Local Time 12:38 25 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V8.00.00 betas: Apps and more
Posted: 12:37pm 23 Nov 2026
PicoMite V8.00.00b1: the first beta of V8
V8 starts from V7.00.00 and adds programs written in C and C++ to the PicoComputer 3, and raster effects to the VGA and HDMI builds. This is a beta for testing: V7.00.00 stays the current release. The firmware for all 18 builds, the manual, the release notes and the first apps are on GitHub: https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V8.00.00b1
Two builds reset coming from V7.00.00. The PicoMitePC3 and the PicoMiteRP2350VGAUSB have moved their flash region to make room for the new features. At their first boot of V8 their options return to their defaults, and their flash slots and program memory are cleared. Save the options first with OPTION DISK SAVE "B:/myoptions.txt" and load them again afterwards with OPTION DISK LOAD "B:/myoptions.txt". On the PicoMitePC3, pair your Bluetooth keyboards and speakers again and give it its WiFi network again. On a board with 4 MB of flash, such as a Pico 2, the A: drive is reformatted too; on the PicoComputer 3 it is kept. Every other build keeps everything.
What is new
• Programs in C and C++ on the PicoMitePC3. RUN "name.app" runs a program built separately from the firmware, at full speed from the PSRAM, and returns to MMBasic when it ends. The firmware lends it its files, display, keyboard, gamepads, mouse, sound, I/O pins and network. The services have the Colour Maximite 2's names, so the same source builds for either machine. The SDK is in the firmware's tools/sdk folder, with an example for each group of services.
• The first apps. Three of the Colour Maximite 2's apps already run on the PicoComputer 3. They are in PicoMite_Programs-8.00.00b1.zip on the release page: copy its folders to the root of the SD card, and its README tells you how to start each one.
    ◦ NES: the Colour Maximite 2's NES emulator, at about 55 frames a second, with two free games, Nova the Squirrel and Thwaite.
    ◦ Doom: with Freedoom's free game data, at 28 frames a second in its timedemo, with its sound effects (no music).
    ◦ MicroPython 1.29, with the PicoComputer 3's display, keyboard, mouse, sound, files, pins and network. Every example in Programming the Pico Computer 3 runs, except those for the RGB512 and RGB1024 modes.
• USER modules on the PicoMitePC3. USER LOAD adds commands and functions of your own to MMBasic, written in C with the same SDK. Their errors are MMBasic errors, so ON ERROR SKIP catches them.
• FRAMEBUFFER WARPH and WARPV (VGA and HDMI, MODE 2 to 5). These copy a framebuffer with every row (WARPH) or column (WARPV) moved by its own offset, taken from an integer array. They give the old arcade raster effects: a racing road with curves and hills, parallax scrolling, rippling water and reflections. At 315 MHz a whole 320x240 screen takes 0.9 ms with WARPH and 1.6 to 4.7 ms with WARPV. The Game Development Guide has worked examples, and Bas/warp_demo.bas in the repository shows them all at full frame rate.
• Shapes at the edge of the screen. On every display, a shape that runs off an edge no longer leaves a line of pixels along that edge.
So far this beta has been tested on the PicoComputer 3. The other builds compile cleanly, but the edge-clipping fix touches every display driver, so reports from other boards and displays are especially welcome.
Warp Demo - please try it
' warp_demo.bas - FRAMEBUFFER WARPH and WARPV: every row or column of a picture moved by its own offset
' PicoMite V8, VGA or HDMI, RP2350 (it uses framebuffers F and 2 and both layers), MODE 2 at 320x240.
'  1. 240 stars, each row at its own speed; a logo waving in the layer; a sine scroller in the top layer
'  2. a lake from day to dusk: parallax hills, and a reflection that ripples more the nearer it is
'  3. a road in the style of the arcade racers: curves, hills, kerbs, and the mountains panning
'  4. the credits, waved both ways (a WARPH into a WARPV)
' Each picture melts away column by column into the next. Any key ends it.
' No per-pixel BASIC in the frame loops: each layer is one command, and the offset tables are made
' with MATH (SCALE, ADD, C_ADD, CLAMP) or animated with the phase argument.
