Local Time 00:00 06 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Chuckie Egg for the Pico Computer 3 - the ultimate platform game
Posted: 08:58am 09 Sep 2026
Runs using a local keyboard (USB or PS2). could be modified to use other controls. Tested on the PC3 with both HDMI and VGA builds. May work on a RP2040 (untested).
Please reports any issues with the game play (with corrections if possible)
chuckie.zip
'  C H U C K I E   E G G        PicoMite MMBasic
'  after the 1983 BBC Micro game by A&F Software
'  Runs in MODE 2 (320 x 240, 16 colours) on VGA and HDMI builds.  MODE 2 is only
'  selected if the screen is not already 320 x 240.
'  Harry has to gather all twelve eggs on each floor before the clock runs
'  out while the hens patrol the girders.  Grain piles are worth points and
'  the hens stop to eat them.
'  The eight floors come round five times over, and each time the odds get
'  worse:
'    levels  1-8   the floor's own hens (3 or 4), duck still caged
'    levels  9-16  no hens at all, but the duck is loose and hunts Harry
'    levels 17-24  the hens are back, and the duck stays out with them
'    levels 25-32  five hens on every floor, plus the duck
'    levels 33-40  five hens and the duck, everything at full speed
'  Keys      Left / Right ... arrow keys, or Z and X
'            Up / Down ...... arrow keys (ladders)
'            Jump ........... SPACE
'            Quit ........... ESC
'  For testing: UP and DOWN on the title screen pick the level to start
'  on, and N during play skips straight to the next one.
'  How it matches the original
'  The BBC screen is 256 rows: 32 for the status panel and 224 for the
'  floor.  Ours is 240, and the whole 16 row difference comes out of the
'  panel - the BBC set its two text rows in a 32 row band and our 6 x 8
'  font fits the same two rows in 16 - so the playfield keeps its full 224
'  rows.  The BBC is 160 pixels across against our 320, so everything
'  horizontal is doubled and the sprites, girders, ladders and jump arcs
'  come out the same size on screen as they did in 1983.
'  The eight floors were traced from screenshots of the real game; Harry,
'  the hens and the duck are lifted pixel for pixel off its title screen.
'  Sound is synthesised on the PicoMite's square, triangle and noise
'  generators in the style of the original.
OPTION EXPLICIT
OPTION DEFAULT NONE
' ------------------------------------------------------------ geometry
CONST SCRW = 320, SCRH = 240
CONST FONTN = 7, FW = 6, FH = 8   ' font 7 is the 6 x 8 one; font 1 is 8 x 12
CONST PLAYTOP = 16                ' first pixel row below the status panel
CONST CW = 16, CH = 8             ' one map cell
CONST GCOLS = 20, GROWS = 28      ' map size in cells
CONST FLTHK = 5                   ' a girder is five pixels deep
CONST HW = 16, HH = 18            ' Harry
CONST NW = 14, NH = 20            ' hen
CONST NHEAD = 6                   ' its raised head and neck are not lethal
CONST DW = 31, DH = 22            ' duck
CONST LW = 20, LH = 4             ' lift
' -------------------------------------------------------- map cell bits
CONST C_SOLID = 1, C_LADDER = 2, C_SHAFT = 4
' ------------------------------------------------------ sprite buffers
CONST S_STAND = 1, S_RUN1 = 2, S_RUN2 = 3, S_CLIMB1 = 4, S_CLIMB2 = 5
CONST S_DUCK1 = 6, S_DUCK2 = 7
CONST S_HEN1 = 8, S_HEN2 = 9, S_HEN3 = 10
CONST S_LIFT = 11, S_EGGA = 12, S_EGGB = 13, S_SEED = 14
CONST NSPR = 14
' --------------------------------------------------------------- limits
CONST MAXEGG = 12, MAXSEED = 16, MAXHEN = 5, MAXLIFT = 2
CONST S_HENA = 15                 ' MAXHEN copies each of walk A, walk B, peck
CONST S_LIFT2 = S_HENA + 3 * MAXHEN
CONST E_DUCK = MAXHEN + 1
CONST E_LIFT = MAXHEN + 2
CONST NENT = MAXHEN + 3           ' 0 Harry, 1..MAXHEN hens, duck, two lifts
' -------------------------------------------------------------- physics
CONST GRAV = 0.38
CONST JUMPV = -4.8
CONST WALKSPD = 2
CONST CLIMBSPD = 2
CONST MAXFALL = 7.0
CONST LIFTSPD = 0.6
CONST FRAMEMS = 33                ' about 30 frames a second
CONST ST_WALK = 0, ST_CLIMB = 1
CONST LADDERODDS = 0.03           ' chance a hen takes a ladder each frame
CONST PECKFRAMES = 45
' ---------------------------------------------------------------- sound
CONST NSFX = 10
CONST SFX_EGG = 0, SFX_SEED = 1, SFX_JUMP = 2, SFX_DIE = 3, SFX_CLUCK = 4
CONST SFX_STEP = 5, SFX_TICK = 6, SFX_EXTRA = 7, SFX_QUACK = 8, SFX_LAND = 9
CONST MAXSTEP = 20
CONST NCHAN = 4
'  globals
DIM INTEGER grid(GROWS - 1, GCOLS - 1)
DIM lvl$(7, GROWS - 1) LENGTH 20
DIM INTEGER pal(15)
DIM INTEGER img(1023)
DIM hexd$ LENGTH 20
DIM INTEGER egX(MAXEGG - 1), egY(MAXEGG - 1), egOn(MAXEGG - 1)
DIM INTEGER nEgg, eggLeft
DIM INTEGER sdX(MAXSEED - 1), sdY(MAXSEED - 1), sdOn(MAXSEED - 1)
DIM INTEGER nSeed
DIM FLOAT henX(MAXHEN - 1), henY(MAXHEN - 1)
DIM INTEGER henDir(MAXHEN - 1), henSt(MAXHEN - 1), henVD(MAXHEN - 1)
DIM INTEGER henAnim(MAXHEN - 1), henPeck(MAXHEN - 1)
DIM INTEGER henX0(MAXHEN - 1), henY0(MAXHEN - 1)
DIM INTEGER nHen, nHen0, gIdx
DIM INTEGER henBase(7)
DIM FLOAT px, py, pvy
DIM INTEGER pvx, pState, pFace, pAnim, pGround, pLift, pFell
DIM INTEGER startX, startY
DIM FLOAT dkX, dkY
DIM INTEGER dkOn, dkAnim, dkQuack, dkFace
DIM FLOAT lfY(MAXLIFT - 1)
DIM INTEGER lfN, lfX, lfTop, lfBot
DIM INTEGER entBuf(NENT), entWant(NENT), entX(NENT), entY(NENT)
DIM INTEGER entRot(NENT), entLay(NENT)
DIM INTEGER kLeft, kRight, kUp, kDown, kJump, kQuit, kSkip
DIM INTEGER gStart
DIM INTEGER gScore, gHi, gLives, gLevel, gLap, gTime, gBonus, gNextLife
DIM INTEGER panelCol, eggBuf
DIM FLOAT henSpd, dkSpd
DIM INTEGER sndOK
DIM INTEGER sfxF(NSFX - 1, MAXSTEP - 1), sfxD(NSFX - 1, MAXSTEP - 1)
DIM INTEGER sfxN(NSFX - 1), sfxV(NSFX - 1), sfxW(NSFX - 1), sfxCh(NSFX - 1)
DIM INTEGER chSfx(NCHAN - 1), chStep(NCHAN - 1), chLeft(NCHAN - 1)
DIM INTEGER chPri(NCHAN - 1)
'  main
Setup
DO
 TitleScreen
 PlayGame
LOOP
END
'  one-time set-up
SUB Setup
 LOCAL INTEGER i, j
 IF MM.HRES <> 320 OR MM.VRES <> 240 THEN
   ON ERROR SKIP 1
   MODE 2
 ENDIF
   ON ERROR CLEAR
   PRINT "Chuckie Egg needs a 320 x 240 screen (MODE 2)."
   PRINT "This display is"; MM.HRES; " x"; MM.VRES
   END
 ENDIF
 ON ERROR CLEAR
 pal(0) = RGB(BLACK)    : pal(1) = RGB(BLUE)     : pal(2) = RGB(MYRTLE)
 pal(3) = RGB(COBALT)   : pal(4) = RGB(MIDGREEN) : pal(5) = RGB(CERULEAN)
 pal(6) = RGB(GREEN)    : pal(7) = RGB(CYAN)     : pal(8) = RGB(RED)
 pal(9) = RGB(MAGENTA)  : pal(10) = RGB(RUST)    : pal(11) = RGB(FUCHSIA)
 pal(12) = RGB(BROWN)   : pal(13) = RGB(LILAC)   : pal(14) = RGB(YELLOW)
 pal(15) = RGB(WHITE)
 hexd$ = "0123456789ABCDEF"
 SPRITE CLOSE ALL
 ON ERROR SKIP 1
 FRAMEBUFFER CREATE
 ON ERROR CLEAR
 FRAMEBUFFER WRITE F
 CLS RGB(BLACK)
 LoadSprites
 ' Working copies, so the four hens can animate independently while
 ' sharing one set of images, plus a second lift for the shafts that
 ' carry two of them.
