Local Time 15:06 20 Sep 2026 Privacy Policy
Forum Index : Off topic archive. : stator output on 100ci revtech stator
dastephan
Posted: 01:04am 28 Jul 2010
does anyone know what i should read on my meter for my stator output on my
2004 revtech 100ci motorcycle ....i am getting 18v ac but the battery is not charging ...i am thinking its the volt pack
das
Robb
Posted: 04:15am 28 Jul 2010
If the 18v ac has enough current to light up a 12 volt tail lamp at low rpm then I'd be fixing this "volt pack" as you call it. Charge the battery ASAP with an external charger because if you leave it flat for a few weeks you can kiss it good bye.
VK4AYQ
Posted: 04:46am 28 Jul 2010
Hi Dastephan
It looks like your regulator rectifier has died, I think that's what you called the volt pack, As Robb suggested try a globe "12 v" across the output leads of the stator if the globe lights it is OK, don't go for a lot of revs as it will possibly blow the globe without a regulator in line, if the globe doesn't light it may be a bad stator or a bad joint in the circuit to the stator, measure with ohm meter to check.
All the best
Bob
Foolin Around
Downwind
Posted: 08:08am 28 Jul 2010
A friend of mine is in the repair of motorbike electricals here, and the voltage regular modules often fail, if you have volts in and none out then it would indicate a dead regulator.
Check for voltage out close to the regulator as bad leads or plugs/sockets is also a big cause.
I often push a pin through the wires to use as a test point for checking if there is a break or bad connection in line some where.
Some modules are chassi earthed and this can also be where a problem is located with a poor earth.
Only working your way along the circuit will isolate where the problem is.
I doubt that it is the stator at fault.
Pete.
Sometimes it just works
dastephan
Posted: 12:30pm 28 Jul 2010
thanks i will try putting my meter leads into the wire coming out of the stator plug
if it good there i will replace the volt pack..thanks again
das
matt down south
Posted: 03:20pm 28 Jul 2010
im a m/cycle mechanic and we had a run on 650 kawi dirt bikes back in 97 with bad star connections on the 3 phrase stators as they were cripped and not soldered together,plenty of volts unloaded but nothing loaded,to much varnish on the wires on the star connection
matt