OPTION EXPLICIT
OPTION DEFAULT INTEGER
MODE 2
IF MM.HRES <> 320 OR MM.VRES <> 240 THEN
 MODE 1
 PRINT "This demo needs MODE 2 at 320x240 (OPTION RESOLUTION 640x480)"
 END
ENDIF
CONST W = 320, H = 240
DIM cl(15), quit, i
FOR i = 0 TO 15 : cl(i) = MAP(i) : NEXT  ' the colour that draws in each of the 16 palette slots
DIM rbw(7) = (&HFF2020, &HFF9000, &HFFF000, &H30FF30, &H20E0FF, &H3070FF, &HA040FF, &HFF40C0)
FRAMEBUFFER CREATE
FRAMEBUFFER CREATE 2
FRAMEBUFFER LAYER
FRAMEBUFFER LAYER TOP
FRAMEBUFFER WRITE N
DO
 scene1 : IF NOT quit THEN melt
 IF NOT quit THEN scene2
 IF NOT quit THEN scene3
 IF NOT quit THEN scene4
LOOP UNTIL quit
FRAMEBUFFER CLOSE
MAP RESET
MODE 1
PRINT "FRAMEBUFFER WARPH and WARPV demo ended"
END
' ---------------------------------------------------------------- 1: stars, logo, scroller
SUB scene1
 LOCAL lay(119), spd!(H - 1), so(H - 1), sr(H - 1), sco(0), ssr(0), sw(159), lw(159)
 LOCAL pal(15) = (0, &H404060, &H9090B0, &HFFFFFF, 0, 0, 0, 0, 0, 0, 0, 0, &HFFE860, 0, &H181830, &HFFFFFF)
 LOCAL x, y, k, c, fr, spos, nextc, cx, cyc
 LOCAL m$ = "    FRAMEBUFFER WARPH + WARPV ...  EACH ROW OR COLUMN MOVED BY ITS OWN OFFSET FROM AN INTEGER ARRAY ...  "
 m$ = m$ + "240 STARS: ONE WARPH ...  THE LOGO: ONE WARPV ...  THIS TEXT: A WARPH TO SCROLL IT, A WARPV TO WAVE IT ...  "
 m$ = m$ + "ONE COMMAND A LAYER ...   "
 FOR k = 4 TO 11 : pal(k) = rbw(k - 4) : NEXT
 setpal pal(), 0 : MAP SET
 FRAMEBUFFER WRITE L : CLS : FRAMEBUFFER WRITE T : CLS
 FRAMEBUFFER WRITE 2 : CLS cl(0)
 ' F: stars in rows 0-119, the scroller's strip in 120-151, the logo in 152-226, nothing below
 FRAMEBUFFER WRITE F : CLS cl(0)
 FOR y = 0 TO 119
   lay(y) = 1 + INT(RND * 3)
   x = INT(RND * (W - 1))
   PIXEL x, y, cl(lay(y))
   IF lay(y) = 3 THEN PIXEL x + 1, y, cl(3)
 NEXT
 FOR y = 0 TO H - 1
   sr(y) = y MOD 120
   spd!(y) = lay(sr(y)) ^ 1.7 * 0.45 + RND * 0.2
 NEXT
 TEXT 160, 162, "FRAMEBUFFER  WARPH  +  WARPV", "CT", 1, 1, cl(15), -1
 TEXT 163, 179, "WARP", "CT", 1, 4, cl(14), -1
 TEXT 160, 176, "WARP", "CT", 1, 4, cl(15), -1
 PIXEL 0, 239, cl(15) : k = PIXEL(0, 239) : PIXEL 0, 239, cl(0)  ' what PIXEL() reads for slot 15
 FOR y = 176 TO 223  ' the logo in eight bands of colour, which MAP then cycles
   c = 4 + ((y - 176) \ 6) MOD 8
   FOR x = 96 TO 226
     IF PIXEL(x, y) = k THEN PIXEL x, y, cl(c)
   NEXT
 NEXT
 FRAMEBUFFER WRITE N
 FOR k = 0 TO 159
   sw(k) = -50 + 20 * SIN(2 * PI * k / 80)  ' the scroller's wave: 2 periods, so the phase can turn it
   lw(k) = 156 + 4 * SIN(2 * PI * k / 80)   ' the logo's
 NEXT
 ssr(0) = 120
 DO
   fr = fr + 1
   MATH SCALE spd!(), -fr, so()