 SPRITE COPY S_HEN1, S_HENA, MAXHEN
 SPRITE COPY S_HEN2, S_HENA + MAXHEN, MAXHEN
 SPRITE COPY S_HEN3, S_HENA + 2 * MAXHEN, MAXHEN
 SPRITE COPY S_LIFT, S_LIFT2, 1
 RESTORE hendata
 FOR i = 0 TO 7
   READ henBase(i)
 NEXT i
 RESTORE lvldata
 FOR i = 0 TO 7
   FOR j = 0 TO GROWS - 1
     READ lvl$(i, j)
   NEXT j
 NEXT i
 LoadSfx
 sndOK = 0
 ON ERROR SKIP 2
 PLAY SOUND 1, B, Q, 1000, 0
 PLAY SOUND 1, B, O
 IF MM.ERRNO = 0 THEN sndOK = 1
 ON ERROR CLEAR
 gHi = 1000
 gStart = 1
 FOR i = 0 TO NENT
   entBuf(i) = 0 : entWant(i) = 0
 NEXT i
END SUB
'  Build every sprite from the packed bitmaps at the end of the listing.
'  Each DATA line is width, height, colour index and a hex string holding
'  <height> rows of ceil(width/4) digits, most significant bit on the left.
SUB LoadSprites
 LOCAL INTEGER n, w, h, ci, col, j, nd, nyb, d, b, i, k
 LOCAL bits$ LENGTH 200
 RESTORE sprdata
 FOR n = 1 TO NSPR
   READ w, h, ci, bits$
   col = pal(ci)
   nyb = (w + 3) \ 4
   k = 0
   FOR j = 0 TO h - 1
     FOR nd = 0 TO nyb - 1
       d = INSTR(hexd$, MID$(bits$, j * nyb + nd + 1, 1)) - 1
       FOR b = 3 TO 0 STEP -1
         i = nd * 4 + 3 - b
         IF i < w THEN
           IF (d AND (1 << b)) <> 0 THEN img(k) = col ELSE img(k) = 0
           k = k + 1
         ENDIF
       NEXT b
     NEXT nd
   NEXT j
   SPRITE LOADARRAY n, w, h, img()
 NEXT n
END SUB
'  sound
SUB LoadSfx
 LOCAL INTEGER s, n, f, d
 RESTORE sfxdata
 FOR s = 0 TO NSFX - 1
   READ sfxCh(s), sfxW(s), sfxV(s)
   n = 0
   DO
     READ f, d
     IF f < 0 THEN EXIT DO
     sfxF(s, n) = f : sfxD(s, n) = d
     n = n + 1
   LOOP UNTIL n >= MAXSTEP
   sfxN(s) = n
 NEXT s
 SfxSilence
END SUB
SUB SfxSilence
 LOCAL INTEGER c
 FOR c = 0 TO NCHAN - 1
   chSfx(c) = -1 : chStep(c) = 0 : chLeft(c) = 0 : chPri(c) = 0
   IF sndOK <> 0 THEN PLAY SOUND c + 1, B, O
 NEXT c
END SUB
SUB SfxPlay(s AS INTEGER, pri AS INTEGER)
 LOCAL INTEGER c
 IF sndOK = 0 THEN EXIT SUB
 c = sfxCh(s)
 IF chSfx(c) >= 0 AND chPri(c) > pri THEN EXIT SUB
 chSfx(c) = s : chStep(c) = 0 : chLeft(c) = 0 : chPri(c) = pri
END SUB
' Advance every channel by one frame, so an effect never blocks the game.
SUB SfxService
 LOCAL INTEGER c, s
   IF chSfx(c) >= 0 THEN
     IF chLeft(c) > 0 THEN chLeft(c) = chLeft(c) - 1
     IF chLeft(c) <= 0 THEN
       s = chSfx(c)
       IF chStep(c) >= sfxN(s) THEN
         chSfx(c) = -1 : chPri(c) = 0
         SndOut c + 1, 0, 0, 0
       ELSE
         SndOut c + 1, sfxW(s), sfxF(s, chStep(c)), sfxV(s)
         chLeft(c) = sfxD(s, chStep(c))
         chStep(c) = chStep(c) + 1
       ENDIF
     ENDIF
   ENDIF
 NEXT c
END SUB
' PLAY SOUND wants the waveform as a literal, so pick it here.
SUB SndOut(ch AS INTEGER, wf AS INTEGER, f AS INTEGER, v AS INTEGER)
 IF f <= 0 OR v <= 0 THEN
   PLAY SOUND ch, B, O
 ELSE
   SELECT CASE wf
     CASE 0 : PLAY SOUND ch, B, Q, f, v
     CASE 1 : PLAY SOUND ch, B, T, f, v
     CASE 2 : PLAY SOUND ch, B, S, f, v
     CASE ELSE : PLAY SOUND ch, B, N, f, v
   END SELECT
 ENDIF
END SUB
' A short blocking tune, used between lives and floors.
SUB Tune(which AS INTEGER)
 LOCAL INTEGER f, d
 SfxSilence
 SELECT CASE which
   CASE 0 : RESTORE tune0            ' new floor
   CASE 1 : RESTORE tune1            ' floor cleared
   CASE ELSE : RESTORE tune2         ' game over
 END SELECT
 DO
   READ f, d
   IF f = 0 THEN
     PLAY SOUND 1, B, O
   ELSE
     PLAY SOUND 1, B, Q, f, 18
   ENDIF
   PAUSE d
 LOOP
 PLAY SOUND 1, B, O
END SUB
'  keyboard
'  KEYDOWN(0) gives the number of keys held and KEYDOWN(1..6) the
'  character of each, so the whole set is read once a frame and latched
'  into flags.  Every KEYDOWN call also empties the console input buffer,
'  so INKEY$ has to be read first.
SUB ReadKeys
 LOCAL INTEGER i, k
 LOCAL ky$ LENGTH 2
 kLeft = 0 : kRight = 0 : kUp = 0 : kDown = 0 : kJump = 0 : kQuit = 0
 kSkip = 0
 ky$ = INKEY$
 IF ky$ = " " THEN kJump = 1
 IF ky$ = CHR$(27) THEN kQuit = 1
 IF ky$ = "n" OR ky$ = "N" THEN kSkip = 1
 FOR i = 1 TO 6
   k = KEYDOWN(i)
   SELECT CASE k
     CASE 130, 122, 90  : kLeft = 1
     CASE 131, 120, 88  : kRight = 1
     CASE 128, 59, 39   : kUp = 1
     CASE 129, 47, 46   : kDown = 1
     CASE 32            : kJump = 1
     CASE 27            : kQuit = 1
     CASE 110, 78       : kSkip = 1        ' N, skip a level while testing
   END SELECT
 NEXT i
END SUB
'  map helpers
FUNCTION CellFlag(cx AS INTEGER, cy AS INTEGER) AS INTEGER
 LOCAL INTEGER r, c
 CellFlag = 0
 IF cy < PLAYTOP OR cx < 0 OR cx >= SCRW THEN EXIT FUNCTION
 r = (cy - PLAYTOP) \ CH
 IF r < 0 OR r >= GROWS THEN EXIT FUNCTION
 c = cx \ CW
 CellFlag = grid(r, c)
END FUNCTION
' Is any cell solid across the given pixel span on map row rr?
FUNCTION RowSolid(rr AS INTEGER, x0 AS INTEGER, wd AS INTEGER) AS INTEGER
 LOCAL INTEGER c0, c1, c
 RowSolid = 0
 IF rr < 0 OR rr >= GROWS THEN EXIT FUNCTION
 c0 = (x0 + 2) \ CW
 c1 = (x0 + wd - 3) \ CW
 IF c0 < 0 THEN c0 = 0
 IF c1 > GCOLS - 1 THEN c1 = GCOLS - 1
 FOR c = c0 TO c1
   IF (grid(rr, c) AND C_SOLID) <> 0 THEN RowSolid = 1 : EXIT FUNCTION
 NEXT c
END FUNCTION
'  level loading and drawing
SUB LoadLevel
 LOCAL INTEGER r, c, idx
 LOCAL cel$ LENGTH 1
 LOCAL row$ LENGTH 20
 idx = (gLevel - 1) MOD 8
 gIdx = idx
 gLap = (gLevel - 1) \ 8
 nEgg = 0 : nSeed = 0 : nHen0 = 0
 lfN = 0 : lfX = 0 : lfTop = 0 : lfBot = 0
 startX = 16 : startY = PLAYTOP
 ' the panel and the eggs change colour every six floors, as they do on
 ' the BBC
 IF ((gLevel - 1) \ 6) MOD 2 = 0 THEN
   panelCol = RGB(MAGENTA) : eggBuf = S_EGGA
 ELSE
   panelCol = RGB(RED) : eggBuf = S_EGGB
 ENDIF
 FOR r = 0 TO GROWS - 1
   row$ = lvl$(idx, r)
   FOR c = 0 TO GCOLS - 1
     grid(r, c) = 0
     cel$ = MID$(row$, c + 1, 1)
     SELECT CASE cel$
       CASE "#"
         grid(r, c) = C_SOLID
       CASE "H"
         grid(r, c) = C_LADDER
       CASE "+"
         ' a ladder passing through a girder: walk over it, or climb down
         grid(r, c) = C_LADDER OR C_SOLID
       CASE "L", "K"
         grid(r, c) = C_SHAFT
         IF lfN = 0 THEN
           ' the shaft is two columns wide, so the 20 pixel lift sits
           ' just inside its left hand edge
           lfX = c * CW + 2
           lfTop = r : lfBot = r
           IF cel$ = "K" THEN lfN = 2 ELSE lfN = 1
         ELSE
           IF r < lfTop THEN lfTop = r
           IF r > lfBot THEN lfBot = r
         ENDIF
       CASE "E"
         IF nEgg < MAXEGG THEN
           egX(nEgg) = c * CW + (CW - 12) \ 2
           egY(nEgg) = PLAYTOP + (r + 1) * CH - 6
           egOn(nEgg) = 1 : nEgg = nEgg + 1
         ENDIF
       CASE "S"
         IF nSeed < MAXSEED THEN
           sdX(nSeed) = c * CW + (CW - 14) \ 2
           sdY(nSeed) = PLAYTOP + (r + 1) * CH - 4
           sdOn(nSeed) = 1 : nSeed = nSeed + 1
         ENDIF
       CASE "P"
         startX = c * CW
         startY = PLAYTOP + (r + 1) * CH - HH
       CASE "1", "2", "3", "4", "5"
         IF nHen0 < MAXHEN THEN
           henX0(nHen0) = c * CW + (CW - NW) \ 2
           henY0(nHen0) = PLAYTOP + (r + 1) * CH - NH
           nHen0 = nHen0 + 1
         ENDIF
     END SELECT
   NEXT c
 NEXT r
 eggLeft = nEgg
END SUB
' One girder cell.  The BBC draws three courses of green a pixel deep with
' a pixel of mortar between them, each course broken by one vertical joint
' and the joints staggered from course to course.
