Local Time 12:39 19 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V7.00.00 Release
Posted: 03:11pm 18 Nov 2026
PicoMite V7.00.00 released
V7.00.00 is the first full release since V6.03.01 in August, and gathers everything from the 6.04.00 and V7 test releases since then. The attached pdf,PicoMite MMBasic V7.00.00: what has changed since V6.03.01,
PicoMite_V7.00.00_Changes_since_V6.03.01.pdf
lists every change by subject: what is new, what can affect an existing program, and what is fixed. The firmware for all 18 builds, the manual and the release notes are on GitHub: https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V7.00.00
Back up before you upgrade. Coming from V6.03.01 or earlier, every board is reset on its first boot of V7.00.00: the options return to their defaults, saved variables, the flash slots and program memory are cleared, and the A: drive is reformatted. Copy anything you need from A: to an SD card or your PC, and while the board still runs V6.03.01 save your settings with OPTION DISK SAVE "B:/myoptions.txt"; after upgrading, OPTION DISK LOAD "B:/myoptions.txt". V6.03.01 saved some values wrongly: after loading, give OPTION MOUSE SENSITIVITY again and recalibrate a touch screen if it is off. The PDF has the details.
The main changes
• Faster on every board. Against V6.03.01 on an RP2040 PicoMiteVGA, PETSCII Robots takes 16% less time per frame and Solar eclipse about 18% less. Every build also has more heap for variables, arrays and strings.
• A compiler on the RP2350. With OPTION COMPILE ON most of a program runs as native code, unchanged: you write and edit BASIC as before, and whatever the compiler cannot take runs as it always did.
• The language. Whole-array assignment (b%() = a%()), FUNCTIONs that return arrays, dimensions of a single element, LIBRARY LOAD to install a library from files (and a library in RAM on boards with PSRAM), BASE$, MATH CLAMP, MM.ERRLINE, and labels no longer counted towards the SUB and FUNCTION limit.
• The console. A HELP file, Print Screen (Ctrl-\), listings to a printer, serial port or file (LIST ALL #n and others), and a file manager that plays a track list.
• Graphics. Smaller SAVE IMAGE files and 32 DRAW3D objects; on the RP2350, SAVE PNG, PNG images of any size, FRAMEBUFFER MERGE on VGA and HDMI, and image slots in PSRAM.
• Sound. The BBC Micro's SOUND and ENVELOPE as PLAY BBC SOUND and PLAY BBC ENVELOPE, on every build.
• Files. ZMODEM transfers, and the A: drive on littlefs 2.11.3, which closes several ways a power failure could damage it.
• USB. A new USB host stack: hubs, USB drives (several hundred KB/s) and USB serial adapters are faster and more reliable, and more serial adapters and gamepads work.
• Bluetooth. On the Bluetooth host builds, Classic keyboards as well as BLE ones, speakers and headphones (OPTION AUDIO BLUETOOTH), and a Bluetooth serial device as COM7.
• Serial ports. A program's COM output is now sent before the ports close at its end, and CLOSE and FLUSH wait for the last character.
• Stepper (RP2350). Arcs blend with the moves around them, and the stepper works with I2S audio.
• mmb2csub. A tool that compiles one SUB or FUNCTION of your program into a CSUB, with no C to write.
• Two new builds. The PicoMitePC3 runs the Pico Computer 3 (HDMI, USB, WiFi and Bluetooth in one firmware, with a 256 KB program), and also the Pico Computer 2 and Olimex's RP2350pc, setting itself up for whichever it is on. The PicoMiteHDMIBTH brings Bluetooth keyboards, mice and speakers to the HDMI PicoMite.
Check your programs
A few changes can make a program that ran on V6.03.01 behave differently. They are all in the PDF's first chapter; the ones most likely to matter:
• -2^2 is now -4, as in mathematics (write (-2)^2 for 4).
• /* and */ must start their line, followed by a space, and /* cannot be used inside a SUB or FUNCTION; a program that breaks the rule is refused when it is loaded.
• Text after a SUB's bracketed arguments, as in MySub (a), b, is now an error rather than ignored.
• The same label twice is an error, names are limited to 31 characters, and BOUND() gives an error for a dimension an array does not have.
• OPTION TRACECACHE has gone, and MATH RANDOMIZE now gives the standard generator's sequences.
• A program that used nearly all of its memory may need OPTION SYMBOLS OFF as its first line. Five RP2350 builds take programs of up to 208 KB.
Known limitation
On the RP2350, STEPPER arcs (G2, G3) run faster than their feed rate away from the axes, up to 1.41 times at 45 degrees. Straight moves are not affected. It is GitHub issue #161 and will be fixed in a later release.
Thanks to everyone who tested the betas and release candidates. Please keep the reports coming, especially from existing programs.
karlelch
Posted: 05:52pm 18 Nov 2026
Wonderful - Thanks!!
atmega8
Posted: 06:19pm 18 Nov 2026
Very very AWESOME!!
THX