   spos = spos + 2 : sco(0) = -spos
   DO WHILE nextc * 16 < spos + W + 16  ' the next letter into the strip, one cell ahead of the screen
     cx = (nextc * 16) MOD W
     FRAMEBUFFER WRITE F
     BOX cx, 120, 16, 32, 0, cl(0), cl(0)
     TEXT cx, 124, MID$(m$, (nextc MOD LEN(m$)) + 1, 1), "LT", 1, 2, cl(12), -1
     FRAMEBUFFER WRITE N
     nextc = nextc + 1
   LOOP
   IF fr <= 25 THEN
     setpal pal(), fr / 25
   ELSEIF fr MOD 3 = 0 THEN
     cyc = cyc + 1
     FOR c = 0 TO 7 : MAP(4 + c) = rbw((c + cyc) MOD 8) : NEXT
   ENDIF
   IF fr <= 25 OR fr MOD 3 = 0 THEN MAP SET ELSE FRAMEBUFFER WAIT  ' MAP SET waits for the frame too
   FRAMEBUFFER WARPH F, N, so(), 1, 0, , , , sr()        ' the stars
   FRAMEBUFFER WARPH F, 2, sco(), 32, 100, , , , ssr()   ' the strip, scrolled, to rows 100-131 of 2
   FRAMEBUFFER WRITE 2
   BOX 0, 100, 16, 32, 0, cl(0), cl(0) : BOX W - 16, 100, 16, 32, 0, cl(0), cl(0)
   FRAMEBUFFER WRITE N
   FRAMEBUFFER WARPV 2, T, sw(), 2, 0, fr * 2            ' waved into the top layer
   FRAMEBUFFER WARPV F, L, lw(), 2, 0, fr, -1            ' the logo waved into the layer
   IF INKEY$ <> "" THEN quit = 1
 LOOP UNTIL quit OR fr > 1500
END SUB
' ---------------------------------------------------------------- 2: the lake
SUB scene2
 LOCAL day(15) = (0, &H3070D0, &H5090E0, &H80B0F0, &HB0D0F0, &HD8E8F8, &HFFFFE0, &H6080A8, &H405878, &H183820, &H90B0D0, &HB8D0E8, &HFFFFFF, &H385068, &H102818, &H2850A0)
 LOCAL dusk(15) = (0, &H201848, &H503070, &HA04870, &HF07050, &HFFB040, &HFFE8A0, &H402850, &H281838, &H081008, &HA05050, &HC08848, &HFFE0A0, &H301830, &H040804, &H101838)
 LOCAL night(15) = (0, &H000010, &H080828, &H181838, &H302048, &H603050, &HC08060, &H101020, &H080810, &H000000, &H201828, &H402838, &H806050, &H080810, &H000000, &H000008)
 LOCAL tcn(9) = (0, 1, 2, 3, 4, 5, 6, 7, 8, 9)
 LOCAL tcr(9) = (0, 15, 15, 10, 10, 11, 12, 13, 13, 14)
 LOCAL bgo(0), hlo(0), hlr(0), rbr(89), rhr(49), rwo(89), hwo(49)
 LOCAL wsn!(89), wcs!(89), wa!(89), wb!(89), wc!(89), hsn!(49), hcs!(49), ha!(49), hb!(49), hc!(49)
 LOCAL k, fr, ph!, amp!, f!, br!, gl!
 lerppal day(), dusk(), 0, 0
 MAP SET
 FRAMEBUFFER WRITE 2 : CLS cl(0) : drawland tcn()     ' the land in 2 (hills in rows 150-199)
 FRAMEBUFFER WRITE F : CLS cl(0) : drawland tcr()     ' and in the water's colours in F
 FRAMEBUFFER WRITE N
 hlr(0) = 150
 FOR k = 0 TO 89
   rbr(k) = 149 - k                ' the reflection is the land upside down
   amp! = 0.3 + k * 0.075          ' ripples grow towards the viewer...
   ph! = 9 * SQR(k + 1)            ' ...and spread out
   wsn!(k) = amp! * SIN(ph!) : wcs!(k) = amp! * COS(ph!)