SUB DrawGirder(x AS INTEGER, y AS INTEGER)
 BOX x, y, CW, 1, 0, RGB(GREEN), RGB(GREEN)
 BOX x, y + 2, CW, 1, 0, RGB(GREEN), RGB(GREEN)
 BOX x, y + 4, CW, 1, 0, RGB(GREEN), RGB(GREEN)
 BOX x + 10, y, 2, 1, 0, RGB(BLACK), RGB(BLACK)
 BOX x + 2, y + 2, 2, 1, 0, RGB(BLACK), RGB(BLACK)
 BOX x + 6, y + 4, 2, 1, 0, RGB(BLACK), RGB(BLACK)
END SUB
' One ladder cell: two magenta rails with a rung across them.
SUB DrawRungs(x AS INTEGER, y AS INTEGER)
 BOX x + 2, y, 2, CH, 0, RGB(MAGENTA), RGB(MAGENTA)
 BOX x + 12, y, 2, CH, 0, RGB(MAGENTA), RGB(MAGENTA)
 BOX x + 2, y + 3, 12, 1, 0, RGB(MAGENTA), RGB(MAGENTA)
END SUB
' The duck's cage hangs in the top left corner of the floor, as it does on
' the BBC.  From level nine the duck is out and the cage stands empty.
' It is scenery only - nothing collides with it.
SUB DrawCage(occupied AS INTEGER)
 LOCAL INTEGER i
 BOX 24, 20, 2, 5, 0, RGB(YELLOW), RGB(YELLOW)
 CIRCLE 25, 20, 3, 1, 1, RGB(YELLOW)
 RBOX 4, 24, 43, 46, 12, RGB(YELLOW)
 IF occupied <> 0 THEN
   CIRCLE 22, 54, 9, 0, 0.75, RGB(YELLOW), RGB(YELLOW)
   CIRCLE 33, 44, 4, 0, 1, RGB(YELLOW), RGB(YELLOW)
   BOX 37, 44, 6, 2, 0, RGB(YELLOW), RGB(YELLOW)
 ENDIF
 FOR i = 10 TO 41 STEP 6
   BOX i, 27, 1, 41, 0, RGB(YELLOW), RGB(YELLOW)
 NEXT i
 BOX 4, 68, 43, 2, 0, RGB(YELLOW), RGB(YELLOW)
END SUB
SUB DrawWorld
 LOCAL INTEGER r, c, y, fl
 CLS RGB(BLACK)
 ' Where a ladder passes through a girder the BBC draws the ladder alone:
 ' that square is a single tile that you can both climb and stand on, and
 ' no green shows through it.  So the girder is skipped there.
   y = PLAYTOP + r * CH
     fl = grid(r, c)
     IF (fl AND C_LADDER) = 0 AND (fl AND C_SOLID) <> 0 THEN DrawGirder c * CW, y
   NEXT c
 NEXT r
     IF (grid(r, c) AND C_LADDER) <> 0 THEN DrawRungs c * CW, y
   NEXT c
 NEXT r
 IF gLevel <= 8 THEN DrawCage 1 ELSE DrawCage 0
 FOR r = 0 TO nEgg - 1
   IF egOn(r) <> 0 THEN SPRITE WRITE eggBuf, egX(r), egY(r), 0
 NEXT r
 FOR r = 0 TO nSeed - 1
   IF sdOn(r) <> 0 THEN SPRITE WRITE S_SEED, sdX(r), sdY(r), 0
 NEXT r
END SUB
' Rub something out of the background.  All the sprites have to be lifted
' first, or they would put the old picture back when they next move.
SUB EraseBg(x AS INTEGER, y AS INTEGER, w AS INTEGER, h AS INTEGER)
 SPRITE HIDE ALL
 BOX x, y, w, h, 0, RGB(BLACK), RGB(BLACK)
 SPRITE RESTORE
END SUB
'  entity plumbing
SUB HideAllEnt
 LOCAL INTEGER e
 FOR e = 0 TO NENT
   IF entBuf(e) <> 0 THEN SPRITE HIDE entBuf(e)
   entBuf(e) = 0 : entWant(e) = 0
 NEXT e
END SUB
SUB SetEnt(e AS INTEGER, buf AS INTEGER, x AS INTEGER, y AS INTEGER, lay AS INTEGER, rot AS INTEGER)
 entWant(e) = buf : entX(e) = x : entY(e) = y
 entLay(e) = lay : entRot(e) = rot
END SUB
SUB ShowEnts
 LOCAL INTEGER e, sw, sh
 FOR e = 0 TO NENT
   IF entWant(e) = 0 THEN
       SPRITE HIDE SAFE entBuf(e)
       entBuf(e) = 0
     ENDIF
   ELSE
     IF entBuf(e) <> entWant(e) THEN
       IF entBuf(e) <> 0 THEN SPRITE HIDE SAFE entBuf(e)
       entBuf(e) = entWant(e)
     ENDIF
     sw = SPRITE(W, entBuf(e)) : sh = SPRITE(H, entBuf(e))
     IF entX(e) < 1 - sw THEN entX(e) = 1 - sw
     IF entX(e) > SCRW - 1 THEN entX(e) = SCRW - 1
     IF entY(e) < 1 - sh THEN entY(e) = 1 - sh
     IF entY(e) > SCRH - 1 THEN entY(e) = SCRH - 1
     SPRITE SHOW SAFE entBuf(e), entX(e), entY(e), entLay(e), entRot(e)
   ENDIF
 NEXT e
END SUB
'  Harry
SUB UpdatePlayer
 LOCAL INTEGER cx, fy0, fy1, r, rEnd, ytop, ybot, landed, oldAnim, i
 LOCAL FLOAT ny
 cx = INT(px) + HW \ 2
 oldAnim = pAnim \ 6
 ' ---------------------------------------------------------- on a ladder
 IF pState = ST_CLIMB THEN
   IF kJump <> 0 THEN
     pState = ST_WALK : pvy = JUMPV : pGround = 0
     SfxPlay SFX_JUMP, 2
   ELSE
     IF kUp <> 0 THEN
       IF (CellFlag(cx, INT(py) + HH - 1) AND C_LADDER) <> 0 THEN
         py = py - CLIMBSPD
         pAnim = pAnim + 1
       ENDIF
     ELSEIF kDown <> 0 THEN
       IF (CellFlag(cx, INT(py) + HH + 1) AND C_LADDER) <> 0 THEN
         py = py + CLIMBSPD
         pAnim = pAnim + 1
       ENDIF
     ENDIF
     IF kLeft <> 0 OR kRight <> 0 THEN
       IF kLeft <> 0 THEN pFace = 1 ELSE pFace = 0
       IF RowSolid((INT(py) + HH - PLAYTOP) \ CH, INT(px), HW) <> 0 THEN
         pState = ST_WALK : pvy = 0 : pGround = 1
       ENDIF
     ENDIF
     IF (CellFlag(cx, INT(py) + HH - 1) AND C_LADDER) = 0 THEN
       IF (CellFlag(cx, INT(py) + HH) AND C_LADDER) = 0 THEN
       ENDIF
     ENDIF
   ENDIF
   IF py < PLAYTOP THEN py = PLAYTOP
   IF (pAnim \ 6) <> oldAnim THEN SfxPlay SFX_STEP, 0
   EXIT SUB
 ENDIF
 ' ---------------------------------------------------------- grab a rung
 IF kUp <> 0 THEN
     pState = ST_CLIMB : pvy = 0 : pLift = 0
     px = (cx \ CW) * CW
     EXIT SUB
   ENDIF
 ELSEIF kDown <> 0 AND pGround <> 0 THEN
     px = (cx \ CW) * CW
     EXIT SUB
   ENDIF
 ENDIF
 ' ------------------------------------------------------------- running
 pvx = 0
 IF kLeft <> 0 THEN pvx = -WALKSPD : pFace = 1
 IF kRight <> 0 THEN pvx = WALKSPD : pFace = 0
 IF pvx <> 0 THEN
   px = px + pvx
   IF px < 0 THEN px = 0
   IF px > SCRW - HW THEN px = SCRW - HW
   pAnim = pAnim + 1
   IF pGround <> 0 AND (pAnim \ 6) <> oldAnim THEN SfxPlay SFX_STEP, 0
 ENDIF
 IF kJump <> 0 AND pGround <> 0 THEN
   pvy = JUMPV : pGround = 0 : pLift = 0
   SfxPlay SFX_JUMP, 2
 ENDIF
 ' ----------------------------------------------------- riding the lift
 IF pLift <> 0 THEN
   i = pLift - 1
   IF (INT(px) + HW - 2 <= lfX) OR (INT(px) + 2 >= lfX + LW) THEN
     pLift = 0
   ELSE
     py = lfY(i) - HH : pvy = 0 : pGround = 1
     EXIT SUB
   ENDIF
 ENDIF
 ' ------------------------------------------------------------- gravity
 pvy = pvy + GRAV
 IF pvy > MAXFALL THEN pvy = MAXFALL
 ny = py + pvy
 landed = 0
