Forum Index : Microcontroller and PC projects : Help needed with power circuit
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 375 |
Hi, I am interested in robots - driven by MMBasic - and I am currently working on a new version: A hexapod with 3DOF per leg that uses serial servos (12 V Waveshare ST3215 HS). I have a library written in MMBasic that can control all 18 servos and make the robot walk. But currently I am using a bench power supply. Eventually, I want to become mobile with a LiPo battery. I have mainly experience with "normal" servos and their power draw. I used Claude to work out the specifications of a power control board with the following requirements: - 2x connectors for serial bus input from a Waveshare Bus Servo Adapter - 6x connectors to a chain of 3 servos each (for the 6 legs) - a XT60 connector for the LiPo - a fuse - a soft-on circuit that can be controlled by a microcontroller (PiCo2) - there will be an external power switch between the battery and the board This is what Claude generated (edited for clarity by me): ![]() Anyone experience with such circuits? Could that work? Thanks Thomas |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9393 |
I have no experience with servos whatsoever, but from an electronics point of view I would say that that circuit makes sense. Making the J2 input high causes the battery to be connected to the servos and the bank of 470uF capacitors. This supply will ramp up, not switch on suddenly. When the servos operate the current is supplied initially by the capacitor bank, the capacitors recharging from the battery while the servos are stationary. Commands from the two servo control signals are merely paralleled across three servos each so the three will move together. Taking the J2 input low again disconnects the battery from the circuit. There will be residual charge in the capacitor bank, I suppose, but that doesn't matter. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3458 |
For soft start I think C1 + R4 are placed incorrectly. For a simple resistive load they would work as they are but when the battery is first connected the capacitor bank is at 0V with just a few milliohms resistance. I think they should go from gate to source (+BATT) and C1 may need to be bigger. Q1 could still get hot as the capacitor bank charges so a heatsink with thermal mass (thick aluminium or copper) may help. Currently they will momentarily turn Q1 fully on as soon as the battery is connected. The peak current into the capacitor bank might be enough to damage Q1 or the battery before the fuse has time to blow. Edited 2026-11-20 07:38 by phil99 |
It's a circuit to model, but not tonight. Because the cap bank is discharged the lower side of C1 is also low. For Q1 to turn on the gate has to get low enough. C1 is already charged to 12V via R3 so the gate is held up by that voltage via R4. C1 now has to discharge via (R2+R4) to (12-Vgs) before Q1 opens. R2 and C1 are fairly high so this will take a little time. True, Q1 will start to dissipate as soon as Vgs is exceeded, but that may not be for long at that point. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Not when you first plug the battery in. Then C1 has 0V across it, briefly pulling the gate low through the capacitor bank. For modeling put a switch in the battery line and see what the peak current is when you close it. Maybe it is possible to also see how much energy is in the pulse that the MOSFET must absorb. That should reveal whether it is a problem or not. Edited 2026-11-20 10:00 by phil99 |
Good point - I hadn't looked at when the battery is first connected. I reckon you've got almost 100ms of virtually dead short across the battery. That's not good... As I've said, I have no experience of servos. Are the caps even necessary? They are motors, not solenoids. The impedance of a LiPo battery is very low. A good mosfet will have RDSon of 50mΩ or even less. The tiny little SOT23 AO3140 for example can manage that with Id of 4A. Just don't look for TO92 packages that can do anything useful. . Edited 2026-11-20 18:57 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks Mixtel90 and Phil99! These are digital serial servos; they listen to a simple 1-wire serial bus for packages and respond to their ID. But I agree, the labelling of two serial busses is confusing, because the Waveshare board which translates the COM signals of the Pico2 to the servo bus signals has two connectors with the bus shared. I wanted to switch to these servos because they can respond to complex motion commands and report on their status, such as position, current, voltage, temperature, load ... That'd be great! I have no experience with that ... Thanks for this hint. I gave it back to Claude and it agreed, but suggested a different solution: An additional C8 between source and gate and a different value for C1: ![]() I am wondering that too. This was a recommendation by Claude. The servos are said to feature local voltage regulation, and all sorts of protection (overcurrent, overvoltage, and thermal shutoff), though it is hard to get a circuit diagram. Best Thomas |
The circuit looks good now. With all that perhaps 47 to 100µF close to each servo will be enough. |
Thanks - yes, I'll try that. Best Thomas |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6289 |
Hi, The pinout on the servo connectors is wrong (1-3 swapped). See : ![]() Not sure you need all the 470uF E-caps. The battery is low impedance, the FET is only 4 mohm. Maybe one is sufficient. Just to get rid of the short spikes. One 470uF may be better that 6 small ones (ESR wise). Volhout Edited 2026-11-20 20:32 by Volhout PicomiteVGA PETSCII ROBOTS |
Hi Volhout, The pinout on the servo connectors is wrong (1-3 swapped). Thanks for the schematic - where did you get this from? In KiCad, it is the other way around: ![]() ![]() Ok, thanks! Best Thomas Edited 2026-11-21 00:20 by karlelch |
| Bowden_P Senior Member Joined: 20/03/2019 Location: United KingdomPosts: 177 |
Hi Thomas, Regardles of the numbering of pins in a socket or diagram, look at the ribbon cable on the servo you have. Standard RC servos have a common signal order of control signal, +ve supply, ground. The middle wire is coloured red or orange - +ve supply, the brown or black wire - ground, the control wire - often yellow or white. While the ST3215 HS isn't quite a run-of-the-mill servo, my guess is it will still have the same ribbon colours. The connecting socket is polarised for this servo, look at :- www.waveshare.com/st3215-hs-servo-motor.htm about a third way down for the serial scheme. With best regards, Paul. p.s.See also :- https://files.waveshare.com/upload/d/d3/Bus_servo_control_circuit.pdf Edited 2026-11-21 03:13 by Bowden_P Nothing so constant as change. |
The biggest problem might be the locked rotor current of 2.4A *per servo*. Some sort of current sensing and supply disconnection or limiting may be required. Found a manual Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Paul, Standard RC servos have a common signal order of control signal, +ve supply, ground. The middle wire is coloured red or orange - +ve supply, the brown or black wire - ground, the control wire - often yellow or white. Yes, the ST3215 cables are coded the same. I looked at the cables I have and it matches the pins in the pictures I showed in my previous post. But I see that in my circuit, the serial input connector is not correctly wired. Thanks! It is confusing that Waveshare names 1=data pin, whereas in the KiCad footprint of the matching connector, 1=gnd ... Best Thomas |
The manual suggests that the supplied lead is white/red/black, so signal/+/GND makes sense. For normal PCB connectors the square pad is defined as pin 1. I always try to make that one GND. Waveshare drawings are not always to be trusted. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
I looked at the waveshare website. The pinout on the servo connectors is wrong (1-3 swapped). Thanks for the schematic - where did you get this from? In KiCad, it is the other way around: ![]() ![]() Ok, thanks! Best Thomas PicomiteVGA PETSCII ROBOTS |
I seriously doubt if the caps are needed. Maybe 100nF to reduce noise. The mosfet is rated for 90A continuous and I like to think that the fuse will go before the mosfet is asked to exceed that by much. :) If it doesn't your battery is in serious trouble. Mick Zilog Inside! nascom.info for Nascom & Gemini |