   IF k < 50 THEN rhr(k) = 199 - k : hsn!(k) = wsn!(k) : hcs!(k) = wcs!(k)
 NEXT
 DO
   fr = fr + 1
   bgo(0) = -fr \ 4 : hlo(0) = -(fr * 7) \ 10
   ' amp*sin(ph + wt) = amp*sin(ph)*cos(wt) + amp*cos(ph)*sin(wt): two MATH SCALEs and a C_ADD
   MATH SCALE wsn!(), COS(fr * 0.12), wa!() : MATH SCALE wcs!(), SIN(fr * 0.12), wb!()
   MATH C_ADD wa!(), wb!(), wc!() : MATH ADD wc!(), bgo(0), wa!() : MATH SCALE wa!(), 1, rwo()
   MATH SCALE hsn!(), COS(fr * 0.12), ha!() : MATH SCALE hcs!(), SIN(fr * 0.12), hb!()
   MATH C_ADD ha!(), hb!(), hc!() : MATH ADD hc!(), hlo(0), ha!() : MATH SCALE ha!(), 1, hwo()
   IF fr MOD 4 = 1 THEN  ' the sky from day to dusk to night
     br! = MIN(fr / 25, 1)
     f! = fr / 700
     IF f! < 1 THEN lerppal day(), dusk(), f!, br! ELSE lerppal dusk(), night(), MIN(f! - 1, 1), br!
   ENDIF
   gl! = 150 + RND * 105 : MAP(12) = RGB(gl!, gl! * 0.85, gl! * 0.45)  ' the sun glints on the water
   MAP SET                                                 ' (and the frame sync)
   FRAMEBUFFER WARPH 2, N, bgo(), 150                      ' sky and mountains, slowly
   FRAMEBUFFER WARPH 2, N, hlo(), 50, 100, , , 0, hlr()    ' hills and trees, faster, over them
   FRAMEBUFFER WARPH F, N, rwo(), 1, 150, , , , rbr()      ' their reflection, rippling
   FRAMEBUFFER WARPH F, N, hwo(), 1, 150, , , 0, rhr()
END SUB
' the land, its colours through tc(): sky in rows 0-149, hills and trees (seen at 100-149) in 150-199
SUB drawland tc()
 LOCAL x, y, b, j, r, tx, tb, th
 FOR y = 0 TO 149
   b = y \ 30
   IF (y MOD 30) >= 22 AND (y MOD 2) = 0 AND b < 4 THEN b = b + 1
   LINE 0, y, W - 1, y, 1, cl(tc(1 + b))
 NEXT
 CIRCLE 210, 112, 15, 1, 1, cl(tc(6)), cl(tc(6))
 FOR x = 0 TO W - 1  ' ridges whose sines repeat every 320 pixels, as the rows wrap
   r = 98 + 14 * SIN(2 * PI * x / W * 2 + 0.5) + 7 * SIN(2 * PI * x / W * 5 + 1.3) + 3 * SIN(2 * PI * x / W * 11)
   LINE x, r, x, 149, 1, cl(tc(7))
   r = 124 + 8 * SIN(2 * PI * x / W * 3 + 2) + 4 * SIN(2 * PI * x / W * 7 + 0.2)
   LINE x, r, x, 149, 1, cl(tc(8))
   r = 139 + 3 * SIN(2 * PI * x / W * 4 + 1)
   LINE x, r + 50, x, 199, 1, cl(tc(9))
 NEXT
 RANDOMIZE 77  ' the same trees in both copies, each wholly on the screen (a shape drawn partly off it
 FOR j = 1 TO 30 ' leaves a line in column 0, which the warp then shows)
   th = 8 + INT(RND * 16) : tx = th + INT(RND * (W - 2 * th)) : tb = 140 + INT(RND * 8)
   TRIANGLE tx, tb - th + 50, tx - th \ 3, tb + 50, tx + th \ 3, tb + 50, cl(tc(9)), cl(tc(9))
 NEXT
 RANDOMIZE TIMER
END SUB
' ---------------------------------------------------------------- 3: the road
SUB scene3
 LOCAL pal(15) = (0, &H1850B8, &H3C80D8, &H88C0F0, &H5868A0, &HF0F0FF, &H48B848, &H389038, &H9C9C9C, &H888888, &HE02020, &HF0F0F0, &HFFFFFF, &HD01818, &H202028, &HFFD040)
 LOCAL zz(119), cp!(69), sp!(69), t1!(69), t2!(69), t3!(69), ro(69), rm(69), sko(0), skr(0)
 LOCAL x, y, r, s, k, j, cx, cy, fr, hy, rr, dist, yy
 LOCAL hw!, kw!, lnw!, curve!, camx!, pan!