 IF pvy >= 0 THEN
   fy0 = INT(py) + HH
   fy1 = INT(ny) + HH
   IF lfN > 0 AND (INT(px) + HW - 2 > lfX) AND (INT(px) + 2 < lfX + LW) THEN
     FOR i = 0 TO lfN - 1
       ytop = INT(lfY(i))
       IF landed = 0 AND ytop >= fy0 - 1 AND ytop <= fy1 THEN
         py = ytop - HH : pvy = 0 : landed = 1 : pGround = 1 : pLift = i + 1
       ENDIF
     NEXT i
   ENDIF
   IF landed = 0 THEN
     r = (fy0 - PLAYTOP) \ CH
     IF r < 0 THEN r = 0
     rEnd = (fy1 - PLAYTOP) \ CH
     IF rEnd > GROWS - 1 THEN rEnd = GROWS - 1
     DO WHILE r <= rEnd
       ytop = PLAYTOP + r * CH
       IF ytop >= fy0 AND ytop <= fy1 THEN
         IF RowSolid(r, INT(px), HW) <> 0 THEN
           IF pGround = 0 THEN SfxPlay SFX_LAND, 1
           pGround = 1 : pLift = 0
           EXIT DO
         ENDIF
       ENDIF
       r = r + 1
     LOOP
   ENDIF
   IF landed = 0 THEN
     py = ny : pGround = 0 : pLift = 0
   ENDIF
 ELSE
   fy0 = INT(py)
   fy1 = INT(ny)
   IF r > GROWS - 1 THEN r = GROWS - 1
   IF rEnd < 0 THEN rEnd = 0
   DO WHILE r >= rEnd
     ybot = PLAYTOP + r * CH + FLTHK - 1
     IF ybot <= fy0 AND ybot >= fy1 THEN
         py = ybot + 1 : pvy = 0 : landed = 1
         EXIT DO
       ENDIF
     ENDIF
     r = r - 1
   LOOP
   IF landed = 0 THEN py = ny
 ENDIF
   py = PLAYTOP
   IF pvy < 0 THEN pvy = 0
 ENDIF
 ' Through a gap in the ground girder there is nowhere to land, so going
 ' off the bottom of the screen costs a life rather than wedging him in
 ' the few pixels below it.
 IF py > SCRH - HH THEN
   py = SCRH - HH
   pFell = 1
 ENDIF
END SUB
'  hens
' A ladder stands proud of the floor it serves, so the rungs above a hen's
' head are very often just that overhang and lead nowhere.  Only climb when
' there is a girder at the far end: up, that means a run of ladder cells
' ending in one that is also solid.
FUNCTION LadderUp(cx AS INTEGER, fy AS INTEGER) AS INTEGER
 LOCAL INTEGER r, c
 LadderUp = 0
 c = cx \ CW
 IF c < 0 OR c > GCOLS - 1 THEN EXIT FUNCTION
 r = (fy - PLAYTOP) \ CH - 1
 DO WHILE r >= 0
   IF (grid(r, c) AND C_LADDER) = 0 THEN EXIT FUNCTION
   IF (grid(r, c) AND C_SOLID) <> 0 THEN LadderUp = 1 : EXIT FUNCTION
   r = r - 1
 LOOP
END FUNCTION
' Down, the hen has to be standing on a crossing square, and the run has to
' reach something solid to land on.
FUNCTION LadderDown(cx AS INTEGER, fy AS INTEGER) AS INTEGER
 LOCAL INTEGER r, c
 LadderDown = 0
 c = cx \ CW
 IF r < 0 OR r > GROWS - 1 THEN EXIT FUNCTION
 r = r + 1
 DO WHILE r <= GROWS - 1
   IF (grid(r, c) AND C_SOLID) <> 0 THEN LadderDown = 1 : EXIT FUNCTION
   r = r + 1
 LOOP
END FUNCTION
SUB UpdateHen(i AS INTEGER)
 LOCAL INTEGER fy, cx, edge, nx, r, ytop, nfy, wayUp, wayDn
 LOCAL FLOAT ny
 IF henPeck(i) > 0 THEN
   henPeck(i) = henPeck(i) - 1
   IF henPeck(i) = 0 THEN henAnim(i) = 0
   EXIT SUB
 ENDIF
 fy = INT(henY(i)) + NH
 cx = INT(henX(i)) + NW \ 2
 IF henSt(i) = ST_CLIMB THEN
   IF henVD(i) < 0 THEN
     IF (CellFlag(cx, fy - 1) AND C_LADDER) <> 0 THEN
       ' A ladder stands proud of the girder it serves, so stop on
       ' reaching a floor rather than carrying on to the top of the
       ' overhang, where there would be nothing to stand on.
       ny = henY(i) - henSpd
       nfy = INT(ny) + NH
       r = (fy - 1 - PLAYTOP) \ CH
       IF ytop < fy AND ytop >= nfy AND RowSolid(r, INT(henX(i)), NW) <> 0 THEN
         henY(i) = ytop - NH
         henSt(i) = ST_WALK
       ELSE
         henY(i) = ny
       ENDIF
     ELSE
       henSt(i) = ST_WALK : SnapHen i
     ENDIF
   ELSE
     IF (CellFlag(cx, fy + 1) AND C_LADDER) <> 0 THEN
       henY(i) = henY(i) + henSpd
     ELSE
     ENDIF
   ENDIF
   henAnim(i) = henAnim(i) + 1
   EXIT SUB
 ENDIF
 ' Nothing underfoot means it has stepped off the end of something, so
 ' let it drop rather than flip direction on the spot every frame.
 IF RowSolid((fy - PLAYTOP) \ CH, INT(henX(i)), NW) = 0 THEN
   henY(i) = henY(i) + 2
   nfy = INT(henY(i)) + NH
   r = (nfy - PLAYTOP) \ CH
   IF r <= GROWS - 1 THEN
     IF RowSolid(r, INT(henX(i)), NW) <> 0 THEN henY(i) = PLAYTOP + r * CH - NH
   ELSE
     henX(i) = henX0(i) : henY(i) = henY0(i)
   ENDIF
   EXIT SUB
 ENDIF
 ' Now and then take a ladder - but only one that actually goes somewhere,
 ' and choose freely between up and down when both do, so a hen is not
 ' forever drawn to whichever was tested first.
 IF RND < LADDERODDS THEN
   wayUp = LadderUp(cx, fy)
   wayDn = LadderDown(cx, fy)
   IF wayUp <> 0 AND wayDn <> 0 THEN
     IF RND < 0.5 THEN wayDn = 0 ELSE wayUp = 0
   ENDIF
   IF wayUp <> 0 THEN
     henSt(i) = ST_CLIMB : henVD(i) = -1
     henX(i) = (cx \ CW) * CW + (CW - NW) \ 2
     EXIT SUB
   ELSEIF wayDn <> 0 THEN
     henSt(i) = ST_CLIMB : henVD(i) = 1
     EXIT SUB
   ENDIF
 ENDIF
 nx = INT(henX(i) + henDir(i) * henSpd)
 IF henDir(i) > 0 THEN edge = nx + NW - 3 ELSE edge = nx + 2
 IF nx < 0 OR nx > SCRW - NW THEN
   henDir(i) = -henDir(i)
 ELSEIF (CellFlag(edge, fy) AND C_SOLID) = 0 THEN
 ELSE
   henX(i) = henX(i) + henDir(i) * henSpd
 ENDIF
END SUB
SUB SnapHen(i AS INTEGER)
 LOCAL INTEGER r
 r = (INT(henY(i)) + NH - PLAYTOP + CH \ 2) \ CH
 IF r < 0 THEN r = 0
END SUB
'  one floor
'  returns 0 caught, 1 cleared, 2 quit
FUNCTION RunLevel() AS INTEGER
 LOCAL INTEGER i, e, rot, hit, cx
 LOCAL FLOAT nextFrame, dly
 LOCAL INTEGER tickAcc, running
 LoadLevel
 HideAllEnt
 DrawWorld
 px = startX : py = startY
 pvx = 0 : pvy = 0 : pState = ST_WALK : pFace = 0 : pAnim = 0
 pGround = 1 : pLift = 0 : pFell = 0
 ' Each time round the eight floors the odds get worse.  The second
 ' cycle empties the coop and lets the duck out; the third puts the hens
 ' back alongside it; the fourth fields the full five on every floor; the
 ' fifth does that with everything running flat out.
