Forum Index : Microcontroller and PC projects : Retromax 2 Gen 1 or 2?
| gadgetjack Senior Member Joined: 15/07/2016 Location: United StatesPosts: 246 |
I have a CircuitGizmo Retromax 2 board I broke out since the new software is out. What generation board is it? I tried the Amiga emulator and it says it needs a Gen 2 or newer. I am guessing it is Gen 1, but what is the difference from a Gen 2? How does it know when software runs? Just wondering... (sorry about the blank message , dog bumped my hand and off it went) |
| Wölfi Regular Member Joined: 14/10/2026 Location: GermanyPosts: 55 |
The Colour Maximite 2 User Manual (MMBasic Ver. 6.00.00) provides the following information about the G2 on page 12: 1. It uses a larger RAM chip 32MB vs 8MB) which is used to support the top VGA resolution of 1920x1080 pixels, 24-bit colour depth and provide more RAM for BASIC programs. 2. An 8-bit digital to analog converter is used for each colour channel allowing the Generation 2 computerto display true colour 24-bit images. So you can identify yours by checking whether it supports Full HD and has 32 MB of RAM. ----- PPS: https://circuitgizmos.com/gizmo-store/RetroMax-CGs-Color-Maximite-2-p241231864/ Retromax 1: Extremely fast with 516KB of program memory (about 25,000 lines) and 5MB general purpose RAM. Rock solid VGA output with five resolutions from 1024x768 pixels to 240x216 pixels with up to 16-bit color (65536 colors). Retromax 2: RetroMax 2.3a is "Generation 2" The RetroMax Generation 2 design is fully compatible with the first generation (RetroMax 1.4a), however, it has a few extra features: - An additional 1920 x 1080 pixel VGA mode. - 24-bit color output (in addition to the standard 8, 12, and 16-bit modes). - Extra RAM for BASIC programs (24MB vs 8MB). So I guess a Retromax 2 should be a full CMM2 G2 and it depends on whether your board matches these and probably some more specifications exactly. Edited 2026-11-21 08:47 by Wölfi |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6643 |
> print mm.device$ What reply do you get? If it is CMM2 G2 it will give Colour Maximite 2 G2 Jim VK7JH MMedit |
It just says Colour Maximite 2. I guess it is a gen 1. Looks like a 8MB chip on it. |
Yep, It's a Gen 1 clone VK7JH MMedit |
Are you sure it´s a Retromax 2 and not 1? |
Load the latest V8 beta. The same file is used for all versions on CMM2 so there should be no problems. Then: > print mm.device$ Colour Maximite 2 > mode 16 G2 resolution only > If MODE 16 fails, that confirms that the firmware thinks it is a Gen 1 VK7JH MMedit |
You are right! It is a gen 1. |