 ' F: the road, rows 0-119 with light segments (red kerbs, lane line), 120-239 dark ones (white kerbs)
 FRAMEBUFFER WRITE F
 FOR r = 0 TO 119
   hw! = 2 + r * 0.95 : kw! = 1 + r * 0.13 : lnw! = r * 0.025
   zz(r) = 2400 \ (r + 6)          ' how far away road row r is
   FOR s = 0 TO 1
     yy = r + 120 * s
     LINE 0, yy, W - 1, yy, 1, cl(6 + s)
     LINE 160 - hw! - kw!, yy, 160 + hw! + kw!, yy, 1, cl(10 + s)
     LINE 160 - hw!, yy, 160 + hw!, yy, 1, cl(8 + s)
     IF s = 0 THEN LINE 160 - lnw!, yy, 160 + lnw!, yy, 1, cl(12)
   NEXT
 NEXT
 ' 2: sky, clouds and mountains, the horizon at row 139; grass below it to row 179
 FRAMEBUFFER WRITE 2 : CLS cl(1)
 FOR y = 20 TO 139
   k = (y - 20) \ 40
   IF ((y - 20) MOD 40) >= 30 AND (y MOD 2) = 0 AND k < 2 THEN k = k + 1
   LINE 0, y, W - 1, y, 1, cl(1 + k)
 NEXT
 FOR j = 1 TO 7  ' clouds, each wholly on the screen (as the trees in drawland)
   cx = 24 + INT(RND * (W - 80)) : cy = 35 + INT(RND * 40)
   CIRCLE cx, cy, 6, 1, 2.2, cl(5), cl(5) : CIRCLE cx + 14, cy - 4, 8, 1, 2, cl(5), cl(5)
   CIRCLE cx + 30, cy, 6, 1, 2.2, cl(5), cl(5)
 NEXT
 FOR x = 0 TO W - 1
   r = 114 + 11 * SIN(2 * PI * x / W * 3 + 0.4) + 8 * SIN(2 * PI * x / W * 7 + 2)
   LINE x, r, x, 139, 1, cl(4)
   IF r < 108 THEN LINE x, r, x, r + 2, 1, cl(5)
 NEXT
 BOX 0, 140, W, 40, 0, cl(6), cl(6)
 ' L: the car, and the speed
 BOX 110, 228, 100, 8, 0, cl(14), cl(14)
 BOX 112, 212, 18, 20, 0, cl(14), cl(14) : BOX 190, 212, 18, 20, 0, cl(14), cl(14)
 BOX 116, 196, 88, 26, 0, cl(13), cl(13)
 BOX 132, 183, 56, 14, 0, cl(13), cl(13) : BOX 136, 186, 48, 9, 0, cl(14), cl(14)
 BOX 110, 191, 100, 4, 0, cl(14), cl(14)
 BOX 120, 201, 16, 6, 0, cl(15), cl(15) : BOX 184, 201, 16, 6, 0, cl(15), cl(15)
 BOX 150, 210, 20, 6, 0, cl(11), cl(11)
 BOX 2, 3, 124, 16, 0, cl(14), cl(14)  ' a dark panel, so the clouds behind cannot hide it
 TEXT 6, 6, "SPEED", "LT", 1, 1, cl(12), cl(14)
 FRAMEBUFFER WRITE N
 FOR k = 0 TO 69
   cp!(k) = (1 - k / 69) ^ 2 * 110     ' a curve moves the far rows most
   sp!(k) = (k + 1) / 70               ' the car's place across the road, the near rows most
 NEXT
 DO
   fr = fr + 1
   curve! = 1.3 * SIN(fr * 0.009) + 0.7 * SIN(fr * 0.023 + 1)
   camx! = curve! * 12 + 6 * SIN(fr * 0.041)
   hy = 120 + 16 * SIN(fr * 0.013)     ' the horizon: hills
   dist = dist + 5
   pan! = pan! - curve! * 1.4
   sko(0) = pan! : skr(0) = 140 - hy    ' the sky as one band, moved with the horizon
   MATH SCALE cp!(), curve!, t1!() : MATH SCALE sp!(), -camx!, t2!()
   MATH C_ADD t1!(), t2!(), t3!() : MATH SCALE t3!(), 1, ro()
   FOR k = 0 TO 69  ' each 2-row band: its road row (squeezed by the hill) in the light or dark copy