 SELECT CASE gLap
   CASE 0    : nHen = henBase(gIdx) : dkOn = 0
   CASE 1    : nHen = 0             : dkOn = 1
   CASE 2    : nHen = henBase(gIdx) : dkOn = 1
   CASE ELSE : nHen = MAXHEN        : dkOn = 1
 END SELECT
 IF nHen > nHen0 THEN nHen = nHen0
 FOR i = 0 TO nHen - 1
   henDir(i) = 1 : IF RND < 0.5 THEN henDir(i) = -1
   henSt(i) = ST_WALK : henVD(i) = 0
   henAnim(i) = 0 : henPeck(i) = 0
 NEXT i
 henSpd = 1.0 + 0.05 * gIdx + 0.28 * gLap
 IF henSpd > 1.9 THEN henSpd = 1.9        ' Harry must still outrun them
 dkSpd = 0.55 + 0.18 * gLap
 IF dkSpd > 1.3 THEN dkSpd = 1.3
 dkAnim = 0 : dkQuack = 0 : dkFace = 0
 IF dkOn <> 0 THEN dkX = 20 : dkY = PLAYTOP + 26     ' out of the cage
   lfY(i) = PLAYTOP + lfBot * CH - i * (((lfBot - lfTop) * CH) \ 2)
 NEXT i
 gTime = 900
 gBonus = gLevel * 1000
 tickAcc = 0
 running = 1
 RunLevel = 0
 ' Put everything on screen and hold it while the tune plays, so the
 ' floor can be studied before anything starts moving.
 SetEnt 0, S_STAND, INT(px), INT(py), 3, 0
   SetEnt i + 1, S_HENA + i, INT(henX(i)), INT(henY(i)), 2, 0
 NEXT i
 FOR i = nHen TO MAXHEN - 1
   SetEnt i + 1, 0, 0, 0, 2, 0
 NEXT i
 IF dkOn <> 0 THEN
   SetEnt E_DUCK, S_DUCK1, INT(dkX), INT(dkY), 4, 0
 ELSE
   SetEnt E_DUCK, 0, 0, 0, 4, 0
 ENDIF
 FOR i = 0 TO MAXLIFT - 1
   IF i < lfN THEN
     SetEnt E_LIFT + i, LiftBuf(i), lfX, INT(lfY(i)), 1, 0
   ELSE
     SetEnt E_LIFT + i, 0, 0, 0, 1, 0
   ENDIF
 NEXT i
 ShowEnts
 DrawHud
 FRAMEBUFFER COPY F, N
 Tune 0
 nextFrame = TIMER + FRAMEMS
 DO
   ' ------------------------------------------------------------ input
   ReadKeys
   IF kQuit <> 0 THEN RunLevel = 2 : EXIT DO
   IF kSkip <> 0 THEN
     gBonus = 0
     RunLevel = 1
     EXIT DO
   ENDIF
   UpdatePlayer
     UpdateHen i
   NEXT i
   ' ------------------------------------------------------------ lifts
     lfY(i) = lfY(i) - LIFTSPD
     IF lfY(i) < PLAYTOP + lfTop * CH THEN
       IF pLift = i + 1 THEN pLift = 0
     ENDIF
   NEXT i
   ' ------------------------------------------------------------- duck
   IF dkOn <> 0 THEN
     ' Home in on Harry, but leave a dead band on each axis.  Without one
     ' the duck overshoots by a fraction of a pixel every frame once it
     ' has drawn level with him and shivers on the spot.
     IF dkX < px - 3 THEN
       dkX = dkX + dkSpd
     ELSEIF dkX > px + 3 THEN
       dkX = dkX - dkSpd
     ENDIF
     IF dkY < py - 3 THEN
       dkY = dkY + dkSpd * 0.75
     ELSEIF dkY > py + 3 THEN
       dkY = dkY - dkSpd * 0.75
     ENDIF
     IF dkX < 0 THEN dkX = 0
     IF dkX > SCRW - DW THEN dkX = SCRW - DW
     IF dkY < PLAYTOP THEN dkY = PLAYTOP
     IF dkY > SCRH - DH THEN dkY = SCRH - DH
     ' Only turn round once Harry is clearly to one side, so the sprite
     ' does not mirror back and forth while the duck is right above him.
     IF dkX > px + 8 THEN dkFace = 1
     IF dkX < px - 8 THEN dkFace = 0
     dkAnim = dkAnim + 1
     dkQuack = dkQuack + 1
     IF dkQuack > 60 THEN dkQuack = 0 : SfxPlay SFX_QUACK, 1
   ENDIF
   ' ------------------------------------------------------- collecting
   cx = INT(px)
   FOR i = 0 TO nEgg - 1
     IF egOn(i) <> 0 THEN
       IF cx + HW - 2 > egX(i) AND cx + 2 < egX(i) + 12 THEN
         IF INT(py) + HH > egY(i) - 2 AND INT(py) + 4 < egY(i) + 6 THEN
           egOn(i) = 0 : eggLeft = eggLeft - 1
           AddScore 100
           EraseBg egX(i), egY(i), 12, 6
           SfxPlay SFX_EGG, 3
         ENDIF
       ENDIF
     ENDIF
   NEXT i
   FOR i = 0 TO nSeed - 1
     IF sdOn(i) <> 0 THEN
       IF cx + HW - 2 > sdX(i) AND cx + 2 < sdX(i) + 14 THEN
         IF INT(py) + HH >= sdY(i) - 2 AND INT(py) + HH <= sdY(i) + 8 THEN
           sdOn(i) = 0
           AddScore 50
           EraseBg sdX(i), sdY(i), 14, 4
           SfxPlay SFX_SEED, 2
         ENDIF
       ENDIF
     ENDIF
   NEXT i
   ' the hens stop to eat the grain too
   FOR e = 0 TO nHen - 1
     IF henPeck(e) = 0 AND henSt(e) = ST_WALK THEN
           IF INT(henX(e)) + NW \ 2 > sdX(i) AND INT(henX(e)) + NW \ 2 < sdX(i) + 14 THEN
             IF ABS(INT(henY(e)) + NH - (sdY(i) + 4)) < 5 THEN
               henPeck(e) = PECKFRAMES
               sdOn(i) = 0
               SfxPlay SFX_CLUCK, 1
             ENDIF
           ENDIF
         ENDIF
       NEXT i
     ENDIF
   NEXT e
   ' ------------------------------------------------------- collisions
   hit = pFell
     IF cx + HW - 3 > INT(henX(i)) + 2 AND cx + 3 < INT(henX(i)) + NW - 2 THEN
       ' the top of a hen is its raised head and neck, which Harry clears
       IF INT(py) + HH - 2 > INT(henY(i)) + NHEAD AND INT(py) + 3 < INT(henY(i)) + NH THEN
         hit = 1
       ENDIF
     ENDIF
   NEXT i
   IF dkOn <> 0 AND hit = 0 THEN
     IF cx + HW - 3 > INT(dkX) + 3 AND cx + 3 < INT(dkX) + DW - 3 THEN
       IF INT(py) + HH - 2 > INT(dkY) + 8 AND INT(py) + 3 < INT(dkY) + DH THEN
         hit = 1
       ENDIF
     ENDIF
   ENDIF
   ' ----------------------------------------------------------- render
   SetEnt 0, PlayerFrame(), INT(px), INT(py), 3, 0
     IF henDir(i) < 0 THEN rot = 1 ELSE rot = 0
     SetEnt i + 1, HenFrame(i), INT(henX(i)), INT(henY(i)), 2, rot
   NEXT i
   IF dkOn <> 0 THEN
     rot = dkFace
     IF (dkAnim \ 8) MOD 2 = 0 THEN e = S_DUCK1 ELSE e = S_DUCK2
     SetEnt E_DUCK, e, INT(dkX), INT(dkY), 4, rot
   ENDIF
   NEXT i
   ShowEnts
   DrawHud
   SfxService
   ' ------------------------------------------------------------ clock
   tickAcc = tickAcc + 1
   IF tickAcc >= 3 THEN
     tickAcc = 0
     gTime = gTime - 1
     gBonus = ((gLevel * 1000 * gTime) \ 9000) * 10
     IF gTime <= 0 THEN gTime = 0 : gBonus = 0 : hit = 1
   ENDIF
   IF hit <> 0 THEN
     Died
     RunLevel = 0
     running = 0
   ELSEIF eggLeft <= 0 THEN
     RunLevel = 1
     running = 0
   ENDIF
   ' ----------------------------------------------------------- timing
   IF running <> 0 THEN
     dly = nextFrame - TIMER
     IF dly > 0 THEN PAUSE dly
     nextFrame = nextFrame + FRAMEMS
     IF nextFrame < TIMER THEN nextFrame = TIMER + FRAMEMS
   ENDIF
 LOOP UNTIL running = 0
END FUNCTION
FUNCTION LiftBuf(i AS INTEGER) AS INTEGER
 IF i = 0 THEN LiftBuf = S_LIFT ELSE LiftBuf = S_LIFT2
END FUNCTION
FUNCTION PlayerFrame() AS INTEGER
   IF (pAnim \ 4) MOD 2 = 0 THEN PlayerFrame = S_CLIMB1 ELSE PlayerFrame = S_CLIMB2
   EXIT FUNCTION
 ENDIF
 IF pGround = 0 THEN
   IF pFace = 0 THEN PlayerFrame = S_RUN1 ELSE PlayerFrame = S_RUN2
   EXIT FUNCTION
 ENDIF
 IF pvx = 0 THEN
   PlayerFrame = S_STAND
 ELSE
   IF (pAnim \ 6) MOD 2 = 0 THEN
   ELSE
   ENDIF
 ENDIF
END FUNCTION
FUNCTION HenFrame(i AS INTEGER) AS INTEGER
   IF (henPeck(i) \ 5) MOD 2 = 0 THEN
     HenFrame = S_HENA + 2 * MAXHEN + i
   ELSE
     HenFrame = S_HENA + i
   ENDIF
 ELSE
   IF (henAnim(i) \ 5) MOD 2 = 0 THEN
   ELSE
     HenFrame = S_HENA + MAXHEN + i
   ENDIF
 ENDIF
END FUNCTION
'  status panel
'  The BBC sets it as black lettering on coloured panels, in two rows,
'  with a row of chicks for the lives in hand.
