Forum Index : Microcontroller and PC projects : Feature request: UTF-8 on the serial console(and Font 1 as a TrueType)
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 781 |
1_byte-mode_ISO8859-1: ![]() 2_utf8demo_UTF-8: ![]() 3_utf8demo_PicoCalc_LCD: ![]() Feature request: UTF-8 on the serial console (and Font 1 as a TrueType font) Hi Peter, my wish is this for the CMM2 with firmware 8, but it would be a feature for MMBasic in general: the CMM2 and the PicoMite family share Font 1 (font1.h). I made a TrueType copy of it, so a PC terminal shows exactly what the screen shows. That works today for bytes 32-127 and 160-255. Bytes 128-159 stay dark: Tera Term 5 treats them as C1 control codes and drops them, whatever the font. In UTF-8 mode a terminal could show everything, including real UTF-8 text (SQLite data, for example). But a single byte 128-255 is not valid UTF-8, so today the CLI, the editor and every PRINT CHR$(128...255) disappear in a UTF-8 terminal. Suggestion (the name is only a suggestion): OPTION SERIAL UTF8 ON | RAW | OFF - ON - each byte sent to the serial console goes out as the UTF-8 of the character Font 1 draws for it (one table, 130 entries). No program has to change; the terminal shows the same as the screen. - RAW - the program writes UTF-8 itself. The serial port gets it unchanged; the screen shows the Font 1 character from the table, or a dot. One character = one cell on both sides. - OFF - as today. The screen (VGA, HDMI, LCD) does not change in any mode. The attached ZIP has the details (feature-request.txt), the table, both fonts, three screenshots (Tera Term and the PicoCalc LCD) and utf8demo.bas, which simulates ON and RAW in BASIC with OPTION CONSOLE switching. So far tested on the PicoCalc only; the CMM2 test is still to come. Matthias utf8-terminal.zip |