     y = 100 + 2 * k
     IF y < hy THEN
       rm(k) = -1
     ELSE
       rr = MIN((y - hy) * 120 \ (240 - hy), 118)
       rm(k) = rr + 120 * (((zz(rr) + dist) >> 4) AND 1)
     ENDIF
   NEXT
   IF fr <= 25 THEN setpal pal(), fr / 25
   IF fr MOD 10 = 0 THEN
     FRAMEBUFFER WRITE L
     TEXT 54, 6, STR$(240 + INT(20 * SIN(fr * 0.02)), 3) + " km/h", "LT", 1, 1, cl(15), cl(14)
     FRAMEBUFFER WRITE N
   ENDIF
   IF fr <= 25 THEN MAP SET ELSE FRAMEBUFFER WAIT
   FRAMEBUFFER WARPH 2, N, sko(), 140, 0, , , , skr()     ' sky and mountains
   FRAMEBUFFER WARPH F, N, ro(), 2, 100, , , , rm()       ' the road
 LOOP UNTIL quit OR fr > 2000
END SUB
' ---------------------------------------------------------------- 4: the credits
SUB scene4
 LOCAL pal(15) = (0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, &H404040, &HFFFFFF)
 LOCAL hx(239), vy(159), k, fr, cyc, c
 TEXT 160, 30, "FRAMEBUFFER", "CT", 1, 2, cl(4), -1
 TEXT 160, 58, "WARPH  &  WARPV", "CT", 1, 2, cl(6), -1
 TEXT 160, 100, "every row or column of a picture", "CT", 1, 1, cl(15), -1
 TEXT 160, 116, "moved by its own offset,", "CT", 1, 1, cl(15), -1
 TEXT 160, 132, "read from an integer array", "CT", 1, 1, cl(15), -1
 TEXT 160, 164, "PicoMite V8", "CT", 1, 2, cl(8), -1
 TEXT 160, 206, "press any key", "CT", 1, 1, cl(14), -1
 FRAMEBUFFER WRITE N
 FOR k = 0 TO 239 : hx(k) = 7 * SIN(2 * PI * k / 80) : NEXT
 FOR k = 0 TO 159 : vy(k) = 6 * SIN(2 * PI * k / 80) : NEXT
 DO
   fr = fr + 1
   IF fr <= 25 THEN
   ELSEIF fr MOD 4 = 0 THEN
     cyc = cyc + 1
   ENDIF
   IF fr <= 25 OR fr MOD 4 = 0 THEN MAP SET ELSE FRAMEBUFFER WAIT
   FRAMEBUFFER WARPH F, 2, hx(), 1, 0, fr * 2      ' each row sideways...
   FRAMEBUFFER WARPV 2, N, vy(), 2, 0, fr * 3      ' ...then each column up and down
 LOOP UNTIL quit OR fr > 900
END SUB
' ---------------------------------------------------------------- the melt between scenes
SUB melt
 LOCAL st!(159), tm!(159), dr(159), z(0), k, fr
 FRAMEBUFFER COPY N, F
 FRAMEBUFFER WARPH L, F, z(), H, , , , 0  ' the layers into the picture, so that they melt with it
 FRAMEBUFFER WARPH T, F, z(), H, , , , 0
 FRAMEBUFFER WRITE L : CLS : FRAMEBUFFER WRITE T : CLS : FRAMEBUFFER WRITE N
 FOR k = 0 TO 159 : st!(k) = RND * 40 : NEXT
 FOR fr = 1 TO 80
   MATH ADD st!(), -0.35 * fr * fr, tm!()
   MATH CLAMP tm!(), -H, 0, dr()      ' each column waits a little, then falls faster and faster
   FRAMEBUFFER WAIT
   CLS cl(0)
   FRAMEBUFFER WARPV F, N, dr(), 2, , , -1
   IF quit OR MATH(MAX dr()) <= -H THEN EXIT FOR
 NEXT
 CLS cl(0)
END SUB
' the 16 colours of p() at brightness f!, staged: MAP SET (which waits for the frame) commits them
SUB setpal p(), f!