SUB Panel(x AS INTEGER, y AS INTEGER, t$)
 BOX x, y, LEN(t$) * FW + 4, FH, 0, panelCol, panelCol
 TEXT x + 2, y, t$, "LT", FONTN, 1, RGB(BLACK), panelCol
END SUB
SUB DrawHud
 LOCAL INTEGER i
 BOX 0, 0, SCRW, PLAYTOP, 0, RGB(BLACK), RGB(BLACK)
 Panel 2, 0, "SCORE"
 Panel 44, 0, RIGHT$("000000" + STR$(gScore), 6)
 FOR i = 1 TO gLives - 1
   IF i <= 8 THEN
     BOX 93 + i * 8, 1, 4, 2, 0, RGB(YELLOW), RGB(YELLOW)
     BOX 92 + i * 8, 3, 6, 4, 0, RGB(YELLOW), RGB(YELLOW)
   ENDIF
 NEXT i
 Panel 2, FH, "PLAYER 1"
 Panel 62, FH, "LEVEL " + RIGHT$("0" + STR$(gLevel), 2)
 Panel 124, FH, "BONUS " + RIGHT$("0000" + STR$(gBonus), 4)
 Panel 196, FH, "TIME " + RIGHT$("0000" + STR$(gTime), 4)
END SUB
SUB AddScore(n AS INTEGER)
 gScore = gScore + n
 IF gScore > gHi THEN gHi = gScore
 IF gScore >= gNextLife THEN
   gNextLife = gNextLife + 10000
   gLives = gLives + 1
   SfxPlay SFX_EXTRA, 4
 ENDIF
END SUB
'  losing a life
SUB Died
 LOCAL INTEGER i, e, y
 SfxSilence
 SfxPlay SFX_DIE, 5
 FOR i = 0 TO 24
   IF (i AND 1) = 0 THEN e = S_STAND ELSE e = S_CLIMB1
   y = INT(py) - i \ 3
   IF y < PLAYTOP THEN y = PLAYTOP
   SetEnt 0, e, INT(px), y, 3, 0
   ShowEnts
   SfxService
   PAUSE 40
 NEXT i
 SfxSilence
 gLives = gLives - 1
END SUB
'  a whole game
SUB PlayGame
 LOCAL INTEGER r, b
 gScore = 0 : gLives = 5 : gLevel = gStart : gNextLife = 10000
 DO
   ' Losing a life restarts the floor from scratch, as the original does:
   ' RunLevel calls LoadLevel every time, so all twelve eggs and the grain
   ' come back and the clock returns to 900.  Only the score, the lives and
   ' the level number carry over.  That is deliberate - it is not an
   ' oversight to be "fixed" into keeping the eggs already collected.
   r = RunLevel()
   IF r = 2 THEN EXIT DO
   IF r = 1 THEN
     Tune 1
     DO WHILE gBonus > 0
       b = 10 : IF gBonus < 10 THEN b = gBonus
       gBonus = gBonus - b
       AddScore b
       DrawHud
       SfxPlay SFX_TICK, 1
       SfxService
       PAUSE 12
     LOOP
     SfxSilence
     gLevel = gLevel + 1
     IF gLevel > 40 THEN gLevel = 33
   ENDIF
 LOOP UNTIL gLives <= 0
 IF gLives <= 0 THEN GameOver
 HideAllEnt
END SUB
SUB GameOver
 LOCAL INTEGER i
 Tune 2
 BOX 60, 96, 200, 48, 2, RGB(WHITE), RGB(BLACK)
 TEXT 160, 106, "GAME OVER", "CT", FONTN, 2, RGB(YELLOW), RGB(BLACK)
 TEXT 160, 128, "SCORE " + STR$(gScore), "CT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 PAUSE 2500
 FOR i = 1 TO 200
   IF INKEY$ <> "" THEN EXIT FOR
   PAUSE 10
 NEXT i
END SUB
'  title screen
SUB TitleScreen
 LOCAL INTEGER t, x, hb, nb, ud
 HideAllEnt
 CLS RGB(BLACK)
 TEXT 160, 10, "CHUCKIE EGG", "CT", FONTN, 3, RGB(YELLOW), RGB(BLACK)
 BOX 60, 40, 240, 2, 0, RGB(MAGENTA), RGB(MAGENTA)
 TEXT 160, 48, "after the 1983 A&F Software original", "CT", FONTN, 1, RGB(CYAN), RGB(BLACK)
 DrawCage 1
 TEXT 160, 72, "COLLECT ALL 12 EGGS ON EACH FLOOR", "CT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 TEXT 160, 84, "BEFORE THE CLOCK RUNS DOWN", "CT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 TEXT 76, 106, "ARROWS / Z X", "LT", FONTN, 1, RGB(GREEN), RGB(BLACK)
 TEXT 186, 106, "RUN, CLIMB", "LT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 TEXT 76, 118, "SPACE", "LT", FONTN, 1, RGB(GREEN), RGB(BLACK)
 TEXT 186, 118, "JUMP", "LT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 TEXT 76, 130, "ESC", "LT", FONTN, 1, RGB(GREEN), RGB(BLACK)
 TEXT 186, 130, "QUIT", "LT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 SPRITE WRITE S_EGGA, 106, 152, 0
 TEXT 122, 152, "100", "LT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 SPRITE WRITE S_SEED, 184, 154, 0
 TEXT 202, 152, "50", "LT", FONTN, 1, RGB(WHITE), RGB(BLACK)
 TEXT 160, 170, "HIGH SCORE " + STR$(gHi), "CT", FONTN, 1, RGB(MAGENTA), RGB(BLACK)
 FOR x = 0 TO SCRW - 1 STEP CW
   DrawGirder x, 231
 NEXT x
 t = 0
 ud = 0
 ' start from a clean slate so a key still held from the last game does
 ' not nudge the level select or start play straight away
 DO
   ' level select, for testing: UP and DOWN pick where to start
   IF kUp <> 0 AND ud = 0 THEN
     gStart = gStart + 1
     IF gStart > 40 THEN gStart = 1
   ELSEIF kDown <> 0 AND ud = 0 THEN
     gStart = gStart - 1
     IF gStart < 1 THEN gStart = 40
   ENDIF
   ud = kUp OR kDown
   TEXT 160, 184, "START ON LEVEL " + RIGHT$("0" + STR$(gStart), 2) + "  (UP/DOWN)", "CT", FONTN, 1, RGB(CYAN), RGB(BLACK)
   x = 20 + ((t * 2) MOD 280)
   IF (t \ 6) MOD 2 = 0 THEN hb = S_STAND ELSE hb = S_RUN1
   IF (t \ 5) MOD 2 = 0 THEN nb = S_HENA ELSE nb = S_HENA + MAXHEN
   SetEnt 0, hb, x, 231 - HH, 3, 0
   SetEnt 1, nb, 290 - ((t * 1) MOD 300), 231 - NH, 2, 1
   ShowEnts
   IF (t \ 10) MOD 2 = 0 THEN
     TEXT 160, 200, "PRESS SPACE TO PLAY", "CT", FONTN, 1, RGB(YELLOW), RGB(BLACK)
   ELSE
     BOX 40, 200, 240, 10, 0, RGB(BLACK), RGB(BLACK)
   ENDIF
   PAUSE 45
   t = t + 1
   ReadKeys
 LOOP UNTIL kJump <> 0
 HideAllEnt
END SUB
'  Sound effects.  Each entry is
'      DATA channel, waveform, volume        waveform 0=square 1=triangle
'      DATA freq, frames, freq, frames, ... , -1, 0        2=sine 3=noise
'  A frequency of 0 is a rest.  One frame is about 33 ms.  Volume is
'  0 to 25 per channel (PLAY SOUND caps it at 100 / MAXSOUNDS).
