 000 I have pico2w, I uploaded the RC08 firmware, I checked RC6 version 7, but I can't send the program using mmedit 5.4.3. It seems to be sending, it's OK, but the letter shows nothing...zerooooo. If I type "pirint" in the editor directly, it's OK... eng version, so it seems to have sent, but the letter shows nothing. Zero, the same in files... ot tak chyba |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6638 |
Using firmware PicoMiteRP2350BTHV7.00.00RC8, it works as normal > OPTION LIST PicoMiteBTH MMBasic RP2350A V7.00.00RC8 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION CPUSPEED (KHz) 200000 > C:\Users\Jim\Documents\myapps\maximite\apps\untitled.bas Uploading using: 'target port\COM5:115200 s\picomite Upload started NEW > AUTOSAVE N Progress: 1/4 Upload completed 1 Saved 67 bytes > Time taken: 1049mS RUN 1 Using firmware PicoMiteRP2350BTV7.00.00RC8, you have to connect using Bluetooth. That needs a driver for Windows. You might be able to configure a serial port as the console and use a TTL-USB adapter Jim VK7JH MMedit |
Oh, my apologies, you're quite right... I might not be "old" yet, but I’m definitely getting on in years... hee hee... But thank you all—programming in MMBasic made me feel like a little kid again! Best regards to everyone! |