 LOCAL n
 FOR n = 0 TO 15
   MAP(n) = RGB(((p(n) >> 16) AND 255) * f!, ((p(n) >> 8) AND 255) * f!, (p(n) AND 255) * f!)
 NEXT
END SUB
' the 16 colours a fraction f! of the way from a() to b(), at brightness br! (MAP SET by the caller)
SUB lerppal a(), b(), f!, br!
 LOCAL n, r, g, bl
 FOR n = 0 TO 15
   r = (((a(n) >> 16) AND 255) * (1 - f!) + ((b(n) >> 16) AND 255) * f!) * br!
   g = (((a(n) >> 8) AND 255) * (1 - f!) + ((b(n) >> 8) AND 255) * f!) * br!
   bl = ((a(n) AND 255) * (1 - f!) + (b(n) AND 255) * f!) * br!
   MAP(n) = RGB(r, g, bl)
 NEXT
END SUB
Posted: 02:30pm 23 Nov 2026
Quick check ... the demo does not run on 2040 VGA (as indicated, it uses framebuffer 2 ).
Posted: 02:56pm 23 Nov 2026
Try it on the PC3. You can also give doom, which now runs as an app a try
Posted: 03:30pm 23 Nov 2026
8.00.00b3 and 7.00.00RC6: ScummVM replaced in the programs zip (23 November)
ScummVM (quest/scummvm.app) read the games' speech from the SD card in the interrupt that makes the sound. That was in Day of the Tentacle, Sam & Max Hit the Road, Indiana Jones and the Fate of Atlantis on CD, Full Throttle, and the CD versions of The Legend of Kyrandia 1 and 2. A line that played while a game loaded a room or saved could have read the wrong data, or damaged a file on the card. No one is known to have seen it happen: the PicoMite's port of ScummVM found it in the code.
The new scummvm.app reads each line into memory before it plays it. Both zips have it now:
https://github.com/UKTailwind/CMM2V1.5/releases/tag/v8.00.00b3
https://github.com/UKTailwind/CMM2V1.5/releases/tag/v7.00.00RC6
If you downloaded either zip before 23 November, copy the new A:/quest/scummvm.app from it to your card. Nothing else in them has changed.
Bleep
Posted: 07:58pm 23 Nov 2026
Hi Peter,
The warp demo works fine on a HDMIUSBI2S
Should the apps work?
Doom tries to load but I get an error line too long.
MicroPython, I get not enough memory.
I have enabled the PSRAM, and have 6Mb which may not be enough?
Regards Kevin.
Posted: 09:55pm 23 Nov 2026
I haven't tested other than on a PC3 as I don't have any other hardware with me, will see if I can diagnose tomorrow.
ville56
Posted: 08:03am 24 Nov 2026
Bleep,
on what hardware are you trying to run micropython other than PC3?
Gerald
73 de OE1HGA, Gerald
Posted: 08:20am 24 Nov 2026
At the moment apps are only enabled on the PC3 firmware. I will look at the possibility of enabling them on any build with psram enabled but no promises.
Posted: 08:33am 24 Nov 2026
  matherp said  ……but no promises.
Meaning: give him a couple of hours and it will be ready for you to download!
Posted: 01:53pm 24 Nov 2026
PicoMite V8.00.00b2: the second beta of V8
Beta 2 adds continuous sound effects to PLAY MODSAMPLE, loadable programs to the PicoMiteHDMIUSB, two more apps for the PicoComputer 3 (the BBC Micro and ScummVM), 720x576 to the HDMI builds, and CPU speeds up to 444 MHz to the RP2350. This is a beta for testing: V7.00.00 stays the current release. The firmware for all 18 builds, the manual, the release notes and the apps are on GitHub: https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V8.00.00b2
Load your programs again. To free function tokens for new functions, EOF(, LOC( and LOF( now share one token and RAY( is part of SPRITE(, so most functions have a new token number. A program saved by V7.00.00 or V8.00.00b1 lists and runs with the wrong functions: in program memory, in a flash or RAM slot, in a library or in a .lib file. Load each again from its .bas file, which is not affected. If OPTION AUTORUN starts a program, turn it off before updating. A library that a program puts in with LIBRARY LOAD is loaded again by itself.