sfxdata:
' egg collected - quick rising sparkle
DATA 0, 0, 10
DATA 659,1, 880,1, 1047,1, 1319,1, 1568,1, 2093,2, -1,0
' grain collected
DATA 0, 0, 9
DATA 1568,2, 1047,2, -1,0
' jump
DATA 0, 0, 8
DATA 262,1, 349,1, 440,1, 523,1, 659,1, -1,0
' caught - long fall away
DATA 0, 0, 13
DATA 880,2, 784,2, 698,2, 622,2, 587,2, 523,2, 466,2, 415,2, 370,2
DATA 330,2, 294,2, 262,2, 233,2, 208,2, 185,2, 165,3, 147,3, -1,0
' hen cluck
DATA 2, 1, 7
DATA 1245,1, 740,1, 988,1, 0,1, -1,0
' footfall
DATA 1, 0, 4
DATA 147,1, 0,1, -1,0
' bonus countdown tick
DATA 0, 0, 8
DATA 2093,1, 0,1, -1,0
' extra life
DATA 0, 0, 12
DATA 1047,2, 1319,2, 1568,2, 2093,2, 1568,2, 2093,4, -1,0
' duck quack
DATA 2, 1, 8
DATA 330,3, 262,3, 311,3, 247,4, -1,0
' landing thud
DATA 3, 3, 5
DATA 300,2, 0,1, -1,0
' ---------------------------------------------------------------- tunes
'  DATA frequency, milliseconds ... terminated by -1, 0
tune0:
DATA 523,70, 659,70, 784,70, 1047,140, 0,40, 784,70, 1047,220, 0,1, -1,0
tune1:
DATA 784,80, 988,80, 1175,80, 1568,80, 1976,260, 0,1, -1,0
tune2:
DATA 523,180, 494,180, 440,180, 392,180, 330,520, 0,1, -1,0
' ----------------------------------------------------- hens per floor
'  How many of the five hen squares each floor uses on cycles 1 and 3.
'  Cycle 2 uses none, cycles 4 and 5 use all five.
hendata:
DATA 3, 4, 4, 4, 3, 3, 3, 3
'  Sprite bitmaps lifted from the BBC Micro title screen.
'    DATA width, height, colour index, hex bitmap
sprdata:
DATA 16,18,7,"03C00FF0FFFF0FF00FF003C003C0CFF3FFFF3FFC3FFC3FFC0FF00C300C303C3C00000000"   ' SP_STAND
DATA 16,18,7,"03C00FF0FFFF0FF0CFF0C3C0C3C0CFF0FFFF3FFF3FFF3FFF0FF33FF0003000300030003C"   ' SP_RUN1
DATA 16,18,7,"03C00FF0FFFF0FF00FF303C303C30FF3FFFFFFFCFFFCFFFCCFF00FFC0C000C000C003C00"   ' SP_RUN2
DATA 16,18,7,"0000000003C00FF0FFFF0F300FF0030003C00FF03CFC3CFC3CFC3CFC0FF003C0030003C0"   ' SP_CLIMB1
DATA 16,18,7,"0000000003C00FF0FFFF0F300FF0030003C00FF03CFC3CFC3F3C3F3C0FF00FC030CC0C30"   ' SP_CLIMB2
DATA 31,22,14,"00007E000001FF860007F9980007F9E00007FFE00007FF980001FE060001F8000000780003F87E000FFE7E003F07FF80FCF87F80F3FF9F80CFFFFFE0FFFFFFE0FFFFFFE03FFFFFE03FFFFF800FFFFF8003FFFE00007FF800"   ' SP_DUCK1
DATA 31,22,14,"00007E000001FF800007F9800007F9FE0007FFFE0007FF800001FE000001F8000000780003F87E000FFE7E003FFFFF80FFFFFF80FFFE7F80CFFF9FE0CFFF9FE0F3FF9FE03CFE7FE03F39FF800FC7FF8003FFFE00007FF800"   ' SP_DUCK2
DATA 14,20,7,"03C00F3C0FC00300030000C000C000303C30FF3CFFFCFFFCFFFC3FF00F000C000C000C000C000F00"   ' SP_HEN1
DATA 14,20,7,"03CC0F300FCC0300030000C000C000303C30FF3CFFFCFFFCFFFC3FF00F0033003300C0C0C0CC3030"   ' SP_HEN2
DATA 14,20,7,"000000000000000000000000000000003C00FF00FFFCFFFCFFFC3FF00F300C300CFC0CFC0C000F00"   ' SP_HEN3
DATA 20,4,14,"FFFFFFFFFF7FFFE7FFFE"   ' SP_LIFT
DATA 12,6,14,"3F0F3CCFFFFFFFC3F0"   ' SP_EGGA
DATA 12,6,15,"3F0F3CCFFFFFFFC3F0"   ' SP_EGGB
DATA 14,4,9,"03000CC03330CCCC"   ' SP_SEED
'  The eight floors.  20 columns x 28 rows, one cell = 16 x 8 pixels.
'    .  empty          #  girder        H  ladder
'    E  egg            S  grain         L  lift shaft
'    P  Harry starts   1-4  a hen starts
lvldata:
' ---- level 1
DATA "...................."
DATA ".......H............"
DATA "......EH1....ES....E"
DATA ".....##+##.######.##"
DATA ".......H..ES........"
DATA "...5E..H.###........"
DATA "...####+........S..."
DATA ".......H.......##..."
DATA ".......H.....##....."
DATA "...H...H..E##......."
DATA "..EH.S.H4##....S.E.."
DATA "..#+###+#.....#####."
DATA "...H...H............"
DATA "...H...H...H....H..."
DATA ".E3H.S.H...H.ES.H.E."
DATA ".######+###+####+##."
DATA ".......H...H....H..."
DATA "..S.EP.H...H.S..H..2"
DATA "####################"
' ---- level 2
DATA "....H....H.......H.."
DATA "....H5.E1H..S4.E.H3E"
DATA "....+####+#.#####+##"
DATA "..H.H.H..H...H...H.."
DATA "S.H.H.HE.HS..H...H.."
DATA "##+###+##+#.#+###+##"
DATA "..H...H..H...H...H.."
DATA "E.H...HE.H...H...H2E"
DATA "##+#.#+##+#####.#+##"
DATA "..H...H..H.......H.."
DATA "E.H.E.H..H...E..SH.."
DATA "##+####.#+#.###.#+##"
DATA "..H......H.......H.."
DATA "..#......H.......H.."
DATA ".........H.......H.."
DATA "SPSS.E...H..E..S.H.."
DATA "####.###############"
' ---- level 3
DATA ".............H......"
DATA "...H....H.H..+##..SE"
DATA "...HE..SH2H..H..#.##"
DATA "...+#..#+#+#SH......"
DATA "...H....H.H.##.S...."
DATA "...H....H.H....#.E.H"
DATA "SE3H....H.H......#.H"
DATA "###+....H.H.......#+"
DATA "...H....H.H........H"
DATA "...H....H.H..S.E...H"
DATA ".H.H....H.H.##.#...H"
DATA ".HSHE.E.H.H........H"
DATA "#+###.#.H.H.......##"
DATA ".H......H.H....E.#.."
DATA ".H......H.H....#...."
DATA ".H.....SHEH...#...H."
DATA ".H.....####.#...E1H."
DATA ".H.............###+."
DATA ".H................H."
DATA ".H..E.............H."
DATA "4HS##.......5SPE..H."
DATA "###....###.#########"
' ---- level 4
DATA "................E..."
DATA "........H.....H.#..H"
DATA "........HS4..SH..2.H"
DATA ".....#.#+##L.#+#E##+"
DATA "....#...H..L..H.#..H"
DATA "...#....H..L..H....H"
DATA "E.#.....H..L..H....H"
DATA "#.......HE.L..H....H"
DATA "........+##L.#+.#E#+"
DATA ".....S.#+..L..H..#.#"
DATA ".....#..H..L..H....."
DATA "E..#....H..L..H....."
DATA "##......H..L.EH5...."
DATA ".......#+..L.####..E"
DATA "........H..L......##"
DATA "........H..L........"
DATA "...H....H..L...H...."
DATA "S..H...EH..L...HE..."
DATA "###+#..#+##L.##+##.."
DATA "...H....H..L...H...#"
DATA "E..H1...HPSL.E.H.3S."
DATA "#####.#####..#######"
' ---- level 5
DATA "............H......."
DATA "....H.......HE.S...."
DATA "...SHESS....+###..SE"
DATA "...#+###....H...L.##"
DATA "....H....#.EH...L..."
DATA "....H......###..L..."
DATA "..H.H.........#.L..."
DATA "E1H.H..H........L..."
DATA "##+#+#.H........L..."
DATA "..H.H..H........L..."
DATA "..H.H..H....H...L..."
DATA "E5H3H..H..S.H.4SL..E"
DATA "######.H.E##+###L..#"
DATA ".......H.#..H...L..."
DATA ".......H....H...L..."
DATA "...H...H..H.H.H.L..."
DATA "E2.H.E.H..H.H.H.L..."
DATA "###+##.H.#+##E+#L..."
DATA "...H...H..H..#H.L..."
