Local Time 01:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Computer 3 - One board to rule them all
     Page 11 of 11
cdeagle
Posted: 09:14pm 10 Nov 2026
Is it possible to plug the PicoMite 3 into a PC and use TeraTerm and MM Edit 5?
Posted: 09:32pm 10 Nov 2026
It has a built-in serial to USB adapter (U7 - CH340) for the serial console, connected to COM2 on GP8 & 9.
The console USB-C socket (USB2) is near the HDMI socket.
Edited 2026-11-11 07:49 by phil99
Posted: 09:51pm 10 Nov 2026
  cdeagle said  Is it possible to plug the PicoMite 3 into a PC and use TeraTerm and MM Edit 5?
Depending on which firmware you have loaded, MMEdit will connect to the USB "firmware update" port just like a "normal" picomite.
If you load one of the standalone firmwares, you use the serial-USB adapter which is part of the PC3. In this case you have to be sure to use the correct baud rate. Usually 115200
cdeagle
Posted: 10:08pm 10 Nov 2026
Thanks guys. That worked especially when I turned on the power switch.
Call me old fashioned.
     Page 11 of 11