The PicoMiteHDMIUSB resets at its first boot of b2, as its flash region has moved to make room for the loader. Save its options first with OPTION DISK SAVE "B:/myoptions.txt" and load them again afterwards with OPTION DISK LOAD "B:/myoptions.txt". Its flash slots and program memory are cleared, and on a board with 4 MB of flash the A: drive too. Coming from V7.00.00, the PicoMitePC3 and the PicoMiteRP2350VGAUSB reset as well, as they did for b1. Every other build keeps its options, programs, flash slots and A: drive.
What is new
• Continuous sound effects with PLAY MODSAMPLE. With LOOP a sample of the MOD file keeps playing until PLAY MODSAMPLE STOP, and PLAY MODSAMPLE CHANGE changes its volume and rate where it is, without starting it again: an engine that follows its revs, a siren, or a car going by with the Doppler effect. A new rate argument sets the pitch. On the RP2350 builds an effect is now heard 12 to 23 ms after the command, not up to 93 ms. The Colour Maximite 2 has the same commands, and the Game Development Guide has worked examples.
• Loadable programs on the PicoMiteHDMIUSB, once its PSRAM is enabled with OPTION PSRAM PIN. A firmware without the loader now says that it cannot run a .app file, where it used to try to load it as a BASIC program.
• Two more apps on the PicoComputer 3, in PicoMite_Programs-8.00.00b2.zip with MicroPython, Doom and the NES emulator:
    ◦ The BBC Micro: the Colour Maximite 2's emulator, the Model B and the Master 128, at the BBC's own 50 frames a second with its sound, discs and sideways ROMs. At 720x576 each of the BBC's lines is shown twice.
    ◦ ScummVM: its SCUMM engine, for the LucasArts adventures from Monkey Island to Full Throttle, with their speech, music and the USB mouse, at 640x480. Bring your own games.
• 720x576 (576p) on the HDMI builds, except the HDMIWEB and HDMIBTH: OPTION RESOLUTION 720x576, at 50 frames a second with the CPU at 404 MHz.
• Up to 444 MHz on the RP2350, with or without PSRAM: the 384 MHz limit with PSRAM has gone. The firmware now writes its flash at a speed of its own, so the A: drive, the options and the flash slots keep working when the CPU is overclocked.
• An SRAM part for loadable programs, for code that is too slow from the PSRAM: the BBC Micro's 6502 runs from it.
This beta has been tested on the PicoComputer 3, with the PicoMitePC3 firmware and with the PicoMiteHDMIUSB firmware. The other builds compile cleanly, so reports from other boards are welcome.
homa
Posted: 03:41pm 24 Nov 2026
Hi Peter,
thanks for the PicoMite V8 betas. The PC3 apps look great!
And a big, heartfelt thank you for all the other new features (MOD sound effects, FRAMEBUFFER WARP and much more). It will take me a while to work them into my projects properly, but I’m looking forward to it.
Over in the CMM2 V8 beta thread, SQLite has made my day: my little SQLite admin tool mmsql already runs nicely on it, and SQL(TYPE n) arrived just when I needed it.
So, cheeky question :-) Can I hope for the SQL command on the PicoMitePC3 firmware too, at some point? I know the RP2350 has much less RAM than the CMM2, so “no” or “not yet” would be a perfectly fair answer.
Either way, many thanks for all your work!
Matthias
Posted: 03:57pm 24 Nov 2026
I'm looking at sql on the pc3, will do it if possible
Bleep
Posted: 08:03pm 24 Nov 2026
Hi Peter,
A report on 8.0.b2, as far as I can tell apps are now working on my HDMIUSBI2S board with PSRAM.
I've run Doom, BBC Basic, ScummVM though I don't have any games for it and Python, all start up & appear to work correctly, even MMBasic works ;-)  Thanks.
Regards Kevin
homa
Posted: 08:49pm 24 Nov 2026
For those who haven't had the chance to install FW 8.00.00 b2 yet, here's a quick video of Peter's warp_demo.bas running on my [board, e.g. RP2350 HDMI] in MODE 2:
https://youtu.be/FCE48UFDMHo
Really impressive what WARPH/WARPV can do. The lake reflection and the road scene especially look like they came straight out of an old arcade machine, and it's all in BASIC at full frame rate. Thanks Peter!
Matthias
terekgabor
Posted: 09:25pm 24 Nov 2026
Peter!
This is unbelievable what Picomite can do now!
Big-big thank you for your hard work!
I am blown away! As everybody I think.
G@bor