DATA "...H...H..H...H.L..."
DATA "E..HSSSH..H..SHSL.SP"
DATA "##.#########.###..##"
' ---- level 6
DATA ".................H.."
DATA "..............H..HEE"
DATA "......E.......H..+##"
DATA "......#.#K..E.H..H.."
DATA ".........K..##+##+.."
DATA ".........K....H..H.."
DATA "....H....K....#..H.."
DATA "S2SSH..E.K.......H4E"
DATA "####+#.#.K......#+##"
DATA "....H....K.......H.."
DATA "....H....K....H..H.."
DATA "....H.5S.K..E.H.EH.."
DATA "..##+###.K..##+##+.S"
DATA "....H....K....H..+##"
DATA "H...H....K....H..H.."
DATA "H...HE...K..E1H..H.."
DATA "+#.#+#...K..###..H.."
DATA "H...H....K.......H.."
DATA "H...#....K.......H.."
DATA "H3E.....PK.SSSS.EH.."
DATA "###...###..####.##.."
' ---- level 7
DATA ".....H.H.H.........."
DATA ".....HEHEHE........."
DATA ".....H#H#H#2SH.EE..."
DATA ".....H.H.H.##+###K.."
DATA ".....H.H.H...H...K.."
DATA ".....#.#.#...H...K.."
DATA ".............H...K.."
DATA "3H.S...E.....H.H.K.."
DATA "#+###.##....4H.H.K.."
DATA ".H..........###+EK.."
DATA ".H.............H#K.."
DATA ".H.............H.K.."
DATA ".H5..#..#..E...H.K.."
DATA "#+#..#..#.##...H.K.."
DATA ".H...#........1HEK.."
DATA ".H...#.ES.....###K.."
DATA ".H.H.####........K.."
DATA ".HSH.............K.."
DATA ".+#+.............K.."
DATA ".H.H.............K.."
DATA "#+.H........E....K.."
DATA ".HEH.....#..#....K.."
DATA ".H#HP##..#.....##K.."
DATA ".#.##..##..........."
' ---- level 8
DATA ".................E.."
DATA "..........H......#.."
DATA "...E......H.5......."
DATA "...#.E#E##+##E#E.#.."
DATA ".....#.#..H..#.#...."
DATA "..........H........."
DATA "....H.....H.....H..."
DATA "....H.1...H.....H..."
DATA "...#+##.E#+#E.##+#.."
DATA "....H...#.H.#...H..."
DATA "....H.....H.....H4.."
DATA "..####E.##+##.E####."
DATA "......#...H...#....."
DATA "...H......H......H.."
DATA "..3H......H......H.."
DATA "..#+#E.#######.E#+#."
DATA "...H.#.........#.H.."
DATA "...H.............#.."
DATA "...H................"
DATA "PSSHSSS.SSSSSSSSSS2S"
Edited 2026-09-09 19:00 by matherp
Martin H.
Posted: 09:46am 09 Sep 2026
NICE
I had the Spectrum version of Chuckie Egg back then, but my brother-in-law’s Dragon32 version was simply more fun.
Thank you
Martin
'no comment
Posted: 09:53am 09 Sep 2026
Hi Peter,
Plays nice on 2040 VGA design 2. Including sound. Used keyboard to play.
2 levels.
Looked at the program, nicely coded .. Claude .. I assume ?
Wonderful how things can be created now adays. If I had to write it myself, it would have taken few weeks of coding, and more of debugging.
Maybe a nice addition for the Game*Mite. I'll look into it.
Thanks,
P.S. 1 remark : vertical position on ladders is very critical when walking on platforms (I think 1 pixel height difference). Jumping is the best way to change from ladder to plaform. Haven't played the original, so not sure if this is normal. I may have time to look into it this weekend. No free evenings this week.
Edited 2026-09-09 20:40 by Volhout
Geoffg
Posted: 10:06am 09 Sep 2026
Runs perfectly using the MMBasic toolchain for Windows.  Looks like a fun game.
Geoff
DaveJacko
Posted: 09:11pm 09 Sep 2026
I worked for A&F in 1984, got the job by knocking on the door. I remember the racks of tape duplicators. I touched a seminal moment..
Try swapping 2 and 3 over
Posted: 09:27am 10 Sep 2026
Peter,
Attached is a version of Chucky that runs on Game*Mite/PicoGamer, as well as VGA (and untested HDMI). Tested on V6.03.00.
The only inconsistency I have (according Wikipedia) found is that by collecting seeds, you not only gain point, but also gain time. That is not the case in this version.
chuckie_gm.zip
Edited 2026-09-10 19:28 by Volhout
PilotPirx
Posted: 09:34am 10 Sep 2026
Great Game, love Chuckie Egg!!! Thank you!!
Posted: 09:47am 10 Sep 2026
Sorry
Wrong file uploaded. This is the correct one. Earlier one was missing the Game*Mite instructions. But plays as well.
chuckie_gm.zip
PilotPirx
Posted: 10:05am 10 Sep 2026
@Volhout
With my PicoGamer i get the Error
"Error: Syntax
[259] BLIT LOADARRAY n,w,h,img()
Posted: 11:55am 10 Sep 2026
HI PilotPirx,
What firmware are you using (MMBasic version).
There is no command BLIT LOADARRAY. But there is a command SPRITE LOADARRAY.
Earlier versions of MMBasic did a translation of SPRITE to BLIT (since they where synonyms) but since version MMBasic V6.xxxxx they have been logically separated.
SPRITE is for with graphical elements
BLIT is for memory related function (brute force copy graphics memory to another location).
It is hard for me to advise what you should do. There is a "Game Mite" uf2 file that you can program, which has a set of games. But that is not Geoff's image. It is closer to Tom's image.
image GM2040
Geoff indicated he was working on an upgrade for PicoGamer, but not sure what the status is.
Edited 2026-09-10 22:02 by Volhout
PilotPirx
Posted: 12:11pm 10 Sep 2026
Hi Volhout,
i used Picogamer V1.0 from Geoffs homepage.
There is no Info which Version it is.
Seems to be Version 5.08.00.
Is there a newer one for the PicoGamer?
Posted: 12:20pm 10 Sep 2026
Hi PilotPirx,
See my question to Geoff in the Pico Gamer thread.
The PicoGamer is slightly different from Game*Mite in that it has 4 or 16Mb flash, and thus can hold more programs in A:/ drive.
Geoff has used that flash space, so the PicoGamer has a larger set of built-in games compared to Game*Mite.
Wait for his answer...
PilotPirx
Posted: 12:25pm 10 Sep 2026
Hi Volhout,
thank you for your support.
Waiting for Geoffs answer.
Posted: 07:38am 13 Sep 2026
Here is an update:
chuckie.zip
Grain stops the clock. A clockStop counter is set to 20 on pickup and the whole tick — TIME and BONUS — is skipped while it runs down, mirroring .update_timers. It's an assignment, not an addition, so a second pile restarts the pause rather than extending it, exactly as the BBC's STA clock_stop_timer does. 20 ticks is the same 2.2 % of the level clock as the original; Points stay at 50.
Eggs scale with level. 100 × ((level−1) \ 4 + 1), capped at 1000. Verified the formula on the board across all 40 levels — 100 on 1–4, 200 on 5–8, up to 1000 at 37–40, so the cap is reached exactly at the top of the range rather than clipping anything.
Riding a lift into the top costs a life. Previously the lift just wrapped and dropped Harry.
Ladder step-off tolerance implemented, so he can step across from up to 3 px above a girder and gets dropped the last pixel or two. Three rather than two because a climb step is 2 px and a mid-air grab adds a fraction on top.
Edited 2026-09-14 04:18 by matherp
Posted: 06:39pm 13 Sep 2026
Hi Peter,
Any reason you did not take the universal chucky I created (gamemite and VGA/hdmi) as a basis to do the mods ?
Now I have to mod this one as well, with the same changes.
Posted: 06:51pm 13 Sep 2026
yes, because I would have had to work out the changes and apply them. The game is on github so you should be able to push the mods to that and then assuming I accept them they will be integrated into the single source
Posted: 07:39pm 13 Sep 2026
Peter,
Chucky is not in your Tailwind github (where the Pico releases are)....
Maybe it is not public.
Posted: 08:06pm 13 Sep 2026
I'm not sure whether I should admit this or not. I've never played Chucky Egg. In fact I don't remember watching anyone else play it either, although I surely must have at one time or another. :)  I was never a great one for playing games unless they were adventures of some sort, partly because my reaction times are pretty close to those of a snail.
Posted: 09:29pm 13 Sep 2026
  Quote  Chucky is not in your Tailwind github (where the Pico releases are)....
https://github.com/UKTailwind/PicoMite/tree/main/Bas
Posted: 06:39am 14 Sep 2026
  Mixtel90 said  I'm not sure whether I should admit this or not. I've never played Chucky Egg.
Honestly, Mick, Reason I have so much trouble porting games to pico, is because I never played the originals. I must have been under a rock at that time. Never played:
Star trek
Chucky Egg
Elite
Breakout
Lemmings
Asteroids
Flappy Bird (didn't exist in my 'youth')
Tetris
Galaxian
Space invaders
Kingdom
My Gaming history was limited to
Sokoban
Frogger
And text adventure games.
My girlfriend (now wife) played Tapper.
