Forum Index : Off topic archive. : HTML Links
| Greenbelt Guru Joined: 11/01/2009 Location: United StatesPosts: 566 |
Gizmo; The Link on my post calls up the (Log in page.) I know you are not buisy enough! Oh! Windmills/Aluminum Blades/page 8. Hope I didn't mess it up. Time has proven that I am blind to the Obvious, some of the above may be True? |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5195 |
That is a bit strange, dont know how it got that link. Can you tell me the correct link? Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
http://www.pipercubforum.com/woodprop.htm I realize this is off subject (Aluminum Blades), but related. Most of you know that a wood blade will serve well when cared for, It has the qualities to stand up under repeated abuse. A tree after all is conditioned to the fury of nature and evolved to withstand the twisting and bending. It can fail but not fatigue. My post is directed to the wind power Newbies Time has proven that I am blind to the Obvious, some of the above may be True? |
Thats fixed mate. Its a good link too, thanks for posting. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
